Build a scale to weigh bee hives
 by trearick
Featured
Step 3: Drill and cut the wooden paddle and lever
Saw out the outline of the paddle in 3/4" plywood, oak, maple, hickory, or other tough wood. Make a lever that the user will use to pull the luggage scale with. Then drill the holes.  Cut out the center tongue as shown at right. I used a band saw for the two long cuts down the tongue then used a jigsaw to join the two cuts.  Sand and finish with a tough marine varnish.
A note on drilling the holes: the mending plates on the bottom share some of the same holes as the corner braces on the top. I could see no way around it. You just need to be precise in your drilling.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
