Aside: I'm in the middle of re-roofing my house and plan to build in a transparent section of roof in one area. Then I can experiment with different solar collector designs like this one and install and remove them easily from inside my attic instead of having to go out on my roof. It will make the plumbing easier too. The drawback is that if a collector springs a leak, it will leak into my home instead of into my gutter.
For information on this and other projects of mine see my website IWillTry.org.
Remove these ads by
Signing UpStep 1: Concept
Because the whole collector is made of plastic, it is important that the temperature doesn't get too high or it will soften and possibly spring a leak. 80 degrees C (176 degrees F) is about the limit. Don't think it can get that hot? Think again. In practice the maximum temperature is difficult to guarantee. Water may stop circulating, or may drain out completely for a number of reasons and the panel will overheat. Therefore this may not be a practical design for residential installation but it is an inexpensive, easily built experimental system that produces as much or more hot water than commercially available systems. Mine cost about $60 in materials (about $4.00 per square foot) and about 6 hours of construction time.
Visit Our Store »
Go Pro Today »
If you get enough bio activity and pretty good insulation you may never need additional heat.
Have you ever seen a truck load of chips from a tree chipper smoldering away? Hopefully the bio activity in a worm compost may not get that drastic but if the worms get busy and you add heat at the same time i think you would have a real mess on your nahds.
I live in the SF Bay Area, where temps are moderate compared to the Frozen East. I keep my worm bin in an outdoor shed, raised slightly from the cement paver floor and it's fine.
The cistern sounds like a great way of having Thermal Mass. If you can keep the soil Under it away from moving ground water, sink the insulation deeper into the soil around it and use the additional mass of the soil underneath to ride through cloudy days. The insulation and surrounding soil may need to be covered with tarp to drain away moisture. It may take a while to heat the soil underneath, but the solar collector would eventually get there.
Rigid hose under the compost sounds great. Of course the plumbing and collector would need substantial insulation, since it will be out in the cold. The water is in a closed loop and not used for drinking or for moisture, so you can load it with a non-toxic antifreeze and black dye for improved heat absorption. (We are on a web page with a transparent absorber!)
It is also a good idea to provide some heating from above. This could be rubber hose and/or bladder on top of soil and/or transparent insulation (bubble-wrap or white closed-foam) above the rest to let in light.
Good Luck!
I tried the first setup by using ABS pipe, but there was always leaks along the pipe. I tried with many type of glues and regular silicone doesn't seems very good at this.
Finally I bought a plastic plank, cut it in two narrower planks, made a deep groove to make the coroplast enter it. I use using workbench saw and multiple pass to avoid plastic overheating. Finally I glued the plank to the board using epoxy. It worked but it is expensive. The groove was deep enough, so there was a free space below the insert to have water to get in.
I didn't had any problem about overheating, since the sheet is not in a enclosed area. If water doesn't circulate it just get hot quickly but not enough to damage it. The panel releases it heat into the air. Actually I make water circulate at a speed of 4 gallon per minute. The panel is 4x4 feet, and water raise from 2°F when passing through it. Sure when you consider a pool of 10000gal, divided by 240 gal per hour it would take 42hr to get a complete 2°F increase. But this is relatively small panel. I intend to install four 4x8 panel on the roof, so I could get a 2°F increase 8 time faster so the pool would gain 2°F increase in 5-6hr.
The key to the efficiency again is to make water circulate quickly trought the panel, so the every F° gets into the water and not back into the air. Surprisingly I get the same 2°F increase on colder days (60°F outside) than on hot days (90°F).
Last I had to make 2 perpendicular 1/2 hole at the top to collect the water (through 2 short copper pipe to which I plug my hose). With only one, some part of the panel where gettting hotter. The panel is installed verticaly so the hot water return is a the top. This way panel temperature is even.
We did a 4 hour test on a clear day, readjusting the panel angle a few times during the test. The full spreadsheet is available but I was not sure if it could be posted here, so I just posted a screen shot of it. It is a 1.814 square meter panel with 37.85 liters (10 gal) of water in the system. We used a 55 gallon plastic drum for the tank. The tank and hoses were not insulated.
At the 1 hour mark average power was 951 watts, 52% efficient. At 2 hours, 768 watts, 42%. At 3 hours, 593 watts, 33%. At 4 hours, 464 watts, 26%. We also did a stagnation test with no water in it, and it got up to 152 degrees F on a 45 degree day. We are looking forward to mounting it permanently and testing reliability/longevity. One thing we still need to do is get UV clear paint to help protect the panels from UV breakdown, and see if that affects the efficiency much.
The pool heating may overload your current hot water system so that it cannot ride through cloudy and/or cold days; then you are using fossil fuel. :-(
If your home is well insulated, you may be able to use some of that domestic hot water energy for air heating or radiant floor heating. ;-) This is also a good use for excessive hot water from the solar pool heaters. They can provide preheated water before a final boost from the domestic hot water system. This loop would Not use potable water. It would run on a separate loop requiring a pump, heat exchanger(s) and second thermostat.
water heater for swimming pool
For what it's worth, the better commercial solar pool heaters run at about 80% efficiency and here's a DIY unit that hit 78%.
http://rimstar.org/renewnrg/solar_pool_heater_diy_fp.htm
Your best bet for local sources are sign shops which often have 4'x8' sheets in the 4-5mm thickeness. they also have 2-3mm thick smaller panels which are used for real estate and election signs.
Another handy material is the stainless steel sheet, salvaged from dead clothes dryers (the drum is often SS), and commercial (and increasingly, domestic) refrigerators and other appliances.
To avoid air bubbles it is a good idea to install your fill point at the lowest point of the system. This is because air always rises to the top. The expansion tank should also have a safety relief valve from a water heater installed. Better yet, use a water heater as the expansion tank.
- air locks
- collector not low enough relative to storage tank
- connecting tubes not large enough in diameter
- connecting tubes not providing a continuously rising (for hot tube) or continuously falling (for cold tube) path for the water to follow
I don't know what diagrams you are referring to.You are welcome to add it. If you like, please also check my website www.iwilltry.org where I have some other solar projects. Cheers.
. In your "thermal conductance of a typical flat panel collector." your calculation of 25 watts for the fins. I got, but you did not do the tube itself. 4 .25" tubs that are 4 mm thick would greatly increase the efficiency.
0.4 W/mm/degreeC * 7741.92 mm2 (6.35 mm wide x 304.8 mm long *4 qty) /4 mm = 774.19W/degreeC.
Which would make the copper 799 w/ degreeC
Really tire so might be out of my head, but seems correct.
Well, today I finally got around to buying a sheet of black corrugated plastic and was thinking about how to connect the ends to some PEX pipe I have.
Then I saw this site, you beat me to it ;-)
Its great to see that it works as well as hoped it would, I can now build with confidence.
Coroplasthttp://coroplast.cat-x.net/CategoryListView.aspx?id=1 is the material you are looking for and is available in black.
As for all those plastics, your guess is as good as mine. I found this site that lists the "Vicat softening temperature" of some of those plastics. PVC may work OK if you make proper allowances for thermal expansion and ensure that there is as little force as possible acting on the tube while it is in a softened state.
