3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build your own t-shirt printing press
Step 4Make your design
Make your design
If you just want to have text then one of the simplest ways is to use wooden letters instead of making your own. Since Michaels was a kind contributor to a prior contest we recommend their wooden letter sets. On the other hand, if you want to make a design or image then there is a lot more work (unless of course, you own a laser cutter) to cut out a design. We decided to try an image of a 20 sided die along with the text "High Roller" (Copyright Kevin Dean and Ryan McFarland!) We experimented with materials that we had around the workshop. Red cedar smells good when the Dremel is put to it but the wood soaked up the paint. Laminate counter top was tough to shape and showed the blotting pattern because it was too smooth. Finally we tried using some foam from a set of alphabet foam letters that are used for a child's play mat. This was easy to cut with a hobby knife and took the paint well. It also was forgiving when pressed against the cloth.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
264
Author:zieak(Zieak's site)
I like making things out of items that would have otherwise been discarded. Check out my other projects! Now a PE teacher in Mongolia! I don't have much time or even the resources to make much any m...
more »
