Before making the guitar, I decided that it should be made from either found or very cheaply obtained materials. Most of the items I used were not originally meant for use in a guitar, I don't think I spent more then $50 for all the parts. It's not a dirt cheap guitar, but it wont hurt the wallet either.
Also, since I don't have any big power tool, I had to be able to make it in my kitchen using handheld tools i already had. (with the exception of the fingerboard which i had cut for me from from a scrap of plywood at a hardware store)
And lastly, I wanted to make this instructable because I wanted to share everything I learned, plus to give back for all the helpful guides I used for this project. There are lots of fantastic cigar box instructables on this very site, just do a search!
This project has a lot of steps, so i tried to divide it up in to logical sections. Hope its not confusing!
Here are some essential tools:
Dremmel (best tool ever)
different sand papers
couple of different files
coping saw
drill
lots of clamps
hot glue
epoxy
Remove these ads by
Signing UpStep 1The Body
Since the neck will be glued to the top of the box lid I first made a cut where the neck will go through. I cut it down with a saw and then filed it down.
Next I wanted two circular sound holes on either side of the guitar, this way i can run the neck all the way down the body. I also wanted to make the rims of the sound holes be metal. So i found a nice chrome metal pipe at home depot that had nice rims at the end. I cut those off with my coping saw.
I also want the option of this guitar being played electrically, so i will install a piezo pickup in a later step. But I have to make a hole for the mono jack. Since the jack is pretty short, i had to grind down the inside of the box were the jack will be installed. check the pictures for what I mean.
http://www.stewmac.com/fretcalc.html
Do you reckon it'd work if it was made out of metal? I was going to go an old cake tin for the body... would I get good sound or does wood have special vibratory propeties?
I've started a blog for my first CBG build here dirtyguitarguide.com
hope that helps
