Step 11Cool CD Turbine Movies
The first video is an overview of the basic faucet-powered CD Turbine and levitating Magnetic Coupler.
The second movie is of some unusual movement of a rotating ball magnet influenced by the turbine.
The third movie is the creation of a beautiful vortex by the magnetic coupler. Enjoy!
Additional water pressure will increase the turbine power and rpm's sufficiently to drive the alternator properly.
The engagement mechanism you mention might be useful if the turbine was tuned for maximum torque at a specific higher rpm, but usually there would be no advantage (other than flywheel effect) to "spinning up" the turbine first.
As a mechanic, I've been around alternators for 40 years. Your comments are right on. I applied power to the field wire as you suggested.
The main problem of not generating power was getting the shaft to spin fast enough. The rotating/rolling resistance of the alternator took up most of the energy output of the turbine, while running it at the relatively low pressure of 30 psi or so.
So rpm's are very limited unless pressure can be increased significantly.
Actually, if your a mechanic, i have an unrelated question. I made pans for an engine a while ago that runs on both diesel and gas using (compressive detonation). I want to make a prototype, but i need to know how much PSI will be generated at TDC right after the plug has fired with the throttle open fully. do youk know within a hundred PSI what that might be? :/ Thank you.
Excellent I was wondering if that was possible.
Ah, well I hope you find a more successful setup!
