3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build your own Electric Car!
Step 3Adapter plate
adapter plate
You did make sure to keep the transmission, right?
We will use the car's original transmission as a way to connect power from the electric motor to the car's wheels.
The trick here is how to attach the motor to the transmission?
We will make an "adapter plate" out of a chunk of plate aluminum which has holes in it to line up with both the transmission and the end of the motor.
I pulled the transmission out of the car, and flopped it on some tagboard, then outlined it in pencil and marked all the holes.
I then took that and the motor end cap to a local machinist who is also a hot-rodder and knows way more about cars than I do.
He cut an aluminum plate to the size and shape required, complete with carefully aligned holes. The center of the motor drive shaft and the center of the transmission driven shaft need to line up perfectly.
Before bolting the motor and transmission together with the adapter plate, we need to design a coupler that will mechanically connect both drive-shafts.
10 comments
Jan 27, 2009. 12:51 PMdansoffdawall says:
Where can I get an electric forklift motor and batteries for a good price?
Jun 12, 2011. 8:10 PMjimramos says:
I work as a buyer for a scrap metal dealer. We buy forklifts and chop them up for scrap. You might check in your town for metal recyclers instead of junk yards to hunt down a motor. I haven't read ahead to how the controls are constructed, but you will probably find some relays etc. tho help finish the project in the same visit.
Jan 28, 2009. 2:01 PMdansoffdawall says:
Thank you so much, this really helped me alot because I'm converting my old BMW to run on an electric power supply.
Mar 20, 2011. 3:03 PMfr334risT says:
That's pretty straightforawrd , also you look just like "Tony Stark" even more with all the "Mechanical Fuzz" lol
Great Job! Looking forward to make me own very first car be an Electrict one :D
So other ppl be jelous of "Why the heck that car doesn't have a muffler or why he doesn't use gasoline!?"
Thanks :D
Joey
Sep 17, 2009. 12:17 AMmontague says:
Would this work the same way with an automatic transmission?
Sep 26, 2009. 4:43 PMmotormayhem says:
No it wouldn't work with an automatic because the torque converter always needs to be spinning to run the hydraulic pump to keep the transmission in gear. This is why you cant push start a automatic. If you loose hydraulic pressure then the transmission will be unable to shift and will not stay in gear. You might be able to pull it off with a lockup torque converter (torque converter with a clutch inside it), but you will still have problems with the transmission starting from stops because the hydraulic pressure would be too low to correctly hold it in gear resulting in a swift failure of 1st gear. The only way to make it work would be to run the electric motor at about 800 rpm when stopped with a lockup torque converter, and then when it is time to go lockup the torque converter and go. It would be a tricky process at best and running the motor constantly would kill the batteries.
Sep 22, 2009. 4:14 PMDanish M1Garand says:
Back in the day this was the hot setup for drag racing. You replace the Torque Converter with a manual trans style clutch.
Jun 12, 2011. 8:04 PMjimramos says:
This setup required an adapter that constantly drove the transmission pump with the clutch cover. The engine was always running just like it does with a torque converter. The only way to make an automatic work with an electric motor is with a separate small electric hydraulic pump that would keep the pressure up in the transmission. This would be additional battery drain. If you have a driver that doesn't know how to operate a clutch, no need to worry. There is no clutch with the electric motor.
Nov 23, 2008. 4:46 PMChemGuy45 says:
Did the machinist follow your stencil drawing or did he just rework all the measurements himself? The times I've gotten people to weld things for me they haven't been too accommodating.
Nov 13, 2008. 5:18 PMmatroska says:
Long story short about this step: you had to fit the forklift engine to the transmission and made a custom part, right? This sounds complicated! But still an awesome project!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
280
Author:bennelson(300MPG.org)
Ordinary guy with no special skills, just trying to change the world one backyard invention at a time. See more at: http://300mpg.org/ On Twitter - @300MPGBen and at Ecoprojecteer.net
