Introduction: Build an Infrasonic Subwoofer
Infrasound is sound that is below your hearing threshold which general drops off at 20-30hz, i.e. lower than big booty bass. It can have a profound effect on your body, and should be experimented with carefully! Infrasound is used by the military as a weapon, or science to monitor earthquakes, whales ect.. In this instructable we will walk you through the process of building your own Infrasonic Subwoofer.
from wikipedia:
Infrasound is sound that is lower in frequency than 20 Hz (Hertz) or cycles per second, the "normal" limit of human hearing. Hearing becomes gradually less sensitive as frequency decreases, so for humans to perceive infrasound, the sound pressure must be sufficiently high. The ear is the primary organ for sensing infrasound, but at higher levels it is possible to feel infrasound vibrations in various parts of the body.
The study of such sound waves is sometimes referred to as infrasonics, covering sounds beneath 20 Hz down to 0.001 Hz. This frequency range is utilized for monitoring earthquakes, charting rock and petroleum formations below the earth, and also in ballistocardiography and seismocardiography to study the mechanics of the heart. Infrasound is characterized by an ability to cover long distances and get around obstacles with little dissipation.
Step 1: Speaker Cones
What is Qes?
http://www.bcae1.com/spboxad2.htm
http://en.wikipedia.org/wiki/Q_factor
Step 2: Step Two
Select a wood type. We chose 18mm plywood. This is probably the best material. Avoid Chinese plywood if possible because it is not as consistant. Plywood is very sturdy and holds up well the air pressure produced by the large speaker cones. You need enough wood to make both the box and the bracing structure. Each wall should be braced to handle all the bass. You should try to make the box as big as you can. We built ours to be 30" x 30" x 70" It should NOT be square. This will greatly reduce its ability to produce infrasonic frequencies low enough.
Step 3: Bigger the Case
We used a combination of wood glue, and as few screws as possible. The box should be airtight so each screw increases the possibility of air leaks and rattling. Then we used Kwik Seal to seal all of the corners and potential air leaks.
Step 4: Installation
Step 5: Electronics + Test, Test, Test
You will want to find powerful amplifiers. We chose two livesound amplifiers. Each channel was 500watt amplifier and switch to serial mode to which collectively made one amplifier a mono 1000 watt amplifier.
Once the cone works, then solder together the thick gauge audio cable, connect it from the speaker to a 2 channel Speakon wall-mount connector which we will insert into the wall of the speaker. This will enable you to unplug your speaker but also insert it into a larger live sound system. Then solder on male speakon connecters to thick audio cable and then connect this to your amplifier and add the compatible connector for your amplifier. For us, we used balanced 1/4" connectors.
Test all the wiring by running sine tones through the input to make sure all of your connections wokr.
Step 6: Cabling
Now once you have tested and solder together your cabling install l all the cabling, solder the speakers, cut holes to the exact size of the speakon jacks + corresponding panel. Then test all the wiring by running sine tones through the input again. At this point you may want to add wooden or metal handles to the side of the Subwoofer because its heavy and awkward to lift!! Ours was close to 70lbs.
Step 7: Seal the Connections
Step 8: Step 8
Step 9: Step 9
Step 10: Rock
Next crank it up but be slow about it to see how you react to the low frequency. A 15hz sine tone is a good start or even better a sliding tone from 60hz down to 10hz and then back up. From this you will be able to tell when your body feels it intensely and also how low the speaker will be able to reproduce a frequency. Enjoy but be careful!!
