3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build the Mini Line Array
Build a Mini Line Array
Along with all my other interests in life, audio and speaker building is near the top. The first set of speakers I ever built had drivers that came from Radio Shack in 1978. The tweeters had a 10uF capacitor on the + lead and at the time, I thought that was all you needed for a crossover... Over the next 30 years I learned a quite a bit more. I was also very interested in line arrays as the concept always seemed like a good idea. A line array is a group of audio drivers (speakers) mounted in a row. It does a couple things for you. First, it allows each individual driver to use less power thus, in theory minimizing distortion as the driver does not have to work as hard. Second, all the acoustic energy couples together to provide a sound field that does not drop off at the same rate as single driver, which acts as a point source. For more information see this  and this.  This project started out like a lot of mine. Parts Express had a sale on 3inch audio drivers and I said “I always wanted to build a line array, let me order 16 of them!” three years later I actually got around to building them. I am actually glad I waited because there was more information I needed to learn before I built them.
There is a lot of debate around how good they are and what there issues are. On the down side, multiple drivers can cause interference and acoustic artifacts. Interestingly, the same argument is the same for why an orchestra sounds so good live. Next time you go to a concert look at the PA speakers... They are most likely set up as a line array. If you really want to hear how they sound lets build one!
Step 1The Design
The Design
The Design:
I found a speaker building buddy who happened to live in my neighborhood. The first time I went to his house he had a line array using 9 three inch drivers per side and 9 small tweeters. This reminded me about the 16 I had in my garage. After listening to his I knew I needed to put my drivers to good use. Dave suggested I pair them up with a different tweeter than he used. He used a ¾ inch dome tweeter and recommended the same driver that had a 5/8 inch dome. He had used this tweeter in a couple other projects and really liked them.
I had 16 of these
and ordered 16 of these for use as my tweeter
Dave had substantial experience with speaker design, after measuring my little woofers designed a great crossover. With 8 drivers I chose to wire them 4 in Parallel and then the two sets of paralleled drivers in series giving me roughly a 4 ohm load. This was taken into account for the crossover design. See the theoretical frequency response graph.
Parts List:
Crossover parts (for two speakers:)
(2) 2.4 Ohm Resistor
(2) 3.3 uF Capacitor
(2) 7.5 uF Capacitor
(2) 10 uF Capacitor
(2) .70 mH Inductor
(2).15 mH Inductor
(2) Speaker terminals
Cabinet/Enclosure Parts  (for two speakers:)
½ ” Birch plywood
(2) Front Panel 7” X 34”
(2) Rear Panel 7” X 34”
¾ ” Birch Plywood
(4) Top and Bottom 3” X 5.5”
(4) Side panels 3” X 34”
Miscellaneous
20 feet of Black 18 gauge wire
20 feet of Red 18 gauge wire
Semi Gloss Polyurethane
Wood Stain
Sandpaper
Mounting Screws for the 3” drivers
One bag of Poly Stuffing to act as acoustic insulation in the cabinet
Mounting screws for the rear panel.
Electrical Tape or Heat Shrink Tubing
Tools
Drill Press
Soldering Iron
Solder
Orbital Sander
Hot Glue Gun (with a bunch of glue sticks!)
Wood Clamps
Wood Glue
Screw Driver
For the cabinet I chose 13 ply birch plywood. In the Dallas area you can get it here. I wanted the line array to be small and compact. And, easy to build with the tools I have. I drew the front panel in inkscape  (Great Open Source drawing program!) Because the tweeters were so small I decided to just drill the right size hole and then glue the driver in flush to the front panel. I experimented with a 1 ¼” hole and a 1 3/8” hole and ended ordering a 1 5/16” forstner bit from here  that was just right.
37 comments
Apr 18, 2012. 7:46 PMTachyon says:
This design has me excited about using it as a basis for a project of my own. I can see modifying it slightly to make a clone of the polk SDA's, which I've always wanted to do.
Nicely done, thanks.
Feb 28, 2012. 1:04 AMheiney says:
To eliminate the "beaming" add an L-pad to the tweeter section in the crossover, just make sure the L-pad has the same impedance as the tweeter array, I'm guessing that would be 4ohms.
Jul 5, 2011. 6:24 PMsmirnoff04 says:
I'm not an audiophile so the technical stuff is lost on me, but I really appreciate the fine craftsmanship on display here. A great looking set of speakers to be sure. I've seen a lot of peoples' diy speakers and while I'm sure they sound as great as they say, 9 time out of 10 they just don't look good. That may not matter to purists but to me a speaker should look as good as it sounds.
Keep up the good work!
Feb 28, 2012. 12:41 AMheiney says:
I agree they should look as good as they sound
Feb 28, 2012. 12:36 AMheiney says:
MDF is the go to wood for building speakers & then veneered. I don't know one manufacturer that uses plywood. MDF is more dense, stable, great to cut & you don't have to worry about any voids which plaque plywood to no end & MDF is just easier to work with. And your choices of veneer is endless.
Older speakers the manufactures use to use particle board (also better then plywood) & then veneered the particle board.
It doesn't make a difference if the factory speakers are $100 or $10,000 there still veneered.
Pretty much like your birch plywood is just with a better substrate & well you can veneer a better surface for staining.
Birch just doesn't take stain well you should have used a pre-stain conditioner 1st.
Besides that I think the speakers look good.
Also on 2-way designs wire the tweeters out of phase with the low frequency drivers,
on 3-way designs wire the midrange out of phase with the tweeter & woofer.
This will eliminate any frequency cancellation at the crossover points.
Thats the reason why on some subwoofers you might see a 0/180 degs phase switch, its there just to make sure there is no cancellation of any frequencies at the crossover point between speakers, You probably will never hear the difference between one way or the other, but thought I would just put it out there as it is an easy thing to do.
Also there are online crossover calculators that you can use to design a crossover.
Apr 18, 2012. 7:48 PMTachyon says:
You're right on all counts. AFAIR
Jan 25, 2012. 12:04 AMjordon.gerber says:
Why not build a full length line array? Your "what I'd do next time" picture is similar to what Don Keele has done with his curved line array, but he himself has said that it is a fix for those who don't want a full floor to ceiling line array. His design is an attempt to minimize some of the inherent problems of creating a truncated line array. Also why lump all the tweeters closer together? I understand that you want the drivers to be as close together as possible to extend the upper frequency response of the system but at the same time when you don't extend the radiating area all the way down the cabinet the line array effect is destroyed. Was this a budgetary constraint or a deliberate design choice? If it were for impedance matching reasons, why not go for a lower overall impedance? lots of speakers try and reduce the impedance of their speakers to gain efficiency (Apogee, Genesis etc.), and also I have heard that it deadens the resonance peak of the driver but I am having trouble wrapping my head around how that would work.
Cheers
Jan 25, 2012. 12:20 AMjordon.gerber says:
Also, have you ever played around with this driver?
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=299-113
I am in the process of making my own 90" line array and am thinking about this driver as a mid/bass because of the price, aesthetics, quality, etc.
Nov 9, 2011. 3:52 PMpddonovan2011 says:
DJJules, this instructable could not have arrived at a more perfect time! i am one of those 'hold-outs' who is still watching his old 27" CRT Television. Not because I don't want to embrace the new Flat Panels, rather because the old CRT never stopped performing admirably. UNTIL JUST YESTERDAY, when all of a sudden the color has gone 'STUPID!' NOW it is time to replace it, with a flat panel screen and everyone says they have terrible sound! I have been looking for the answer to the question, "How do I get the 'Best Sound Possible' for the Buck?" And YOU, my friend, just answered that question. BEAUTIFUL pair of speakers, GREAT job, WONDERFUL! BUT!?! You raise several questions as well and I hope I don't make a nuisance of myself, But that is how you learn and speakers have always given me trouble! How do you 'Ohm Match' the Speakers to the amplifier? Doesn't pairing and quadrupling the speaker change the Oms? Four groups in parallel/series, doesn't that change the Ohms to 4 Ohm? Won't that over-heat a standard 8 ohm amplifier? Does that crossover have a terminal to which to connect the Sub Woofer? Can I, or should I, run DUAL sub woofers for extra presence and separation? (I do own dual Subs now!) I REALLY want to make this array a reality for my, fast approaching, New Home Theater System. I will GREATLY appreciate all the information you can provide. I am not afraid to jump all over this project and will rely on all the help you can provide. I already ordered the tweeters, cash was a little low this month. Next Month I have extra cash for the rest of the speakers and I already do cabinetry for people with BIG money! Let's ROCK this new speaker system!!
Jan 5, 2012. 9:32 AMsysadmn says:
Your explanation is a little unclear. I think you mean:
if you wire two 8 ohm speakers in series, they become 16 ohm then you wire that in parallel with two other speakers in series and you are back to 8.
In response to the original question, resistors in series add up, identical resistors in parallel are half the original resistance.
Nov 20, 2011. 11:56 PMpddonovan2011 says:
Excellent, really cool stuff! I was not thinking about left and right subs. I was thinking about front and rear subs. But first I am going to buiild my own arrays and then try them and see if the subs are even needed! I was also thinking about three additional Arrays 4 X 4 on the tweets and 3" speaks for the use of front and left/right back spekers!
Jul 7, 2011. 7:18 AMweeniewawa says:
square drive screws are way safer to use on something like this. actually always better to use. I used to do a lot of woodworking and just bought them online. http://www.mcfeelys.com/ has absolutely the best screws you can find, will not strip or break. It is also nice to be able to find Finish Birch locally. it gets expensive to ship.
Jul 7, 2011. 8:32 AMblanchae says:
Square drive screws are called Robertson screws and come in 4 sizes that are color coded to the screwdrivers: from smallest to largest: yellow, green, red, black. The most common size is red for pretty much everything and green for small work. Once in a blue moon, you'll use a "yellow handle Robertson" for something really tiny like a 4/40 screw. And once every couple of years, you'll use a black handle Robertson for something large. They are absolutely great screws but don't look as pretty as the Philips head screws.
Oct 20, 2011. 12:22 AMmpep says:
Thanks for that. Never knew the name of the square drive screws.
Sep 9, 2011. 3:48 PMellisgl says:
Suggestion for your next build. Put the wire through the hole of the terminal, wrap it around the the terminal and then solder it.
Aug 1, 2011. 7:05 AMjimvandamme says:
Why didn't you use the cheaper Tang Band speakers...W3-1053SC? They're only ten bucks vs. 32 for the neodymium.
Jul 28, 2011. 6:55 PMjhulan_111810 says:
hi mr.dj jules i wanna ask something about the speaker you made...what amplifier did you use and how much watts?tnkz
Jul 15, 2011. 5:58 AMjando915 says:
have you ever thought about making and selling these to ppl not everyone can can make something like this you can really make some good money doing it
Jul 14, 2011. 12:37 PMninjawasaki says:
Nice work! I was thinking about building a line area out of those dayton sound exciters I saw mentioned on another project here. If you are into line arrays and learning about them, read up on the Martin array that we use. Technical sheets can be found here...it's wild how they work and the results are amazing.
http://www.martin-audio.com/softtech/technical.asp
Jul 11, 2011. 3:36 PMtxsmoke says:
The vertical dispersion issue you note is one of the primary by-products of a line array- minimal vertical dispersion and wide horizontal dispersion. This dispersion pattern minimizes floor and ceiling reflections, contributing to the solid imaging you are experiencing.
This is also why they work so well projecting music and speech at presentations and concerts (and block parties :-).
Jul 9, 2011. 8:12 PMborus12 says:
Yes DJ the centre driver at ear level than the distances from each of the other drivers to the ear is the same.
Jul 9, 2011. 5:44 PMsnolou says:
You can do a slight modification to simulate curved mounting of your drivers by using the fresnel lense aproach, that is by progressively angling the drivers from the inner to the outer by either recessing the mount on the box or adding an angled mounting ring under the speakers. You can do this with the midranges and the tweeters. I did this with some arrays I built in the eighties using 4" Dynaudio drivers and tweeters to good affect. The good thing is If you use angled mounting rings under each driver you can undo it if you don't like the results. Great project I am very envious you were able to achieve this. Maybe I'll be inspired to do it again.
Jul 9, 2011. 5:47 PMsnolou says:
Oh one PS I would prefer a concave to the desighn.
Jul 7, 2011. 8:28 AMblanchae says:
For better bass response, put the speakers in the corners of the room. This will cause the walls and ceiling to act as a folded horn and project the bass better. Nice design, I've always wanted to build multiple "small speaker" box ever since I saw the Popular Electronics Sweet Sixteen project in the 60s. I've placed fiberglass insulation quite successfully for inside the box - completely filled. The insulation makes the box appear acoustically bigger than it is, resulting in better bass response.
In one design, I've used prime numbers for the boxes dimensions in order to stop harmonics from occuring - never really could test it if it actually did anything but it does make a good conversation...
Jul 7, 2011. 4:36 PMbknight2 says:
I think what you were looking for is divine ratios. haha!
Jul 7, 2011. 6:41 AMAnsis says:
Hi!
It looks good!
I think- I know how it sounds- I can "Imagen" , because I am in "sound" from 9 years- now I am 44. My way is 4 speakers in the big desk. All 4 is wide- range and paper with 92 dB/m. I have 2 SE drivers 6P14-EV- Russian military in pentode connection- all power is stabilized.
P.S. If You have interest- I can make some photos and send to You. I have Skype: ansis99 and e- mail: ansis_fr@inbox.lv
Good Luck!
Jul 6, 2011. 9:57 AMlesizz says:
Really cool project. And I agree with '04 that they look really look nice.
How did you get the response chart? You must have some fancy equipment. Do you have a room that you've made aneochic?
Maybe you already know this, but the reason speakers are less distoted when driven at low levels is that the cones essentially have a spring-return. The pressure exerted by the spring is not constant, but increases with the amount of cone distention. Non-linearity is the enemy of fidelity. We get harmonic distortion from non-linearity, not to mention other evils. So, anyway, the less the less the cone is driven, and the less the cone is distended, the less the distortion.
How do these speakers sound?
For speaker-listening I like to use some full-orchestra stuff, but very simple music can be very telling. Something like Abby Dewald of the Ditty Bops singing "It's a Shame", accompanied only by her guitar. Does her voice sound real? That's a severe test of a speaker system.
Now all you need are some good tube electronics, a turntable and a collection of some good vinyl to take full advantage of the speak's.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
45
Author:DJJules
I started taking things apart when I was 6 started putting them back together at 8 and they actually worked again when I was 10 or 11...
