Introduction: Build an Optical Theremin--Improve Your Snap Circuits by Adding a 555 Timer Integrated Circuit II
A theremin is a musical instrument that is played without actually touching the instrument. The original theremin used radio frequency interference caused by the movement of the player's hand to change the pitch of the instrument. The optical theremin depends on the intensity of light that falls on the photoresistor also controlled by the movement of the player's hand.
Currently there are no Snap Circuits sets that have the 555 Timer IC. So, you will need to purchase a 555 Timer IC from Allied Electronics or your favorite electronics supplier. If you don't have the Snap Circuits Extreme SC-750 set you can purchase the Snap Circuits Eight-Pin IC Socket block from C&S Sales. Adding these two components to your set of Snap Circuits blocks will allow you to create dozens of circuits built around the 555 Timer IC.
Snap Circuits is an educational toy that teaches electronics with solderless snap-together electronic components. Each component has the schematic symbol and a label printed on its plastic case that is color coded for easy identification. They snap together with ordinary clothing snaps. The components also snap onto a 10 X 7 plastic base grid analogous to a solderless breadboard. There are several Snap Circuits kits that range from a few simple circuits to the largest kit that includes 750 electronic projects.
All the kits include manuals printed in color with easy to follow diagrams to assemble the projects. The illustrations for each project look almost exactly like what the components will look like on the base grid when finished. Because the electronic symbol is printed on each electronic component, once the project is completed, it will look almost exactly like an electronic schematic.
Snap Circuits Parts:
1 Base Grid (11” x 7.7”) # 6SC BG
1 Eight-Pin IC Socket # 6SC ?U8
1 Press Switch # 6SC S2
1 100K ohm Resistor # 6SC R5
1 0.02uF Capacitor # 6SC C1
1 100uF Capacitor # 6SC C4
1 Variable Resistor #6SC RV
1 Whistle Chip # 6SC WC
1 Photosensitive Resistor # 6SC RP
2 Battery Holder (2-AA) # 6SC B1
3 Single Snap Conductor # 6SC 01
6 Conductor with 2-snaps # 6SC 02
3 Conductor with 3-snaps # 6SC 03
3 Conductor with 4-snaps # 6SC 04
1 Conductor with 5-snaps # 6SC 05
1 Conductor with 6-snaps # 6SC 06
1 Conductor with 7-snaps # 6SC 07
The above parts can be found in the Snap Circuits Extreme 750 set (I got my set from my local Radioshack store). Snap Circuits Parts can be ordered separately from http://cs-sales.net/sncirepa.html
Non Snap Circuits Part:
1 555 Timer IC # NTE955M This part can be ordered from radioshack.com
Optional Parts. I used these parts to connect my optical theremin to my mixing desk (reverb from guitar stomp box) to record the video:
1 1/8" to 1/4 adapter. This part can be found at Radio Shack (radioshack.com)
1 Snap Circuits Computer Interface Cable # 9 TLCI-73. This part is included in the Snap Circuits Extreme 750 set
The video of me playing the optical theremin follows below. Warning! Playing an optical theremin is harder than I thought it would be when I designed it. Be sure to watch the shadow of my hand as the shadow changes the pitch of the instrument.
Step 1: Insert the 555 Timer Chip Into the Snap Circuits IC Socket Block
The 555 Timer IC was introduced by a company called Signetics (later bought out by Philips) in 1972 and was designed by Hans R. Camenzind in 1971. The 555 chip has 25 transistors, 15 resistors and 2 diodes in an 8 pin DIP (Dual In-line Package) and looks like a square bug with eight legs. It has a notch at the top and Pin 1 is in the top left corner. (See picture 1) (Source: http://en.wikipedia.org/wiki/File:Signetics_NE555N.JPG)
The Snap Circuits Eight-Pin IC Socket block is picture 2 (source: http://cs-sales.net/eiicso6u8.html)
Insert the 555 timer chip into the Snap Circuits Eight-Pin IC Socket block. Make sure that the notch in the top of the 555 timer chip is aligned with the diagram of the chip pictured on the IC socket block. (See picture 3) (Source: http://www.snapcircuits.net/learning_center/designer)
Step 2: 555 Timer IC Pins
The following are the pin outs for the 555 Timer IC (source:
http://www.markallen.com/teaching/ucsd/147a/lectures/lecture4/5.php):
Pin 1 is ground. It is connected to the negative side of your battery or power along with any other components in your circuit connected to ground.
Pin 2 is the Trigger pin. It will be connected to ground and thus switches on pins 3 and 7.
Pin 3 is the Output pin. In this circuit it outputs a square wave signal that can be heard on a speaker.
Pin 4 is the Reset pin. It is not used in this circuit. See http://en.wikipedia.org/wiki/555_timer_IC or http://www.markallen.com/teaching/ucsd/147a/lectures/lecture4/5.php for more info on this pin.
Pin 5 is the Control pin. It is not used in this circuit. See
Pin 6 is the Threshold pin. The 0.02uf capacitor C1 will charge up and when it reaches about 2/3 Vcc (voltage from the battery), this is detected by the Threshold pin. This will end the timing interval and send 0v to the Output pin 3 (switches it off).
Pin 7 is the Discharge pin. This pin is also switched off by the Threshold pin 6. When pin 7 is switched off it cuts the power to the 0.02uf capacitor C1 which causes it to discharge. Pin 7 also controls timing. Pin 7 is connected to the 100K ohm resistor R5 and the Variable resistor. As you move the slider on the Variable Resistor RV, it changes the amount of resistance in the circuit. This changes the timing of pin 7 and thus changes the pitch of the square wave heard on the speaker.
Pin 8 is connected to the positive side of your battery or power along with any other components in your circuit connected to positive.
Step 3:
Build the circuit shown. If you want to design your own Snap Circuits diagrams go to http://www.snapcircuits.net/learning_center/designer
The photographs show the steps to build the circuit.
Once you build the circuit, push the Press Switch (S2). You will hear a tone from the Whistle Chip. Move the slider on the Variable Resistor (RV) and you will hear the tone rise and lower in pitch depending on which way you move the slider. Next move your hand so that it casts a shadow on the Photosensitive Resistor (RP) and listen to the pitch as it changes.
The last picture is an optional part of the build. Connect the alligator clips from the Snap Circuits Computer Interface Cable to the snaps on either side of the whistle chip as shown. The other end of the cable is an 1/8" jack that you would usually connect to the microphone input on your computer. Instead, connect the 1/8" jack to the 1/8" to 1/4" adapter so that you can connect it to your amplifier, or the microphone input of your karaoke machine, etc. In the video mine was connected to my mixing desk--I had a guitar stomp box set to reverb plugged into the auxilliary input and the mixing desk was plugged into my amplifier.
Step 4: 555 Timer Astable Mode
Let's see if we can make sense of what is happening. The 555 chip is in astable mode which means that Pin 3 is sending a continuous stream of pulses called a square wave signal to the speaker that you hear as a tone. The square wave signal is caused by the charging and discharging of the 0.02uf capacitor C1.
When you switch on the power at the Slide Switch S1:
Step 1. The 0.02uf capacitor C1 charges up.
Step 2. When the charge in the capacitor reaches 2/3 Voltage, this is detected by pin 6, the Threshold pin.
Step 3. The Threshold pin 6 switches off the Output pin 3.
Step 4. The Threshold pin 6 switches off pin 7, the Discharge pin.
Step 5. When the Discharge pin 7 is switched off this cuts the power to the 0.02uf capacitor which causes it to discharge.
Step 6. When the discharging capacitor reaches 1/3 Vcc, this is detected by the Trigger pin 2.
Step 7. The Trigger pin 2 sends 6 volts to pin 3 the Output pin.
Step 8. The Trigger pin 2 sends 6 volts to pin 7 the dischrage pin which causes the 0.02uf capacitor to charge up.
Step 9. Go back to Step 1.
This process repeats creating the square wave signal (see picture) and you hear that signal from the speaker as a tone.
When you move the slider on the Variable Resistor (RV) this changes the resistance of the circuit. Since the Variable resistor is connected to pin 7, changing the resistance controls the timing of how often the 0.02uf capacitor (C1) charges and discharges. Since the photoresistor (RP) is connected to pin 7 as well, the amount of light that falls on the photoresistor changes the resistance too, and this also controls the timing of how often the capcitor (C1) charges and discharges. You'll notice when more light that falls on the photoresistor this makes the pitch higher. Less light makes the pitch lower.
Congratulations! In this article you learned how to how to improve your collection of Snap Circuits blocks by adding a 555 Timer IC. You learned the functions of the pins on the 555 chip. You learned that when the 555 is in astable mode, the output of pin 3 is a continuous stream of pulses called a square wave that can be heard on a speaker as a tone. You learned how to build the optical theremin out of Snap Circuits. Finally you learned how to play the instrument.
Note: You may wonder why the 100uf capacitor C4 is installed in the circuit. At first I simply connected a three snap conductor from pin 3 to the Whistle Chip, but the 555 started to get really warm really quickly. I did not want to burn up my 555 so I replaced the three snap conductor with a 100 ohm resistor, but the tone from the Whistle Chip wasn't as loud. The 470uf capacitor puts just enough load on pin 3 to keep the 555 timer from heating up.
Sad news, readers. Hans Camenzind inventor of the 555 passed away--story reported in EE Times yesterday Wednesday 15 August 2012): http://www.eetimes.com/electronics-news/4394166/Hans-Camenzind-dies
4 Comments
Well done- with very lucid explanations! You could of course do this with a versatile "snap circuit" PICAXE microcontroller - see => https://www.instructables.com/id/quotSnap-connectorquot-PICAXE-microcontroller/ . Some (high level) code would needed, but the component count would reduce.
dude u got some cheap ass theremin skillz
I did warn you beforehand: "Warning! Playing an optical theremin is harder than I thought it would be when I designed it."
great explanation! those 555s are pretty cool
