3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build an Atari Punk Circuit on a breadboard
If you're old enough to remember the Atari, then you probably remember all those "high tech" tones that it produced.  Those beeps and whines were the very lifeblood of our favorite old school games.  While a mint condition Atari may be hard to find these days you can easily recreate the sounds of an Atari using only a few parts stuck on a breadboard.
The Atari Punk circuit gets it's name because it produces similar sounds to the old Atari game systems.  This design has been around since the 70s and often still goes by it's original name of a Stepped Tone Generator.
In this guide I'm going to run through how to make two different Atari Punk setups on a breadboard.  One that uses variable resistors to control the sounds (turn style knobs) and one that uses light sensitive resistors (CDS Cells).
Step 1Parts
Parts
The parts you need for this setup are rather common and decently cheap to buy.
Required Parts
Breadboard
Jumpers (You can make your own)
9V Battery
9V Battery Clip
556 Timer Chip (You can also use two 555 timers as well)
8 Ohm Speaker
1K Ohm Resistor
(2) 500K Ohm Variable Resistor (Potentiometer)
5K Ohm Variable Resistor (Potentiometer)
(2) 0.01uf Capacitors
Optional
(2) Light Sensitive Resistors (CDS Cells
(2) 0.22uf Capacitors
Blue LED
470 ohm resistor
Total Time: 20-30 minutes
Total Cost: $10 (More if you need a breadboard)
The optional parts are used if you want to make the circuit light sensitive, or if you want to add an LED for fun filled lighting.  You could also ditch the 5K Ohm Variable Resistor and use a set resistor, but then you'd have no volume control.
Alternately you could always have one Variable Resistor and one Light Sensitive Resistor in the circuit.  The nice thing is you can easily swap both types in and out, which is the nice thing about a breadboard.
Most of these parts can be found at any electronics hobby store.  If possible, avoid Radio Shack and you'll pay three times as much as you really need.
All Electronics and Electronic Goldmine have most everything you need.  If you'd like to save yourself some trouble and get everything in one nice little kit, why not try my fun filled website BrownDogGadgets.com.  We have a ready to go Atari Punk Kit that even comes with some fancy knobs to impress your friends and family.  72% of all sales go to all natural doggie chew toys.
12 comments
May 1, 2012. 7:31 AMalexwu2211 says:
would it still work if I tried hooking up a MP3 instead of a 9V battery?
Mar 16, 2012. 8:47 PMpfred2 says:
Here's a real blast from the past. The first time I made a similar circuit I had to use 2 555s because either the 556 didn't exist yet, or Radio Shack didn't stock them. That was all back when Atari was just getting in business. I'm pretty sure Atari just divided the video oscillator to make their noises back then though.
Having made an awful lot of circuits like the one here I'll add that I always thought it sounded best if I used polystyrene capacitors with it.
I should dig up the schematic for this if you like photocell noise makers:
http://i.imgur.com/aMhhJ.jpg
It is fun to leave in a refrigerator, then when someone opens the door and the light comes on it howls at them. But it does vary in pitch depending on the intensity of the light that hits the photocell. A single cell battery went between the two copper plates to the left, then a speaker hooked up to the two wires in the middle.
Feb 8, 2012. 8:57 PMshaikhanwarali says:
Thank you so much for giving us full info...
Feb 3, 2012. 4:40 AMt.11 says:
Just used this to build my first APC and all it took was one exploded capacitor!! (don't ask, I really don't know) so thanks immensely!
Jan 24, 2012. 8:20 PMTobaTobias says:
Great project, if Im using the two 555 How would I connect the volume pot? Plus, I am not using a speaker.
Jan 27, 2012. 2:15 AMUgifer says:
I must try this - looks a great project.
Only issues is it might be a little redundant - I still have my original Atari! It now plays through a 42" LCD TV, but it plays (& sounds) just as good as ever!
Dec 9, 2011. 10:45 PMisaac583 says:
Thanks for the easy instruction and great photos. The pictures really made this project easy for a newbie !!
Dec 8, 2011. 6:14 AMjessyratfink says:
Great photos. :D
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
160
Author:JoshuaZimmerman(BrownDogGadgets)
I'm a middle school science teacher in Milwaukee, Wisconsin. I like making random things and then teaching my students how to do the same. I also run a little website where I sell some of the things...
more »
