Step 7Distance Sensor & Assembly
So I used one of the sharp distance sensors mounted on his neck. I had to dremel a bit of the sensor housing to make it fit flush.
Maybe melt/drill a little hole through the top plastic of the box to push the wires through.
The wires that come with the sharp sensor are very small and easily break from fatigue. I replaced the wires with the Servo wire/plug combo that is listed in the parts.
I use those servo wire/plug combos for everything.. LCD's, Speakers, LED's, etc...
Tuck all the wires through their holes when you assemble the unit.
Add Comment
