Build Your Own Countdown Regatta Box
8,005
76
13
Published
Introduction: Build Your Own Countdown Regatta Box
An countdown "box" is a box with horns. When a regatta starts the box sounds the horns at predetermined intervals: 5 minutes before the start, 4 minutes before the start, 1 minute before the start and at the instant of the start. There are two types of sequences: 3 minute and 5 minute. In this instructable me and Chris LaBorde will show you how to build one by yourself. Because marine salt and water environment of boats, the box must be at least splash proof. Using the box will release two volunteers.
Step 1: Components Needed
This photo shows an LCD shield and one realy module.
Arduino UNO from dfrobot
One LCD Shield from dfrobot.com (see photo)
Two relay modules from dfrobot.com
One YUASA deep cycle 12 V 7A battery
One charger for the Battery of 8A
One piezo buzzer
Three push connect only switches
One toggle switch
One on/off interrupter
One splash proof box
A set of two horns and a compressor with the air tubes.
One Tupperware small
Cables, shrink tubes, solder (optional)
Step 2: How to Charge
1. Open the box to charge the battery when needed.
When battery charging push the red toggle switch to charge mode. When not charging push back to 'normal'
Step 3: How to Use
The big green button starts the countdown.
The small button sounds the horn manually (override in case of emergency)
The yellow button inside the box toggles the sequence type between: three minute countdown or five minute countdown.
Step 4: How to Wire
1. Stack the lcd shield on the arduino board.
2. Connect the relays inputs to pins D11 and D2, connect relay D11 to piezo and D2 to the compressor.
3. Connect the big green button to the lcd push buton 'LEFT' (solder cables to the switch pins in the LCD board, the push button will override the lcd 'LEFT' button)
4. Connect the yellow push button the the lcd push button 'SELECT' (same as 3)
5. Connect the small green button between compressor + and battery + poles (to sound it manually)
6. Connect battery to charger via the red switch and baterry to compressor and arduino power input via the 'normal' position of the red switch.
Step 5: The Splash Proof Box
Find a splash proof box with rim seal. Use foam at the bottom so nothing is loose. Once the wiring is done put the Arduino and relay modules inside a Tupperware for added waterproofing. Make holes for the tubes that power the horns. And fix the horns as in the picture.
Step 6: Programming the Arduino
To program the Arduino: Download the Arduino IDE to your laptop. Upload the code to the Arduino with a usb cable. Source is here: https://github.com/orioli/ollie/blob/master/produc... the time units is 100ths of second and the time resolution < 10ms approx.
  • Casting Contest
    Casting Contest
  • Make it Move Contest
  • Woodworking Contest
    Woodworking Contest
13 Comments
This is cool! When I watched your video, the horns starteled me. Great design!
The layout is Chris design. Now we are working on a leaner version with no battery. We shoudl attach a sticker that says "sounds hazard - wear protection" LOL
I have succesfully loaded the program onto the Arduino UNO3. The problem is where do i solder the pushbuttons to on the LCD screen. I know that the select and left switches do all the nessasary functions, I just need to wire the momentary push buttons and am not a computer expert but the soldering is no problem. help me with a simple diagram, or do I solder to the pins on the back side of the board behind the switches? It appears that each switch has 4 pins or is A0 used with other connectors on the LCD board.
Solder your momentary Switches to the back of the LCD Shield on the points next to the board edge. You don't need to do anything with A0
I notice that you've not bothered with a schematic... is there one?
This is great but our club uses a combination of lights and horn. I wonder if I could modify this to do our start sequence?
Advance Notice - Two lights flashing and repeated hornApprox 1 minute before warning signal (short duration)
Warning- One light, single horn and flag 5 minutes before start
Preparatory - Two Lights, single horn 4 minutes before start
One Minute - One light, single horn 1 minute before start
Start - No lights, single hornAt start
Hi I am also wanting to build start regatta system to include lights and horn, very similar to your start sequence New to electronics and will be buying first UNO
if you move forward with your project let me know :-)
Thanks so much for posting this. Going to make one for our J/22 class and if successful one or two more for our junior program. Im pretty good with mechanical things but have no experience with electronics. I've tried to source all the things on your list - but there are a lot of options for each item. Would you mind proofing my shopping list to be sure Im buying the right components? Here is a link to the list I've assembled with SKU's on each item (you can comment on the document)
https://docs.google.com/document/d/1jrpwLfU0zDGcn7...
Also I couldn't find the "on/off interrupter" for the toggle switch -there are many options - could you give me the details on the toggle switch?
Thanks again
Dave
that should say "or the toggle switch"
Love this and would like to make one for my club. I'm good with the wiring, but not code writing. Your code for the 3 minute start seems to be different than what we use. We use 3 long blast at 3 mins, 2 at two mins, 1 long 3 short at 1:30, 1 at 1 min, 3 short at 30 secs, 2 at 20 secs, 1 at ten secs, and count down from 5 secs to start. Could you lead me through changing the code to achieve this. Thanks for any help
modify the vector
unsignedlong sch_3[] <-- indicates horn or buzz time in 10x ms units
h_or_b3[] <-- code: buzz = 0, short horn (sh) = 1, long horn (lh) =2 extralong horn 3
