loading
Step 1: Buy a luggage scale
This is the luggage scale that I bought off the Internet for $16. You attach your luggage to these hand-held devices and lift them with the luggage attached. The scale beeps or stops changing value and then you read off the weight. Their maximum range is about 125 lbs – less than a lot of bee hives. However, if you measure the hive by only lifting one side - and assume that weight in the hive is more or less centrally distributed - then you are only measuring half the hive's weight. You have a loss in accuracy but your maximum range is now extended to 250 lbs.
You do not need to use exactly the same scale shown here. However, you may need to get creative in attaching the luggage scale to the scale handle.
That a clever idea. Last year I wanted to bring my beehive to scout camp (where i worked for the summer) and being a Biologist wanted to be able to make some a project out if it with some hard data. But couldn't find a way to weight it cheaply. On the way to a flea market I saw this scale for sale. I said we will stop, I 'll ask, he will say too much and I can walk away. $20 dollars later its in the car. People throw away the scales it the hanging weights people want. Also not pictured was a indoor out door thermometer. Which is more useful to tell when the bees come out of hibernation. but also when I added the second brood chamber it remained at ambient temperature for three weeks until they built it out and then raised to about 98 deg after they built it out. As my luck would have it, New England had a hot dry summer and the hive went from 125lbs to about 90lbs (I have never Checked to see if the scale is accurate I just wanted to know when the nectar flow started) After checking with other bee keepers this was a low flow year. Last year we had a lot of rain and there was no poilen or nectar
<p>HI turbo bug Can you tell me what brand/make the scale you purchased is??</p>
<p>Hi I am Serbia. I made this device but I think it is accurate only in ideal conditions. Problem is that conditions are never ideal. Beehives are tilted towards front side and weight is rare centrally distributed. i think even diference in weight is not going to be very accurate.</p>
<p>Hi Serbia,</p><p>Your scale looks great. However your experience is the same as mine before I added 1) a stop to insure that the handle is depressed exactly the same each time and 2) a level to insure that the measurement is consistent. Yes, it will not be as accurate as an iron platform scale but if you measure hive weight over time, you should be able to see trends and infer problems or nectar flows.</p>
Very cool. Kind of a mechanical/electronic solution.<br><br>I just put each hive on its own Nintendo Wii-Fit Board. ;-)<br><br><br>
<p>What app do you use to read it? Do you need to reset the Bluetooth every time?</p>
Any assumption, such as &quot;and assume that weight in the hive is more or less centrally distributed&quot; makes me wonder a little about results, because sometimes our assumptions are wrong. The queen might move around from day to day, for example, and the mass of bees with her. Still, I like the general idea behind your invention. May it provide you with correct and useful information.
I suspect that the difference in weight from &quot;shifting&quot; of the Queen position, and her attendants, is probably negligable, BUT... what does concern me is that I notice that the direction of the cord attached to the pull ring on the scale to the center &quot;paddle&quot; is routed over a PULLEY, and my recollection from high school physics [about 1957 or 8] and college physics [about 62 or 63] is that the actual weight on the paddle would be divided by the mechanical advantage of the radius of the pulley, and thus induce error in the weight indicated on the scale.<br> <br> IF I'm correct, this would indicate LESS weight than actual,&nbsp; but IF you're only &quot;comparing&quot; changes in weight rather than actual weight, then this error is not an issue.
Perhaps if you weighed one side and then went around to the other side and did a comparison weight you might be able to check if the bees are all hiding on one side... just a thought... But I agree with being wary of assumptions... and i also didn't think that lifting one side would give an accurate reading.. like a fat man standing on one leg on a set of bathroom scales... but i could see that it would provide a base for comparison readings for the hive under different conditions and let you see changes in weight of the hive... and i think this is the main point of the exercise more than finding the 'true' mass of the hive..<br>A great instructable..
You might wish to weigh both sides of the hive but you would not want to lift the front unless you have full gear on. The bees don't take to large animals obstructing their flight path.<br><br>Regarding accuracy, I am most interested in relative changes - net weight loss and gain. That will tell me if the bees are finding nectar, absconding, foraging - or not, and so on. A platform scale can be more accurate but it has its problems also. See www.beehacker.com for more on that.
Hi, thanks for the instructable. I have just completed my second set of scales, one for me and one for our local bee association training site. I am new to beekeeping, infact two hives plus bees should arrive at the end of the month. I have also built two hive stands following the design on &quot;www.beehacker.com&quot;.<br>Best regards from France (Lorraine).
Clever idea! At 1st glance I worried about the accuracy because of the lever arm, then I looked a little closer and see that my concern is unfounded, the attachment of the cable is near the end of the lever arm, at nearly the same place the weight from the hive is applied.<br><br>Seeing that (afaict) the distance lifted is very small, I think you can get a quite accurate total weight by weighing first one side of the hive, then the other, and adding them together. (If the distance lifted is very small, the center of gravity of the entire hive will shift very little, thus allowing you to add the two weights to get a total with fairly good accuracy.
what is the purpose of this thing?im new to bee keeping.i always thought one build the hives buy the bees and that's it
Well...often you can. However, in order to keep your hive healthy, monitor conditions and (of course) collect honey, it's important to work with your bees once in a while.<br>You wouldn't scatter some seeds and expect a beautiful, lush garden a couple of months later. Beekeeping's just like any other form of agriculture; without putting work into it, you can't expect great results.<br>One of the biggest problems you encounter is swarming. Swarming is how colonies propagate, and it involves the queen, along with a large portion of the workers, leaving the hive to start a new one elsewhere. Your workforce is hugely diminished, and raising up replacement workers and a new queen uses a lot of honey, meaning you won't get as much honey when you harvest. You can forestall this by a number of methods, but in order to do so, you have to realize that it's going to happen. A scale can help you figure that out.
what would one do to prevent this?
I can understand your confusion. Very few beekeepers are able to weight their hives. The only other alternative to this pry scale is to buy an antique iron platform scale from eBay. Of course, that only takes care of one hive. At $200 a pop (don't even think about shipping), you won't see too many beekeepers using platform scales.<br><br>According to a recent survey of beekeepers last year, the largest cause of colony death over winter was not CCD but starvation. The bees collect honey to generate heat to survive winter. What, you thought they did it all for you? Without enough stores, they die. Grizzled old beekeepers will tell you that you can lift your hive and tell if they need feeding. Ooookkaaay. But why leave it to guesswork?<br><br>For more information on this invention (and other inventions), visit www.beehacker.com.<br>
Outstanding! Awesome job.
Really neat. <br>Very well thought out and made.
About This Instructable
51,339views
73favorites
License:
More by trearick:Build a scale to weigh bee hives
Add instructable to:
