iImage Information
Once in awhile I get the urge to create a new wild and crazy cycle based on some idea from the many sketches I have collected over the years. Sometimes these bikes work out as planned, creating new and fun ways to move from point A to point B, and sometimes these creations fail, either in a huge flop, or a blaze of glory where the crash test pilot becomes acquainted with the pavement. This time, the plan worked out, resulting in a very unique and fun ride that is both challenging to master, and capable of some off-the-wall maneuvers.
Step 1You will need a BMX front wheel and a caster wheel
iImage Information
The SpinScooter is based loosely on our
SpinCycle Stunt Trike, allowing the front wheel to steer the vehicle as normal, but also allowing some out of control steering by allowing the rear caster to steer the rear of the vehicle. This front and rear steering gives the feeling of riding on ice, or doing a burn-out on a fast motorcycle. By shifting your weight around and controlling the front wheel, you can get the SpinScooter to do 360s, steer into a drift, or behave like a regular kick scooter. When you are first starting out, you will also learn creative ways to fall on your back!
As shown in Figure 1, you will require a pair of wheels - a standard front 20 inch BMX wheel and some kind of caster wheel like the ones you would find on the front of a shopping cart. The larger the caster, the more fine control you will have over the scooter, so choose the larger diameter caster wheel you can find. Also, rubber or air filled caster wheels are better than hard plastic casters for this project. The caster wheel shown in Figure 1 has a diameter of 8 inches and was taken from an old wheelchair.
It looks good on your profile pic but is too small to see any detail..
Good job and thanks.
thanks again!
