Step 6Check groove depth
Once the target diameter is reached, remove the pipe from the turning setup. Bevel the inside lip of the outer pipe so that the o-rings will slide into it easier. Clean everything before assembly. Put damp, folded pieces of paper towel over the end of the inner pipe and push them through the outer pipe to clean dust and debris out. Put both O-rings into their grooves, liberally lubricate everything, and check the fit.
Add Comment
