Step 2Cut up the box
Break out the Dremel!
I highly recommend that you do some measurements, make some templates and make sure you've got everything the way you want to lay it out.
I chose to put my motherboard towards the back, point out one of the longer sides. The corners of the box are rounded, and because the 6.75" is a tight squeeze in this 7" wide box, you'll need to do something similar. I considered cutting just a small opening for power and the network card and then mounting it internally with the ports pointed towards the shorter ends. I decided though that I wanted the option of this being a regular computer.
I'll warn you now that this is stainless steel, not aluminum as it may look. It's not easy to cut through and requires a lot of patience. Take it slow, and buff and sand everything.
Add Comment
