3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build an Amazing Tesla CD Turbine
Step 7Assemble The CD Disc Pack
The CD Disc Pack is the rotating part that is made of CD's. It spins inside the CD Case. There are several options for CD Disc Packs.
The easiest thing to do, is...nothing! That is, just stack the CD's on the spindle post without gluing or using magnets...about 10 CD's in this case. You can use more CD's if the CD Spindle is taller.
Disc Packs can also be built by simply gluing together discs with a few drops of Methyl Chloride (available at a plastics shop). Methyl Chloride is the solvent glue for CD Disc polycarbonate-type plastic. Put the glue on the raised ring, which you can feel near the centre of the CD, to bond each CD to the next. The glue sets fast. Try to keep the Discs centered on the Spindle as they are glued together. A couple of wraps of paper around the Spindle to take up clearance before gluing the discs might help keep the Disc Pack aligned best.
Let the glue set-up and get ready to assemble and test your Tesla CD Turbine!
Install the recently modified CD Case (with Cover and Nozzle) onto the CD Spindle and Disc Pack. Make sure the Disc Pack spins freely on the Spindle and in the CD Case. Hook up the water pressure supply, adjust the water pressure with the Shut-Off Valve, and the CD's should start to go around!
The speed of the CD Disc Pack is dependant on the water pressure, controlled by the garden hose shut-off valve. It should be able to go over 1200 rpm on garden-hose water pressure.
Welcome to the wonderful world of the Tesla CD Turbine!
20 comments
Feb 16, 2011. 9:19 PMskibum97 says:
My science fair partner and i are working on the tesla turbine and we were just gluing on the magnets with Methylene Chloride and we waited for a couple of hours but it still wasnt sticking, they came off when we tipped it up on edge.
How would you go about getting the magnets to stick?
Jan 1, 2011. 8:50 PM______ says:
can you cut noches into the cd? to increase speed
Jul 7, 2009. 11:13 AM11vs11 says:
Ok that’s sweet I’m sorry that my questions are so sporadic, just that I’m flat out with study wish I’d gotten into engineering now L; (It is also interesting to me that am I correct in thinking that salt increases the boiling point of water therefore some kind of change in rpm should be expected, yes?) What I really want to know is how exactly would you convert the spin of this type of turbine, but let’s say bigger maybe a 50cm (radius), into energy for the ordinary grid or power battery? (Please don’t tell me magnets because there must be a better way and what would be more efficient for getting good psi from steam; concave mirrors or a focus lens?)
Jul 7, 2009. 11:07 AM11vs11 says:
Ok that’s sweet I’m sorry that my questions are so sporadic, just that I’m flat out with study wish I’d gotten into engineering now :( (It is also interesting to me, am I correct in thinking that salt increases the boiling point of water therefore some kind of change in rpm should be expected, yes?) What I really want to know is how exactly would you convert the spin of this type of turbine, but let’s say bigger maybe a 50cm (radius), into energy for the ordinary grid or power battery? (Please don’t tell me magnets because there must be a better way and what would be more efficient for getting good psi from steam; concave mirrors or a focus lens?)
Jul 2, 2009. 1:02 PM11vs11 says:
Hi, am just wandering how would salient water would contribute to the spin seeing as EC is increased with increase in water salinity. I mean obviously it would mean the salt water would eventually eat through the glue but thats besides the point.
Jul 3, 2009. 9:12 AM11vs11 says:
Are these the types of turbines that are employed in solar radiation harvesting? if not can they be and what would the conversion factor be between steam pressure and electricity output be?
Jan 20, 2009. 6:39 PMTanners says:
so for the pack were you glue em all together there wont be any space in between the discs right? so its pretty much just a cylinder?
Jan 20, 2009. 9:38 PMTanners says:
yea so i just tried building it using penny's as spacers and used super glue to glue it all together and it worked pretty good.... for a while but the top disc broke off and then it all didn't work so I'm going to rebuild it this weekend because I'm building it for school and this project is due next Monday due you have any suggestions for what i could use as spacers that i might have lying around or could pick up at longs or homedepot or do u have a suggestion for a type of glue. i would use magnets but i don't have a lot of money and i don't have time for them to ship. thankyou
Feb 22, 2009. 3:51 PMPKTraceur says:
Actually, dimes are created using 5 cents if matreial, whereas nickels use 10 cents. Weird huh?
May 19, 2008. 3:30 PMastrozombies138 says:
I just got my magnets, wow their a bit smaller than i originally thought, so its ok if i dont glue the magnets on or anythingi just just put them on the cds? or should i glue them in place?
May 20, 2008. 9:25 AMastrozombies138 says:
awesome, im gonna be using a loctite marine epoxy, as soon as i get you approval for it to work, until then im just going to try some test runs without the glue. thanks for all the help so far too :D
May 26, 2008. 11:54 AMastrozombies138 says:
wooo, It's working great! Ill upload a video now.
Jan 4, 2009. 10:58 PMMr. Twist says:
ooooohhhhh i hope to be part of that club to. I'm building mine right now but it won't be as good as any of for because 1. I have a very small amount of time 2. I dont have very many tools (my dad isn't much of a DIY guy) all i have is a leatherman knife and a glue gun but I hope it works out ok. I talked to you before asking you about it as a science fair project and the fairs coming up.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
235
Author:mrfixitrick(Mrfixitricks Youtube Channel)
I am re-inventing myself as an inventor, after too many years as a mechanic! I enjoy learning from Tesla disc Turbines, magnetic motors, and Crystal Quantum Radios. "All children are artists. The ...
more »
