Step 2Mech feet
three pistons instead of two, thus the extra hole up top, which I later ignored completely.
I used fiberglass resin to strengthen the feet so they could withstand the pressures from walking. If you've never worked with it before, fiberglass resin is basically the daemon-spawn older brother of paper-mache, only instead of paste you use a resin that sticks to everything and has toxic, explosive fumes. And instead of newspaper you use a fiberglass cloth that feathers into these long thin strands that always float into whatever you don't want them to stick to. And since they're fiberglass, they give you nasty little splinters. And then once the resin
dries around them they become sharp little needles poking out of your piece that you need to sand down. It's pretty nasty stuff, but it did protect the feet well. I found the best technique was to essentially upholster my foam-core shell with the fiberglass cloth using a stapler, then paint the resin over the cloth. Use as few pieces as possible to avoid feathering.
Add Comment
