Step 2The dangers you must know...
There is one thing you must know, a healthy human heart can only withstand electric currents maximum 10mA. Currents over 10mA can results death, I am NOT joking here, this is serous stuff, a lot of people thinks your heart can handle currents up to 500mA, THIS IS NOT TRUE!!! THEY ARE WRONG!!! If you don't believe me, then test your self against a high voltage 500mA power supply, a small microwave transformer would do, put your hand on one lead, put your other hand on the other lead, turn on the power supply and you will be sorry...
The marx generator will also be dangerous after the power is turned off, because the capacitors will hold a lethal charge in them, so, MAKE ABSOLUTELY SURE YOU DRAIN ALL THE CAPACITORS BEFORE YOU TOUCH THE DEVICE!!! Otherwise you will get a 'surprise shock' form the capacitors which can seriously harm you or even death...
Also, every time a marx generator fires (make a spark), it kicks out a lot of UV radiation, and sometimes X-rays! Staring at the sparks form the marx generator can cause problems with your eyes, so wear UV sunglasses or briefly watch it every once a while. If you want to be safe, use laser protection glasses, it will take out nearly all of the UV emitted from the spark and you might not be able to see the spark well, but it much better for your eyes.
Okay, you might be a bit scared after reading this horrible step, so do you think you can build a marx generator? Or find it too dangerous to build it? The choice is yours...
Can this really harm you? The idea that a special number of voltage or amperage will automatically kill you is not accurate.
Scuffing your feet across a carpet and touching something metal also produces thousands of volts and large currents, but it obviously doesn't harm you, because the capacitance is small and the spark is very short-lived. Yes, it's high voltage and high current, but the duration is less than a microsecond.
I'm sure it hurts, but I'm skeptical that it would actually cause any harm. How long are the sparks in cm?
10x 1 nF capacitors charged to 7 kV store a total of 250 mJ. Scuffing your feet across the floor stores maybe 60 mJ max by comparison.
"The effects of electrical current passing through the human body are covered at length in the International Electro Technical Commission document IEC 479-2:1987. In this document it indicates that a transient or capacitive discharge, as is the case with static electricity, requires energy in excess of 5 Joules (5000mJ) to produce a direct serious risk to health."
1/2 * 1 nF * (5 kV)^2 = 0.0125 J = 12.5 mJ
Wolfram Alpha can do a lot of work for you:
capacitor stored energy 5 kV 1 nF
Multiply by 10 and you have 125 mJ total, which is 1/40th of the energy that document says is the minimum that will hurt you.
I'm not claiming that this thing definitively can't hurt you. I'm just skeptical that it's dangerous. Even if it's not harmful to health, the shock might still hurt like hell. :D
D:
Bit of trivia for you: all modern car windshields and windows are polarized, so in theory you could sit in your car all day in full sun, all else being equal, and not get a sunburn (though the heat would be horrific).
if your sunglasses say "uv blocking", they're gonna block uv. you can easily test their effectiveness with a fluorescent blacklight.
However, 5kV-10kV is serious, and while a static charge on your finger is higher voltage (20kV), it only has a few microamps, whereas this will put out an amp or two of a few milliseconds. Actually, it's producing a 2 inch spark, it must be getting to at least 50kV and probably higher since the breakdown voltage of dry air is 33kV/cm. (It's less for humid air). At that voltage, x-rays are a real possibility, though probably not that many.
