3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build an analog vocoder
Step 2Buy the components
Buy the components
Besides the condensers listed in the previous step, I used the following components. You may want to buy a little more than the quantities I list here just in case you damage some while working.
Condensers:
17 x 4.7u
2 x 10u
14 x 150n
14 x 0.1u
Variable resistors:
16 x 50K
1 ganged 50K
Small calibration pots:
14 x 50K
14 x 1K
Jacks:
27 mono phone jacks (because each channel is patchable)
1 stereo phone jack
Cable:
3 meters of 10 wire ribbon cable
30 male 10 wire ribbon cable connector
30 female 10 wire ribbon cable connector
A bunch of wire to make all the connections (I destroyed an Ethernet cable to get this copper cable, its great because it is color coded and all).
Resistors:
28 x 1.2K
28 x 2K
2 x 1K
123 x 10K
28 x 20K
56 x 33K
28 x 120K
28 x 100K
42 x 200K
28 x 220
Transistors:
42 NPN transistors (2n2222 or similar)
Op Amps:
30 TL074
LEDs:
15 RGB
Diodes: 42 signal diodes
4 comments
Sep 12, 2009. 7:29 AMchirp-o-tron says:
Why are only 27 mono jacks needed. (I was assuming two jacks per channel for R and L)
Jan 18, 2010. 9:12 PMkwon1001 says:
You don't have to put all these jacks, and just joint all Filter's Input with all Input Stage's output.
Jan 3, 2010. 1:39 PMaudiophile says:
how much wattage do the resistors need to be able to handle? (i.e. do i buy 1/6 watt 1/2 watt....)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:planetone
