No worries, it's just Joe with a werewolf glove on. In this Instructable I will show you how I made the "haunted crate". Check out the youtube video (below) to see how it works!
Tools and materials I used to build this crate:
raw 1x6 cedar (I got it cheap at Home Depot because i chose all the cracked pieces)
1 x 2s
chop saw
router
screws
drill
watered-down latex paint (for aging the wood)
paintbrush
Tools for the "werewolf-oxygen-intake fan build:
12V fan
8x AA batteries
12V switch
3/4 spade bit
spray paint
Remove these ads by
Signing UpStep 1Measure and cut the wood
This part is quite straight-forward so I won't spend too much time on it - it's really just a box build at this point. First I cut the lengths for the front and the back of the crate. I moved on to the sides. I measured out and cut the lengths for the top. I left the bottom open.
To figure out the length of the two vertical 1x2s I laid the boards on the ground and added the board I was using for the top - with this measurement I cut out the vertical 1x2s for the front and back of the crate.
For the removable panel I figured out where my vertical 1x2s would be placed (offset from the edges by 11") and used the 1x2s to hide the seams. That meant cutting the panel out at 11 1/2" from the sides.
Cutting tip: when cutting with a chop saw the blade is 1/8" thick. Make sure the blade is on the "cut off" side of the material you are cutting or you will lose an eighth of your measurement. It might not seem like much but it only takes eight mistakes to lose an inch!
comments
Add Comment
l8nite
says:
damianzuch (author)
says:
Add Comment
