loading
Step 8: Testing... Testing...
All right, you had built a marx generator, and it is now time to test it! Wire up your marx generator to the HV power supply and flip the switch!
3... 2... 1... *Flips switch* And.....
SNAP
Wow!
SNAP
Cool!
SNAP
It works!!! Yay!
SNAP
Holy ****. You expect people to build it after your little High voltage speech at the beginning? Your crazy man.
<p>shocking</p>
Nice pun ?
Really cool! It looks like alot of those sparks are black. That's not something I've ever seen. What's up with that? Why are they black colored?
<p>It's probably an issue with the camera. </p>
<p>Will it make a difference if I used a 1.5 watts resistor?</p>
<p>Hello PLasmana, thank you for the instructable! My Marx generator is pictured below. I built your power supply, but it sparked only every thirty seconds, so I was forced to find another power source for the generator. The mosquito bat pictured outputs about 2.5 kilovolts.. Also, I bought variable resistors by mistake instead of the normal ones. They work fine, though. </p>
&iexcl;Excelente! Muy buen trabajo, perfectamente explicado y documentado con im&aacute;genes. Te mereces un sobresaliente campe&oacute;n
<p>Nice. </p>
i made Power supply for marx generator but i want to know what is the red board ? i must made one like it ? its essential? or i continue to build marx generator without it ?
<p>I tried to make 100kV one, I got one spark, and then it sadly burned out full bridge rectifier, so I replaced broken diode and then it broke my 5kV transformer. :(</p>
<p>okay so I made one that outputs 17kV (not consistent) (entirely different types of materials, but the materials are the same [like instead of using 1nF, 4kV cer. cap. I used my 2F 7kV]) but the problem is the spark length... it doesn't really go that far (only up to 3 inches) but when it sparks it gives off too much.. so I guessed I certainly need to go farther but it just doesn't create a spark when I go farther than 3 inches..<br><br>also did I mention I used an inductor to resist huge voltage fluctuation</p>
<p>all of the spark gaps on mine are firing, but there is nothing on the big spark end. what is the problem?</p>
<p>in electricity / electronics world..my teacher ..an old guy..once showed us how in the old days he would apply the one hand rule in all high voltage situations..(120 volts and higher AC)..he said he always put one hand in his picket while he wet the tips of his fingers and touched the outlet he was checking..the theory is that electrical current always flows to the shortest path. He demonstrated it and yes go a minor shock through his hand as the current travelled in one finger and out the other of the same hand..while his other hand remained in his pocket..i dont advise doing this with alternating currents..since even a minor voltage can upset your hearts biorythyms and cause it to become irregular..which is bad..you then have to go to the hospital so they can refibulate your heart..always apply common sense when using electricity and stand on a rubber mat..wear insulated electrical rated gloves and test circuits to see if they are &quot;live&quot; ..with a volt meter. Remember..volts do the work when current flows and resistance is present ..high amperage is bad for the body..but pulsed current even at low levels can stop your heart..play safe my friends!</p>
<p>If you are using a 7kV power supply how can you use 4 kV capacitors? Or are you just taking the risk of blowing them out?</p>
<p>Why do you need resistors? Wouldn't they just increase the time needed to charge the capacitors?</p>
<p>They do increase the time, but if they weren't there the circuit would short itself out when it discharges. One possible way to overcome that though would be to use high-power diodes instead of resistors, but they are a lot more expensive than resistors.</p>
<p>Could someone please tell me, what are the red and black wires connected to?</p>
<p>may i use full wave Cockroft-Walton generator for this...?</p>
<p>some body tell me perfect technique .......to make HV impulse generator of 100KV ...</p>
I was thinking about using two aa batteries which feeds into a fly swatter circuit board creating an output of 3.5kv (from one source). Would I still be able to use the same capacitors and resistors as this example and would I get a fair arc out of it? Thanks
<p>I didn't know the resistor value at the moment of buying, so I bought 33 ohm ones. what could go wrong if I put them?</p>
<p>can we use electrolytic caps??</p>
you can, but you will need some diodes as well to prevent them form discharging into the power supply. I believe this is called a cockroft and watson cascade but please don't quote me
<p>Is it possible to use a flyback driver (with a lower mosfet, say 60 v) to power the main one, because i have 3 flyback transformers an 0 capacitor banks for the power supply.</p>
<p>Cool!</p>
<br> Can this really harm you? The idea that a special number of voltage or amperage will automatically kill you is not accurate.<br> <br> Scuffing your feet across a carpet and touching something metal also produces thousands of volts and large currents, but it obviously doesn't harm you, because the capacitance is small and the spark is very short-lived. Yes, it's high voltage and high current, but the duration is less than a microsecond.<br> <br> I'm sure it hurts, but I'm skeptical that it would actually cause any harm. How long are the sparks in cm?<br> <br> 10x 1 nF capacitors charged to 7 kV store a total of 250 mJ. Scuffing your feet across the floor stores maybe 60 mJ max by comparison.<br> <br> &quot;The effects of electrical current passing through the human body are covered at length in the International Electro Technical Commission document IEC 479-2:1987. In this document it indicates that a transient or capacitive discharge, as is the case with static electricity, requires energy in excess of 5 Joules (5000mJ) to produce a direct serious risk to health.&quot;<br>
Okay, you made a very good point, can my marx generator kill? Very good question, personally, I will NOT touch it even if its safe. I never really understand Joules as they are many other units of energy related to it. Each capacitor (1nF) holds approximately 4kV to 5kV, how do I convert that to joules to see if its safe(ish) or not?
<p>the formula for joules is volts squared times capacitance</p>
<p>no, it's 1/2&sdot;C&sdot;V&sup2;</p>
I already did that for you, but I was using 7 kV. :) The <a href="http://hyperphysics.phy-astr.gsu.edu/Hbase/electric/capeng.html" rel="nofollow">energy stored in a capacitor</a> is given by 1/2 * C * V^2, so:<br> <br> 1/2 * 1 nF * (5 kV)^2 = 0.0125 J = 12.5 mJ<br> <br> Wolfram Alpha can do a lot of work for you:<br> <br> <a href="http://www.wolframalpha.com/input/?i=capacitor+stored+energy+5+kV+1+nF " rel="nofollow">capacitor stored energy 5 kV 1 nF</a><br> <br> Multiply by 10 and you have 125 mJ total, which is 1/40th of the energy that document says is the minimum that will hurt you.<br> <br> I'm not claiming that this thing definitively can't hurt you. I'm just skeptical that it's dangerous. Even if it's not harmful to health, the shock might still hurt like hell. :D<br>
Its not all about just the Amp or voltage its how it travels through your body if it goes in through your hand and out your elbow (just saying this way you'll see why in a min) all it will do is is give you some bad burns no matter how high either the Amp or Voltage is but if the same current goes in one hand up your arm across your chest and down your other arm it will travel through your heart which will stop it resulting in death. It also doesn't have to affect your heart to kill you it can go through your diafram(sorry cant spell) and your lungs stop working which will cause you to suffocate, if your an electrical engineer you should have learned that in first year I know in my first year we weren't allowed to touch any of the equipment until we did a report on the dangers of electricity and the rick of burns in the lab to show that we didn't just know about the dangers but fully understood them.
For another example, I'm looking at a safety test certification document for EN 60065, and they limit the maximum energy of a discharge to 350 mJ.
The total voltage could be 70 kV, which means the arcs should be able to jump <a href="http://www.wolframalpha.com/input/?i=70+kV+%2F+%2830+kV%2Fcm%29" rel="nofollow">about 1 inch</a>. Does that seem right?
<p>who says this procedure u jus mentioned (Scuffing your feet across a carpet</p><p> and ...) produces high currents???<br>currents than around mA value will shock u and more than 50 mA will kill u jus before u feel it !!!</p><p>and the tolerated amperage of ur body during the time is obtained from some equations expressed like the form: (i^2 * t) = cte (around 0.156 i think) so this fact that u mentioned doesn't hurt u cuz the values are lower than this equation. and ti is not related to the capacitance. there is a kind of a surge formation when u touch the metal with ur charged body. and the amount of current depends on the discharge resistance before and after its formation. which varies during the discharge time. so it doesnt hurt u cuz the values of volts and amperes are too low. and the idea that &quot;a special number of voltage or amperage will automatically kill you&quot; IS definitely ACCURATE. </p>
<p>&quot;who says ... Scuffing your feet across a carpet ... produces high currents???&quot;</p><p>People who have measured it. See <a href="http://www.wolfsonelectrostatics.com/04_news/index.html#current-and-time" rel="nofollow">http://www.wolfsonelectrostatics.com/04_news/index.html#current-and-time</a></p><p>&quot;so it doesnt hurt u cuz the values of volts and amperes are too low.&quot;</p><p>No, the reason it doesn't hurt you is because the *energy* is too low.</p><p>'the idea that &quot;a special number of voltage or amperage will automatically kill you&quot; IS definitely ACCURATE.'</p><p>No it's not.</p>
I saw on mythbusters that only a few milliamps across the heart will kill you.
But how much voltage do you have to apply to your body to get milliamps across the heart? And how long of a duration does the current need to last to kill you? if it's 10 milliamps for 1 nanosecond I doubt it will do anything.
WOW!! U sure R a expert on electricity!! where u got all those facts from??
I'm an electrical engineer. :)
<p>where is the schematic for the inverter you used</p>
Thanks for your instructable! Since I'm still learning, I'm not up on all of the abbreviations. Can you please tell me what 'RB' stands for? Certainly not Rhythm &amp; Blues....&quot;humor&quot; <br>Thanks!
<p>Rb = Ballasting Resistor</p>
<p>Hi, i've made a 5 stage Marx Generator, with initial voltage &plusmn;10 kV (hard to tell i can't measure it reliably, but it's a CRT monitor flyback).</p><p>After some experiments, all the resistors between stages blew out (my ohmmeter shows &quot;OL&quot;). In your instructable, you used 1M 500V 2W carbon resistors. I've choosen 1.8M 1W 3.5 kV metal film resistors. I'm not sure how this happened ;)</p><p>My ballast resistors (rated 10kV) are still ok.</p><p>Any idea, guys ? I don't blame anybody but myself ;) but some opinions are welcome.</p>
<p>SNAP... YAY sparks! :D</p>
<p>I made it,but i have only 2cm long spark why????</p>
<p>What sort of amperage and voltage do you put into it? I was hoping maybe an electric flyswatter would be enough for a really small one.</p>
I love this very cool and simple to build
About This Instructable
375,658views
782favorites
License:
Bio: &ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash; &quot;Energy cannot be created nor destroyed!&quot; &ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;
More by Plasmana:How To Build A Simple But Powerful Flyback Driver ZVS Flyback Driver - Video Close ups on electronics
Add instructable to:
