3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a "working" tricorder
Step 9Cutting the middle and bottom
 With the head and sides complete, we need to cut a middle and bottom piece to assemble the body.  The middle and bottom need to be slightly longer than the length of the head -- about 1/8 inch.  Cut two identical pieces out of the 3/4 pine.  The front and back plates of the tricorder are just a couple of pieces of 1/4 inch cardboard, so we need to reduce the thickness a bit.  The bottom plate is reduced by 1/4 inch on each side, so it ends up about 3.25 inches deep.   I used a bit of inexpensive 5/8 inch aluminum towel rod as a crossbar, so the middle plate is reduced to 2 5/8.   Use the leftover bits as glue blocks.  Test fit with the head and then glue up.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jcohen
