Have you ever been to the lake to watch the guys with the Chris Craft or Sail Boats? They're sitting around talking 90% of the time. Why aren't they running their boats more? Because the batteries only last about 20 minutes. So, if they spend a few hours at the lake they really only running the boats a fraction of the time (I know because I built a Chris Craft). So, here's what I made so I can have my hands on a controller the entire time I'm there.
This boat has absolutley ZERO batteries.
You'll need to buy one of those up coming popular Solar Attic Fan kits. It comes with the solar panel and a fan. You won't need the aluminum fan blade or shroud but you'll use everything else. I got mine on ebay for under $100
You'll also need basic RC electronics such as a matched radio and receiver, ESC and a servo. These are all things the typical RC modeler and model store have on hand.
Remove these ads by
Signing UpStep 1Easy Build
also I would like to ask that is it better to place propeller half immersed in water or fully immersed??
and what about the propeller...I mean...propeller with 2 wings are better or the one with 4 wings??
Thanks
A propeller is for aircraft, boats use screws
On the terminals,One is positive and One is negative(No durrr),The one with Positive changes to negative and the one with negative changes to positive,IT repeats this process at 60 Hertz,Thats what AlternatingCurrent Means.
Now,These motors have so spin in the same direction no mater what polarity is recived,If you hook it up to a battery they will spin,If you hook it up in reverse they still spin,in the same direction,And DC Motors,Direct current,The polarity is always the same,And If you feed it AC electricity what happends,Nothing!,It will Only vibrate,Due to the Current Alternating,The Electricity.
1.6 Amps is about the 1.5 of a standard remote control car,they are usually 900MAh If it is 1000 Mah,Or 1 Ah ,If you draw 100 Miliamp Hours,It will work,for 10 Hours,If you draw,1000 Miliamp Hours,It will last,1 Hour.
If you draw 20 miliamps it will last,1500 Hours,about the current a standard LED will draw,And that is about,A week and then Some.
Ahem...
I Will start a project on the Boat,But How Fast does yours go(MPH?)
ignore "recreate" he/she does not know what they are talking about and just makes a fool of themselves.
prabbit22m has some good info in the long paragraph response so its worth a read.
http://www.solarbotics.net/library/circuits/se_t1_mse.html
