First a little introduction, watch the vide: http://www.youtube.com/watch?v=OJiMUzJHYFk
I started off with the toy titled "Interactive Wall-E". Available at toys'r'us current price $34.99
I am a robot hobbiest and have a lot of expierence with the programming and design to give robots expression and life. The first bit advice I can lend is to be confident. Second advice is to be creative. Together, you're mind will figure out the rest for you :)
There are plenty of peices available to you. My workshop is nothing special. I keep a supply of parts that are low cost. I usually collect items from disassembling other toys :) . Sadly, servos are the most expensive parts of the bunch.
For fasteners I use Zip Ties and an arragement of small screws, bolts and nuts. All are available in cheap combo kits at your local hardware store.
To modify the casings, i use a speed adjustable dremel and sometimes my soldering iron to melt plastic. For dremeling, please keep a vacumn nearby. *Warning: For melting, keep a window open with a fan!!
Also, if you choose to melt plastic peices, use a seperate bit on your soldering iron. The plastic will burn to the tip and make soldering a pain in the butt!
Now for the programming part... This is actually very easy. I do my programming for my robots using the EZ-Robot Project and the EZ-B Robot Controller. It does not require any programming. You can just plug in your servo motors and control the robot from your PC. It also contains voice recognition and a bunch of other neat features. You can get it here: http://www.ez-robot.com
Here's a video of Wall-e in action...
Here's a cute video of Wall-e falling over while chasing his ball :)
Remove these ads by
Signing UpStep 1Parts
Here is a list of the parts I used...
- 1 EZ-B with SDK or EZ-Builder software
Available at http://www.ez-robot.com
- 2 Parallex modified servos for the drivetrain
Available at: http://www.hvwtech.com/products_view.asp?ProductID=114
- 1 GWS Standard servo for the head (Left and Right motion)
Available at: http://www.hvwtech.com/products_view.asp?ProductID=878
- 2 GWS Pico servos for the arms (Up and Down motion)
Available at: http://www.hvwtech.com/products_view.asp?ProductID=863
- 1 GWS Micro servo for the head tilt
Available at: http://www.hvwtech.com/products_view.asp?ProductID=862
- 2 Sharp Analog Distance Sensors
Available at: http://www.hvwtech.com/products_view.asp?ProductID=88
- A collection of 3-Conductor Servo Cables
Available at: http://www.hvwtech.com/products_view.asp?ProductID=690
- 1 Box of assorted small screws/bolts/nuts
Available at your local hardware store
- 1 Hobby Hot Glue gun
Available at Walmart or hobby store
- 1 bottle of krazy glue
Or any type of good strong plastic glue
- 1 Soldering Iron
I use an adjustable temp range soldering iron, which is costly but recommended. Sometimes you can come across these used in bargain classifieds or at electronic supply surplus shops.
- 1 Case of Jeweler Screw Drivers
Avaiable at walmart or any hardware shop
also ebay selling Interactive Wall-E for under $20
also the board would be a good add on to ROBOREALM software,might ask STEVEN about it,mostly he looks for samples from robot companies and robot controller boards,so many interfaces on his website for robot controllers
he is working on one for AR parrot drone also
but they are standard servo's in the kit and robot said has micro and pico servo's is this correct
HS-55 or HS-65 BY HITEC at SERVOCITY or EBAY looks like a good choice
(Without the internal electronics, of course)
Solar power panels that open up and close every 2 hours while on
Light up solar charge panel, showing how much charge there is
Random times of the Wall-e having his chest bay open and him scoop up stuff with his hands
Led light eyes
closable eye shutters in a leaf iris motion
and finally a modified cocroach that is kinda like a brisstlebot!
Maybe, when I'm older I'll make this...
totally..
i m ur fan nw!!
Are they still available in the States, and if so where?
Thanks
then, you can learn to "script" in the ez-builder... and eventually move to the ez-sdk for serious programming.
there is absolutely zero space available. the tiny battery barely fits. there are multiple size toys, and the most common is the remote control wall-e (which this is not). check my youtube channel www.youtube.com/aliencurv for a video of my larger wall-e
