Step 10How Fast Can It Go? ...and A Safety Reminder.
CD's will explode when over-revved. This includes any RPM over 20,000 rpm. It is unlikely that more than a couple thousand rpm will be achieved by ordinary water pressure. (1400 rpm was max with my last test on water pressure).
But, again, I must stress that this innocent-looking machine becomes a screaming demon when powered by high air pressure. The CD Turbine, with 120 psi straight air pressure, will easily exceed 20,000 rpm and will violently explode the CD's in the Disc Pack. Not maybe...it will for sure. Don't use air pressure unless you are completely aware of this!
I use an air pressure regulator, digital tachometer, and a bullet-proof enclosure for high-rpm air pressure testing. And all the usual self-protection gear for dealing with sharp shrapnel.
So, be careful, wear protection and have fun!
Oh, by the way, the CD Turbine, with the plain Disc Pack has gone 14,500 rpm on half-throttle compressed air, smooth and safe!, and 11,000 rpm for the Magnetic Disc Pack. So far, so good!
I'll show more secrets in the next Instructable of the amazing Tesla CD Turbine.
UPDATE: see my latest instructable for lots more CD turbine fun, with the new Kitchen Sink Model.
What happens is, if the turbine is working properly, even 15-20 psi is enough to send the discs over 10, 000 rpm. With excessive rpm, the CD discs can fracture, and sharp shards come through the side of the case, with possible injury or death.
I have taken turbines up to 14,500 rpm, but they will usually break before that. The magnet spacers limit the max rpm. Plain CD discs go up to 25,000 rpm before exploding.
The CD case itself can take up to 120 psi without exploding...as long as it is somewhat gradual. I did blow up one turbine by too rapid of an increase in pressure! ( see "Tesla CD Turbine Blender Bursts On Kitchen Table", http://www.youtube.com/watch?v=EXo3e58rZ7U )
CD discs with magnets are limited in rpm to about 8000-10,000 rpm. Even then, the disc could shatter at any time.
Cutting holes in the discs could lower the safe rpm even more.
When a disc blows at 15,000 rpm or more it literally explodes and sends sharp shards in all directions. See this site, "The Case Of The Exploding CD-ROM Record",
http://www.qedata.se/e_js_n-cdrom.htm
Another helpful hint...When building a turbine case or parts use polycarbonate or aluminum or steel, etc. Don't use acrylic. Here's why: http://www.youtube.com/watch?v=Hsls5ZPCUnE
So, the idea is to keep the revs down and play safe with protection. New materials such as carbon nanofiber ceramic for discs, and lighter, stronger magnets will soon make the magnetic Tesla Turbine a greater reality.
http://www.instructables.com/id/Tesla-turbine-from-old-hard-drives-and-minimal-too/
http://www.instructables.com/id/Build-a-15%2c000-rpm-Tesla-Turbine-using-hard-drive-/
The paper discs should be stiffened by using something like Crazy Glue, or they will simply move to the side when high-pressure air from the nozzle hits them. They will not withstand high rpm's like a CD, and would be hard to balance.
Note that CD's are dangerous at high rpm, especially with magnets attached like I do. You MUST have a polycarbonate (bullet-proof) case, or a steel enclosure, to run a Tesla Turbine at high rpm. That's why I recommend water pressure turbines for most folks.
The Tesla CD Turbine is a pressure turbine and requires a minimum of about 20 psi pressure at the nozzle before it can begin to do any functional work. 80 psi would be best.
You won't be able to get enough pressure with a downspout, unless it was several stories high. (approximately .5 psi per foot of elevation.) Same goes for the river...You would need a 30-40 foot vertical height of water (*head") just to get things going, 100 foot vertical for decent performance.
More discs will provide more torque, but fluid velocity is the most important factor.
Same problem with air...lack of pressure. Making a cone won't increase it much...You would have to come up with a system that increases pressure for part of the fluid, while utilizing the lower pressure to do so. A Ram Pump does this for water, for example.
I get magnets from this link at K&J Magnetics
I can't see spinning a metal object creating a magnetic field in itself, but if a metal object is spun in a magnetic field, it can behave as if magnetic. And a spinning magnetic field like the CD Turbine can cause a metallic plate such as a pie plate, to spin. What happens is there are eddy magnetic currents formed in the plate from it's interaction with the turbine magnets, pulling it around.
We tried a CD disc in the following movie and it didn't spin in the magnetic field of the turbine. I tried it later and was able to get a very slight spin effect. The foil is very thin!
See this video.
However, have a look at the picture below, and visualize string wrapped around the coupler on top of the turbine.
The string goes out horizontally to a small pulley, say attached to the back of a chair, and from there down to the floor.
At the floor the string can be attached to a bag with coins or weights for "ballast", to be raised by the turning of the turbine.
The radius from the center of the coupler to the string wrapped around it, is multipiled by the bag weight to get inch-pounds (or inch-ounces) of torque.
