3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build an inexpensive Ikea NAS/Computer
Step 4Add Harddrive hardware and hard...drive
Next, we need to put in a method of mounting the hard drive in the case. Initially I was going to mount two beams across the length of the box, and screw the drives in so they would hang upside down over the motherboard. This plan was foiled by my needing room for a fan. Additionally, hard drives are heavy, and the screw points didn't allow for a well-balanced situation.
To resolve, this, I decided to mount the drives vertically. This will assist with heat ventilation as well. The method is to have two right angle brackets attached to the case which will mount on the top of the drive, and then holes on the bottom of the case to mount on the bottom of the drive.
If you choose to follow my design exactly, make sure you get yourself a right angle SATA connection. The straight connectors won't fit in that tight space.
1 comment
May 26, 2009. 9:57 PMtonyboy007 says:
That shiz is gonna over heat trust me
Aug 8, 2009. 4:49 PMlucius108 says:
and if it gets hot u can just take the lid off
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:aarone(AaronEiche.com)
I'm Aaron. I've written for Television I"ve written, directed, and performed in a musical I'm a programmer I'm a Roboticist I'm a Dreamer I'm a doer
