loading
Step 3: Cut and Glue Pieces
Cut the pieces out of the 1/4" poplar using a laser cutter.  You may need to experiment to get a good cut without too much burning.  I recommend doing multiple passes (took my 45W laser 6 passes) with a 0.05" Z-offset on each pass.  If doing it without a laser you can use a table saw jig to cut the fingers with a few tweaks.  The rest of the shapes can be cut with a bandsaw or tablesaw, and a scroll saw for the intricate parts.  Replace the hexagonal hole for the 1/4-20 tripod nut with a simple round hole and just fill with epoxy.
Something I should have done before doing all the gluing is drill a 2mm deep pocket for the retaining rings to sit in. Use a 1/2" forstner drill bit.  See Picture 5.
The finger joints fit together really easy so all the joints can be glued and clamped easily.  Cut three 2.56" long pieces of 3/8" dowel and sand down 1/4" of the end of the pieces so they fit in the spool holder with the flat-sided holes. See Picture 4.
Glue the spool holder with the round holes goes on the bottom side of the box lid, then glue the dowels into the holes and glue the other spool holder on top.
<p>Great project. Thank you very much for sharing.</p><p>I have a question.</p><p>on your design PDF, numbers (sizes) are written, such as 90.0000, 98.0000. What are their unit?</p>
Sorry, those are millimeters.
I'm having a hard time printing out the exact ratio for the wood box portion. Do you have the measurements for the box frame?
Can you be more specific? The overall dimensions are in the images on Step 2, you can also make all the measurements you want from the DWG file supplied on the same step, using AutoCAD or a free DWG viewer like http://usa.autodesk.com/adsk/servlet/pc/index?id=6703438&amp;siteID=123112. <br><br>Hope this helps.
so very nifty! simple (as it were) and elegant!
wow man roll another fattie! <br>seriously <br>very cool
Beautiful!
It appears that the acrylic added some reflections to the image that may or may not be wanted. Would it be possible to replace the cylinder with a geared disc, in line with the film edges? Also, the full surface contact between the film and the acrylic will lead to scratches. <br> <br>If the cutting is done with anything but a laser, the precision involved in this project would require a good deal of sanding for alignments.
You are right about the reflections, and I'm not positive about what you are saying about a geared disc. I have since made some changes which I will add to the Instructable once I have confirmed them to actually be better. I am no longer using an acrylic tube not because of scratches or reflections, but due to the immense friction it created making it difficult to advance the film. <br> <br>Also, finger joints aren't exactly necessary, the camera could be built with the wood edges glued simply. My first pinhole was like that and it worked fine.
Totally awesome project! Although I am fairly certain digital photography has already taken over ;) <br>
I'm fairly certain I like film better ;)
Beautiful work! <br> I LOVE all you folks who share about making and using Pinhole cameras. <br> <br>I personally believe they are an underutilized tool in education, useful across fields of art, science, engineering, reasoning, and naturally fascinating for children - to engage them across all these areas, getting their hands on stuff, even in poorest material environs. I have it on my long-term list to assemble such camera-making info + natural photo-reactive media for eco-friendly picture-making-recording - albumen, citric acid, tin (eco?) photo reactive. <br> <br>Greg
Thanks, I agree, people need to be taught about pinhole cameras because of the educational value. Its a great way to study optics and light.
What is a anamorphic images!?
An anamorphic image is any image which is optically distorted. In this case, the distortions are caused by the film being wrapped in a cylinder instead of laid flat like normal.
Design and execution is absolutely brilliant. But I can't help thinking that if you'd put a bit more into the external finish, you'd have a camera that looked like a fine instrument. A few coats of sanding sealer and some time with sandpaper before you put on the varnish would have really paid off.
Very nice work! Love both the camera and the shown result!
Instead of having the acrylic cylinder fixed in place, you could have it so that it rotates along with the film when you advance it. Ok, it's a lot of fiddle to do, but it should overcome the friction problem.
You're right, but the mechanics of that kind of solution would be difficult, especially since at one end the pinhole cannot be obstructed in any way.
nice one.love the wonkee pics. plastic tube a supprise. could you tell me a little more about the lazer cutter?
The laser cutter I used is a Trotec Speedy 300, and is about 45 watts. Cuts this material at 100 power 0.9 speed and 6 passes, -0.05&quot; Z-offset per pass. With another machine experimentation will be required but many passes and Z-offset on each pass helps prevent the wood from heating up too much and charring.
Cool,Cool,Cool,Cool,Cool, project! Excellent instructable!
Glad you liked it!
Magnific work, Matt.
As always, thank you!
About This Instructable
38,390views
220favorites
License:
More by mattthegamer463:NASA Worm Logo Sign - Inspired By Tom Sachs DIY 6x17 Panoramic Film Camera Pentax Spotmeter V Repair
Add instructable to:
