3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build an Amazing Tesla CD Turbine
Step 2Design an Inlet Nozzle for the CD Turbine
  • last photo ←
This is where the rocket scientist in you comes out...what size, shape and angle inlet nozzle should the CD Turbine have? There will be many theories, but the facts are... WHATEVER WORKS!
I have tried several different types and materials...they all worked. There's room for experimentation here. You just need to taper down to about a 1/8 inch hole into the side of the CD case with pipe fittings, or plastic pipe, then hot-glue it all in. ( Pictures in following step.)
I used an Orbit WaterMaster Extension Nozzle Model 91129 from Home Depot for the Tesla CD Turbine II nozzle. The Orbit Nozzle has an advantage of being able to use a long 3/4 inch PVC or ABS pipe with the included fittings. One fitting is a tapered nozzle, and was originally used for burrowing under concrete sidewalks with water pressure. The other fitting connects easily to the garden-hose Shut-off Valve. A 2' piece(or longer) of PVC connects the two Orbit fittings.
Note: Brass fittings and copper pipe could be used for more of a steampunk look.(future instructable!)
A Later Note: My newer instructable makes the nozzle install process much easier!
2 comments
Aug 3, 2011. 3:38 PMmexiquinn says:
could you use a water balloon nozzle
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
235
Author:mrfixitrick(Mrfixitricks Youtube Channel)
I am re-inventing myself as an inventor, after too many years as a mechanic! I enjoy learning from Tesla disc Turbines, magnetic motors, and Crystal Quantum Radios. "All children are artists. The ...
more »
