Build Connectors to Use Breadboard Easily...!
Published
Introduction: Build Connectors to Use Breadboard Easily...!
About: I'm crazy about inventing new things..... and thanks a lot to instructables website which helped me to share my ideas...
Hello guys...!
I hope you may have used the breadboard......!
and you would have seen a problem that loose connection of wires...!
and if you want to use switches in breadboard then often annoying becoz they don't fit properly....
I have reused old wires,switches ,
male head connectors,....to make breadboard easier to use...
so that's why I decided to post this instructable....!
Step 1: Gathering Parts...
You will need only two tools..
1. soldering iron....
2. male header connector (40 pin)...
Step 2: Soldering Male Header Pins to Switches...
you can solder the male header pins to the switches....so that we can connect it into the breadboard...!
Step 3: Connect Male Header Pins to 9V Battery Connector....!
so that you can power up the circuit which is in the breadboard.....!
Step 4: You Can Make Jumpers..
I think you often have suffered from a problem that loosing of wires....
so you can make your own jumpers.........as I did.........!
Step 5: Connect......!
So you can connect how I did ..........!
and I have attached a USB port and audio port......!
Step 6: EASY Circuit....!
As shown in the pic.....
I have connected the circuit easily......!
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
