www.pondplantgirl.com/coldframe.htm Here is how you can build your own home greenshouse for under $25.
The main pic is a larger version of the 5x5 Greenhouse. See the actual 5x5 image below. For more pics and info please see my website at: www.pondplantgirl.com/coldframe.htm
HAPPY PONDING!!!
See more videos at: www.pondplantgirl.com Step 1: Supplies Needed
4 sections, Total Cost about $8.00
- 1/2" Corner Elbow Connectors
4 with 3 ports
4, Connectors + Adapters total cost about $4.00
Total cost about $5.50, Borrowed cost = $0
I had scissors - my cost $0
My cost $1 from the dollar store
Borrowed - My cost $0
- Visquene or Plastic Sheeting
6' x 6', 3.5 mil (6 mil is ideal)
Thin clear plastic will not withstand past one season.
Box of 10' x 25' is $13.50, Cost per section roughly $7.50
Step 2: PVC Pipe
Assemble the pipe on a dry surface in a well ventilated area, such as a patio or driveway, and cut 2 of the 10' sections of PVC pipe in half, making a total of 4 - 5' sections of pipe.
Step 3: Assemble with PVC primer and cement
Swipe the inside of the elbow pieces and the ends of the PVC pipe with the purple primer. Do not swipe the inside of the threaded elbows.
After the primer dries, attach the elbows to the ends of the two 5' section of pipe with the PVC cement.
Attach the 10' section of pipe to the unthreaded end of an elbow with PVC cement and press down firmly.
Step 4: Here's your basic shape!
After the cement will dries within a few minutes, carefully bend the 10' section of pipe and attached to the other unthreaded end of the 5' section of pipe with cement. Leverage might be needed to bend the pipe, such as leaning up against a wall to prevent slipping while bending the pipe.
Repeat instructions for framing the other side of your greenhouse.
Step 5: Cut out the pattern for the end hoops.
Lay down the cold frame end on the plastic sheeting and cut out the end piece to attach. Be sure to leave at least 6 inches overlap. Allow for corners to be cut out in an L and pleat curve side. Only cut pleats about half way into the sheeting. Do not cut all the way down to the pipe line.
See pattern below.
The black is the assembled pipe
The blue is the outline pattern for the plastic sheeting
The green is where to cut the L corners
The red is the pleating. More can be made if needed.
Step 6: Attaching the plastic
Attach the plastic sheeting to the frame with zip ties starting with the straight edge. Be sure to tuck plastic around the pipe. Slice small holes through plastic close to the frame. I poked a few of my holes too far from the frame structure, but it still looks just fine. Pull ties tight and trim tails. Repeat all the way around the frame.
Step 7: Connecting the PVC
Screw in threaded adapters to threaded elbow end. Attach the remaining 5 foot sections of pipe to the adapters to complete the frame. If you want a temporary structure, do not glue the bottom of your greenhouse pipe together. However, you will need duct tape or cement blocks to brace the base of your greenhouse. If you are using it out in the yard, you can also anchor it down with camping tent spikes.
Step 8: Covering the frame
Cover frame with remaining plastic sheeting and cut to size.
Attach sheeting to frame ends with zip ties from top of frame to half way down. This will allow for access to the inside of your cold frame and will allow for airflow on windy days.
Edges of plastic sheeting can be weighed down with metal washers or clamped to frame.
Slice small holes in top of cold frame plastic to prevent rain water from puddling.
Step 9: Wow! That was easy!
A small cold frame greenhouse can be assembled in 1-2 hours. Cover your garden or pond to keep plants warm on cold winter days and nights!
Step 10: My Next Instructable
My next Instructable will be about how to build a snow country greenhouse and how to efficiently heat it with either solar or wind power. This picture shows heating with a dryer vent, which should only be used if put on a timer system.
If you have any questions or great ideas, please email me at gail@pondplantgirl.com!
HAPPY PONDING & HAPPY INVENTING!
:-) GAiL
In any case, I hope this might help.
BUT I have a question as I am not too familiar with the pvc pipe fittings. Why do I need the threaded adapters? It seems like you only used them for the bottom pvc pieces; why didn't you need them to connect the pvc that arcs across the top as well? Thanks in advance for clarification on this point.
can I use this model to start planting veggies/ flowers in Feb and March for next season or can I use to grow veggies year round?
custom home builder virginia
Also, is there a way to seal it air tight?
I want to make a carbon-dioxide hiyperberic chamber, as is it was in the pre-flood era (Yeah, I'm a Christian, and proud of it!)
http://www.genesispark.com/genpark/exper/exper.htm
If any one reads this, you'll know why I want to build one. Think about it! A tomato tree, that can produce over 13,000 tomatoes in it life-span!
To bad I can't have a warehouse sized one. *sigh*
(I hope I did the URL link rightATMOSPHERIC EXPERIMENTS)
Pondplantgirl... Loved the instructable. Thank you
plants can only use carbon dioxide whilst photosynthesising, during the night they use oxygen and release carbon dioxide. On this basis some old trees which don't do so much growing are supposedly releasing more carbon dioxide at night than they use in the day!
Anyway trees aside, if I'm right (and I think I am even though I didn't love biology at school), then you would not only need a carbon dioxide tent but also a constant supply of light, and you can't just seal in the carbon dioxide, the plants need a fresh supply as they will keep converting it into oxygen.
I don't feel any need to discuss religion in reference to this topic.
alive [əˈlaɪv]adj (postpositive)
They are not animate, but they are most certainly alive.
Also, if we are going to play the bible card, one might consider that Adam and Eve were permitted to eat of all the fruit in the garden save that of one tree. It doesn't say that they tore up the plants and ate them whole. Eating fruit doesn't kill the plant.
I won't question your faith, but let's not be piecemeal with the facts. A wound is not the same as death. Nothing biblical lends credence to the idea that plants are not alive.
We might also consider that a man (however devinely inspired) wrote Genesis, not God. Thus the details can at best be assumed only to have the accuracy expected of a historian. So no one is saying God lies.
Free will leads to the possiblity of inaccuracies, even if they are slight, as well as the option to add personal bias to the text. Especially when we consider how many revisions have been made to the original texts. Many different motives have had their effect on our current bible, we should do well to focus on the faith and not literal descriptions. After all, a good number of the terms and verses were incorrectly translated (possibly with intent).
Assuming even reasonable accuracy in our current bible (and I believe at least that much is true), God has given up all right or ability to control the actions of any human. That is your gift from your God, have faith in it and quite trying to tell people they are wrong for chosing a different route.
In conclusion: believe what you wish, let others do the same and last, but certainly not least, BE NICE. (It's in the ToS, lol.)
Hope this answer was enlightening...
The Vizqueen made a much easier installation, and less chance for error and thus ground water vapor getting up into and through the Concrete slab and into the building.
Vizqueen first became available [I think] in the late 60s or early 70s, and since then there have been many competing brands to become available.
Plastic vapor barrier usually comes in long rolls, and one cuts off what is needed. Due to multiple "fold-overs" the box in which the roll comes is only about 4 or 5 feet long. One or the other brand of vapor barrier can be obtained at most Home Improvement stores [Lowes, Home Depot, Sutherland's, etc.], many of the local hardware supply stores, and most lumber yards.
