Step 3Mount the Motherboard
Did you clear out the metal shavings and left-overs out of your case? Really? I cannot stress the importance here. One little shaving could short out your MotherBoard. Short-out/$85 down the drain.
Take some time and clean out the case after you've completed all of your cutting and drilling. Method I recommend:
1) Get a strong magnet
2) Wrap it in a tissue
3) Go around the edge of the box.
4) The filings (which have magnetized upon cutting) will stick to the tissue.
5) Empty into a garbage can by taking the tissue off of the magnet.
Repeat that several times. also take a brush and go around the crevices and the edges of the box. Clean out the box, and make sure it's in good shape. You'll save yourself some potential trouble.
Okay. Now that the case is clean, The motherboard. I cut my case to have room for the metal insert. I recommend it if you can.
The screws I put in here are 6-32 thread 2" long. I have two nuts. one which secures the screw to the case, and another which supports the motherboard. Initially I planned on putting another nut, but my holes weren't drilled perfectly, so the slightly off pressure of the screws is enough to hold it in place.
Add Comment
