Step 5Fan, PSU and you're ready!
Really you just need to tuck the Power Supply in and make sure it doesn't get in the way of any of the air circulation. With the PSU120, you'll probably need an ATX extension cable. The Pico has a pair of capacitors on one end that just don't with everything so tight. If you're going with the Pico PSU90, those capacitors aren't there and you can plug it right into the board.
The fan I've attached at the far end of the case just on the other side of the motherboard. It turns out that because of that rounded edge, you have just enough room to put the fan in.
One thing not pictured here: Power switch. I picked one up for a few bucks. I decided to save myself the trouble and not drill a hole. I don't think I'll be turning this off and on everyday, so I decided to just keep it in the case and open the lid when I need to access it.
comment
Add Comment
Add Comment
