3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build an Analog Electricity Usage Meter
I have used a Kill A Watt (http://www.p3international.com/products/special/P4400/P4400-CE.html)  electric meter for a while and I decided to build  an analog one. This project went from being simple, with a single panel ammeter and an outlet, to full scale with three meters, a lamp socket, binding posts, and switches for all the outputs.
I also decided to pay attention to the aesthetics of this project and build one that had a steam punk look.
Rather than simply mount the plastic meters I decided to remove the movements and reassemble them in a wooden case and make my own numbers for the meters with a piece of tea-stained paper and an old typewritter.
From Simple to Complex
The basic design requires only 4 components. A cord, an outlet, a volt meter, and an ammeter. My design is more complex because I have two ammeters and three outputs, each with an independent switch.
Volt meters are connected across, where the current travels and ammeters are connected through the path of the current. (See picture two)
The idea of using a steam punk aesthetic meant that the plastic gauges with pre-printed backgrounds would not work. Thus it was necessary to disassemble each one and rebuild it in the new case. Avoiding this step and mounting the panel meters intact will save a considerable amount of time.
Other Design Ideas
One idea is to use an economy multi meter, often available for under $10. It would not be difficult to build a small case, add a plug or a cord and an outlet, and wire the system together. This would be considerably simpler and less expensive.
One important consideration is that to measure volatge you must connect the meter across and to measure amperage you must connect it through.
Measuring Wattage
Measuring wattage directly requires expensive laboratory equiptment. Since W = V*A most devices measure voltage and amperage and multply them together. One idea would be to have the needles of a volt meter and ammeter overlap. The wattage could be read at the point where the needles cross.
The simplest answer is simply to have a multiplication chart with the rows being 110, 115, 120, and 125 for the volts and columes of 1-15 for the amps.
Step 1Materials
Materials
Case:
1-  1/2" thick board 12" X 10-1/4"
4-  3/4" thick boards 12" X 2-1/2"
1-  3/8" thick plywood 12 X 10-1/4"
Electrical Conponents:
Meters:
-- 0-150 V AC volt meter (http://www.allelectronics.com/make-a-store/item/PMA-150V/150V-AC-PANEL-METER/-/1.html)
-- 0-5 A AC ammeter  (http://www.allelectronics.com/make-a-store/item/PMA-5A/5A-AC-PANEL-METER/-/1.html)
-- 0-15 A AC ammeter  (http://www.allelectronics.com/make-a-store/item/PMA-15A/15A-AC-PANEL-METER/-/1.html)
Other:
3 on/off two position toggle switches ( at least one should support two circuts)
1 on/on two position toggle switch
1 porcelain lamp socket
1 circular outlet (recommend using a connector used for repairing an extention cord.)
Hardware
2- 1" brass hinges with screws
4- 2" brass screws with matching nuts and end cap nuts
1-  length of brass tubing that the shaft of the 2" bolt will fit into but the nut will not. This will be cut to make spacers.
2- 1" brass bolts with nuts and knurled knobs that will work well as thumb screws.
23 comments
Dec 27, 2009. 8:44 PMScubaSteve says:
can you make one that measures from 10-15 volts?
Oct 18, 2009. 1:47 AMstatic says:
Allied Electronics carries 3.5" round meters but you would have to spend nearly $200 to duplicate what you have here. Wrapping the  clear meter face cover in a  flush fitting bezel would clean up the appearance a lot. devising a slide rule like apparatus to calculate the power, mounting it in that unused space near the bottom may give it a more of an old tech appearance.   In the event you decide to add a bezel semicircular tops over the scales would add to the old timey look. Man that wide carriage typewriter looks bizarre, I guess there was need for landscape printing way back.
Oct 17, 2009. 2:27 PMBadMonkey63 says:
Really cool!!!!!
Went and got all of the components and going to build now!!!!! Keep it up !!!
Oct 16, 2009. 11:30 AMTrigger_Happy says:
I love the typewritten meter labels - It looks like something from the museum of mad scientists!  :-)
Oct 10, 2009. 11:58 AMRe-design says:
Hey, I've got that same table saw.  I filled the gaps in the cast iron table with fiber glass reinforced bondo and sanded it down flush.  Now I don't pinch my fingers in the hole when I move the fence.
Oct 12, 2009. 3:26 PMRe-design says:
Absolutely the gaps in the table not  the t-slots.  I know what the t-slots are for.  The gaps in the table I assume are for lessoning the weight of the table and to use less stee.  They are just a the right spot for me to rest my hand when I'm moving the fence or on the other side moving a piece of wood and had caught my thumb or finger several times and got really tired of doing that and fixed my table.
Oct 11, 2009. 10:27 AMaaon says:
Those gaps are for attachments to the table saw. However, to each his/her own.
Oct 11, 2009. 11:04 AMRe-design says:
What can you attach using them?  Maybe I'm missing out on something that I don't know about.  I can always use a new tool or accessory.
Oct 11, 2009. 11:37 AMaaon says:
I have made a bunch of custom ones myself: holding formica down so it doesn't chip, cutting angles other than straight cuts, material holders. However, I own a delta. Google returns tons of "table saw" accessories.
Oct 10, 2009. 8:43 PMDougBishop says:
beautiful project just an old mans thought When you attach a wire to a mount tab with a screw, like on a switch, you should twist the wire together and solder the end with just enough solder to "tin" the end and hold all the strands together. This will prevent a loose strand from straying into a position where it should not go, the possibility of the magic smoke being released from the wires is greatly reduced.
Oct 10, 2009. 6:45 AMz0rb says:
 You might want to factor in the formula of W = V * I * Cosign of the phase angle of your resistive to inductive loads. That will give you a true power figure for AC circuits. :D
Oct 9, 2009. 10:04 PMkmpres says:
I'd wager your typewriter is worth much more than your project, though I like your project, too.  Well done, and with a taste for style.  A few tips: If you use good 60/40 rosin core solder and not too much heat on the heat-shrink sleeves you'll make better connections without burning the insulation.  Sanding the corrosion off the wire ends before soldering helps too, especially on salvaged wire.
Have you thought of using 270 deg meters like those used in the 1950s sci-fi classic, Forbidden Planet?  I'd love to get my hands on a few of those.  You could combine your salavaged dials with the 50s sci-fi flashing lights --- sort of retro-future steam punk...
Oct 9, 2009. 6:46 PMKronoNaut says:
I like this very much.
One safety thing:  Since the binding posts are hooked up to 120 volts, I would make a removable cover for them.  Even with them being switched, there is the off chance of brushing against them when they are switched on.
Oct 9, 2009. 3:10 PMknife141 says:
Nice project.  Well executed, and it has nice style.  I REALLY LIKE your wide carriage typewriter!!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:pribich
