Build yourself a portable home - a mongolian yurt
 by davidbuzz
Featured
Yurt/Gher Construction 101
A guide to Building Yurts...or more specifically, how I built mine!
Based on Knowledge Gained from "Doing it Myself", and reading about it on-line.
I've now built three yurts, for myself and friends, and we go camping in Luxury in these a few times a year.
If you like the outdoors, but you hate having to crawl around in pokey little tents then this one's for you!
We sleep two of us in luxury in this tent, in a full queen-sized bed! Of course, sleeping on the floor, like a plastic tent, you could probably sleep 20 people, easily!. :-)
We have dedicated hanging space for our clothes so they don't crumple or anything, and lockable boxes for our belongings (or a lock on the door works too!)
When we invite other camping-inclined friends over for a party in our tent, we can confortably fit 15-20 people in, sitting around on cushions and lounging on the bed and on the rugs on the floor... now that's what I can a party tent! :-)
If you like pictures, please be sure to have a look at step 9 - it's got over 50 assembly photos on that step alone !
Step 1: Overview of the parts and process.!
I'm going to cut right to the chase, and assume you know the following (in principle):
1) What a yurt is, and what it's made from.
2) How all the components should look when together.
If you've ever seen a yurt in the flesh, or photo's, or read a bit about them, that's enough.
As you can see from the photo/s, there are a few major components, so I'm going to write about each of these in turn, with some background info, and how to make them, and after that I'll show you how it all comes together for the assembly!
  • Dimensions and background.
  • Timber Components
- wall
- roof
- door.
  • Metal Components
- roof hub
- bolts, pins, pegs.
  • canvas components
- wall
- roof
- roof cap
  • Assembly!
below are a few sample pictures of some components, just for intereste sake:
Step 2: Dimensions and background
Over all DImensions:
Tent Diameter: approx 15' ( 5 meters) across.
Tent Height: approx 10' (3 meters) in the centre, and 5'6" ( 1.6m) at the edges.
My Yurt Components (A reference guide for later) :
Wall Timbers: 8'(2400mm)long x 6mmx35mm Slats (see below) Quantity: 70ish
Wall Bolts: 1" or 1&1/2" long x 1/4(6mm) bolts Quantity: almost 300
Main Roof Supports: 8'(2400mm) x 45mmx35mm Beams Quantity: 8
Secondary Roof Supports: 8'(2400mm) x 45mmx16mm Beams Quantity: 8
All roof supports and wall slats are cut-down from 90x35 F8 or F12 pine framing timber - see below for details.
Roof 'HUB': Constructed from metal (see later steps)
Wall Canvas: 8oz canvas - preferably "proofed", but I used untreated and unbleached canvas and treated it myself (see details in later steps)
Roof Canvas: 12oz canvas - MUST be "proofed" (water proofed, and anti-mound treated) ...don't use 8oz or you'll regret it. If you can find a really strong and properly treated 10oz canvas(I couldn't), then that will probably do, but it might sag a little.
UNRELATED ASIDE: If I was going strictly "traditional" I wouldn't be using zinc plated bolts
(or any bolts), I'd be lashing saplings together not using machine-sawn timber, I'd be using
natural felt made from sheep and yak fur mixed and pressed with oils (linseed and boiled
animal fats) not water proofed and anti-mould treated canvas. I wouldn't have a tarpaulin on
the floor, it would be dirt, and there would be a rock-surrounded fire-place inside the tent
for warmth (and smoke). The door would always point south, the north inside wall would have
a religious idol/importance. The men and visitors would always sit/sleep on the west, the
women and children on the east, you would always stop for a meal when passing, you would
always ask 'How are you?' '..And your family?' '..And your flock is fat and well?' (and the
answer would always be yes even if it's not true) I'm not THAT anal about "traditional"
form nor am I a "historical" nazi.
Step 3: Timber Components - the wall
How I decided on the size:
Some designs I saw specified 1&1/2"x1/4" OR 1"x1" OR 1&1/5"x1/2" sizes.
I figured that the smallest size would be lighter and would be strong enough if I had the slats
"overlap" enough, and I saw at least 3 sets of plans that used 1/4" thick slats, so I used
that size.
As it turns out, the flexibility of the thin slats is really good for portability as it allows the yurt wall to be rolled-up rather than split into sections and layed out flat.
I thnk 5-6mm is OK, but only if your timber is not prone to breaking, and has natural flexibility in it. Other timber batches do require 7-8mm. In all three tents that I've made, I've always used pine, because it's easily available, and cheap, but there are differing qualities, and using the lowest quality pine (once, in my second tent) did result in more damage occuring, more easily, so I prefer the higher grade/s now.
The extra 2mm might not sound like much, but it'll make a big difference while still giving
the flexibility...or you could leave it that thin and use a slightly harder timber than pine
(eg meranti)...pine is probably as soft as it comes, so anything comercially available will
be stronger than pine. If you don't have pine locally, use whayever softwwood it is that your house frames are normally made out of.
What size I ended up using:
I used approx 6mmx35mm (1/4"x1&1/2") cut from 90x35mm pine construction timber.
Using a "thin kerf" saw blade in a standard circular power saw I was able to cut 9 or 10 slats from
each 90x35 length, so I cut up 8 lengths into about 80 slats, and this gave me some spares
to allow for the more than occassional knot in the timber which weakened the slat and/or
caused it to snap. Don't throw out broken slats as these are used around the door where
the slats must be shorter.
The structure is quite flexible with such thin slats ..it's quote strong enough tho, so if you are after a LIGHT and easy to carry wall structure then go for 6mm, a reasonably sized guy (me!) can easily carry my entire wall structure when it's rolled up into one 8' long 300mm across cylinder.
I've seen other designs that said when they rolled their walls up they rolled up to 2' (600mm) across, so either mine is more flexible/lighter or I rolled it tighter, or both.
Length of timber was 8' because the slats are angled at 45 degrees when setup, giving a wall
height of approx 5'6", which is adequate for anyone 'normal' (if you are 6'6" tall u might like
slightly taller walls).
My timber yard is aimed more at the commercial market, and they sell in
3.0,4.8 or 6.0 metre lengths only...which is great, I just bought the 4.8 lengths and asked them to
cut them down the middle (to 2.4m or 8') "so I can transport them easier in my car".
How I cut it:
I mounted the circular saw upside down (with the blade parallel to the wall) onto a "saw table"
which I made up temporarily from a few scraps of timber I had lying around. The table top
needs to be almost twice as long as the timber you are cutting "longwise". The table I jigged up
was about 4 meters long.
I then screwed a "running board" to the top of the 'table', parallel to the saw blade, so that it was 6mm (or your prefered slat width) behind the saw blade.
Remember that the saw itself is actually underneath the table, and has the blade sticking up
through a slot that you sawed in the table just for this purpose!.
Don't use your dining table for this! DANGER: dont ever try this at home! ;-) Using an exposed saw blade like this is a definite danger. If you like your fingers DO NOT go anywhere near the saw while it is running.
In order to switch the saw on/off and keep it on without holding the trigger in all the time, I
plugged it into a powerboard that had built-in switches, and used these to switch on/off, I then
used a "zip-tie" around the handle to keep the trigger "on" permanently.
In order to keep the timber that is being cut hard up against the timber running board( and hence
make sure that the slats are consistent in width - which is important), I added a little swinging
pivot to the table near the saw blade, and hung a heavy weight off the pivot with a piece of thin
rope.
It was arranged such that the strip of timber that made up the pivot pushed up against the
front edge of the timber being cut, and the counter-weight (in my case a large lump of hardwood,
but a house brick or 2 would also do) pulled on one end of the rope with the other end tied to
the pivot.
The overall result is that the weight on the rope pushes the 'pivot' timber, and
that in turn holds the timber being cat hard against the running board. If none of this makes
sense to you, thats OK, don't worry about it, just find a willing volunteer, give them a "push
stick" and charge them with the responsibility of holding/pushing the timber hard against the
running board while you feed it along the length of the timber being cut.
See the picture below if this is all still to much. It really quite simple, it's just hard to describe.
(SIDE NOTE: a "push stick" is a piece of scrap timber at least a metre long (or 2) than anyone
working with a table saw should be using at all times that they are anywhere near the saw. It
is used to push the piece of timber that is being cut, so that you can push it right up to and
through the saw blade without worrying about things like loosing fingers, etc, having your grip
on something slip and 'whoops there goes that hand'. The end of the 'push stick' is sacrificed
to the god of the power-saw as it becomes sliced and diced up...better it than your fingers!)
Calculating the Quantity of slats required:
A number of factors are involved... 1) how many bolt holes (ie overlapping slats) you have in
each slat. 2) how big you want the finished tent to be, and 3) how many roof supports you want to have.
1) number of bolt holes can be between 5 and 10 per slat. I have seen examples of 5,7, 8 and 10.
The person/plans I saw that said they used 5 later said they had modified their plan by adding
intermediate holes, and converted the 5 to a 9 hole. I figured that I'd pick a middle figure
out of 5,8 and 10. I used 8 holes, layed out thus:
first hole : 3"(75mm) from one end (the top)
next 7 holes: 1'(300mm) in from the last
leaving : 9"(225mm) between the last hole and the other end (the bottom)
This gives a "grid" when assembled whose sides are 1' (300mm) in length.
My finished tent is approx 15' diameter. It seems that most designs I could get my hands on a based around a 15" tent (or close to) as it is quite large enough to normally sleep say 6 or 8, and
this makes it perfect for two or three and leave lots of room to spare.
Some maths: lets assume we want a tent of around 15'(4.5m) diameter, and we are using 8 bolt holes separated by one foot into an 8' slat as described above. When the slats are assembled we will also assume that they are angled at 45 degrees. This results in a wall height of around 5'6" with the slats at 45 degrees.
The angle of the roof will mean that the centre of the tent is over 7' tall (more on that later), so if you are more than 5'6" tall, don't worry, youll only have to duck when going thru the door.
If the slats are at 45deg. then they will be forming diamond shapes in the wall grid that are actually completely square. the width of these "squares" across the diagonal (ie horizontal to the ground) is (using pythagoras) square-root of 2, or 1.41' (424mm).
In order to get a tent that is 15'(4.5m) round you need a circumference of 3.14x15' (3.14x4500mm) ie: 47.1' (14.13m). with each 'square' being 1.41'(424mm), that means we need 33.65 of them to go the entire way round the circumference.
Each square takes two slats, so we need 67.3 (must be multiples of 2) rounded to 68 slats for the entire tent. That said, we haven't allowed for the door yet, or taken into consideration how the roof sits on the top of the walls, but you get the idea....next, the doors etc....
If we make the door 2x1.41' or 2.82' (846mm) wide, then it's an nice even figure, and we can
simply reduce the number of required slats by 4 to 64. (the door taking up the space that those
slats would have take up).
Since the roof supports have to have their lower end supported onto a point where the slats
intersect, then we must be able to divide the number of 'squares' around the tent evenly by
the number of roof supports we decide to use.(or suffer un-evenly spaced roof supports - eek!)
When building my yurt, I forgot this next bit of the step, so every time I put the roof onto the walls, the roof suports never quite sit right as I have to put them onto the nearest intersection , which isn't exactly spaced out. Oh well, it still works well, just not quite as neat.
The neat way: Lets say we decide the roof is to have 8 primary supports that hold up the centre ring, and 8 secondary(smaller cross section) supports that are for stopping the canvas sagging, so we end up with 16 supports.
In order to divide the number of roof slats up evenly into the number of wall 'intersections',
we must have either 16,32,48,64 or 80 'squares' around the yurt (counting the door as two for the
sake of the math). Since we figured that we we going to have '33.65' (rounded to 34) squares
(see above), then we were pretty close to the required 32 that we have just said we must use. Of course, you could also change the number of roof supports to match the walls, rather than change the number of wall slats to match the roof supports. Say you've done what I did, and built your walls, then realising that the number of roof supports you cut is wrong, it's easier to cut another roof support or two than it is to change the wall structure...so long as you haven't built your center 'hub' yet, otherwise it's easier to add or remove a few slats from the wall.
So, the decision I made was to have 16 roof supports, meaning 32 'squares' (two of them
are the door), so with 30 actual squares (32 minus two for the door), we should need 60
slats (plus or minus a few to be cut up either side of the door), and have a resulting tent
size of just a smidgen smaller than we originally said.
The final size is 32x1.41' or 45.12'(13536mm) circumference, and 14.37'(4310mm) diameter
if you keep the "diamonds" perfectly square. Just push the walls out a little more, and make
them a couple of inches shorter, and you still have the 15'-16' tent you started with.
Phew!.
SIDE NOTE: other plans I've seen vary the roof supporting structures from 5 to 45, so there is a
lot of variation here. The upper end of the range is most likely for areas that experience
snow, or that are using extremely thin roof supports, or that like the idea/neatness that
comes from having a roof support on the top of every single wall 'intersection' - ie where
two wall slats join at the top hole, the lower end is possibly for those using a very heavy
canvas, or a smaller tent size that doesn't need as much 'support' to stop sagging) My original
planned roof used 8 as I was goinf for maximum portability, minimum weight, but I modified the
roof before I had even finished building the yurt to be 16 as stated above, and this is a much
better result for minimal weight gain - the secondary supports don't really have to hold much
weight at all, just some canvas. It's the primary ones that hold up the ring. Some other plans
don't use two types of roof support, but instead opt for all of them to be load bearing. This
works too, and will probably give you a roof ring that you can do chin-ups from without any
problems. I hang entire wardrobes of garb from mine with no problems.
Drilling the holes into the slats:
Use a drill press, or be VERY careful to make sure you drill straight thru.
Every plan I read said that a drill press was a good idea. I didn't use one, I was just really careful, and mine worked, but if you are "powertool-impaired" like some of my friends (hi Wolfe!) then you must use a drill press, or get one of your non-impaired friends to do it.
Because the timber I'm using is soft (pine) and gives a bit due to how thin it is, I was able
to get away with the holes being up to 3 or 4 mm off center by the time they came out the other
side of the the 90x35 (drilled thru the 90), but I really strongly recommend taking your time
and getting the holes really straight as it makes lining up the bolts so much easier.
Be accurate and consistent in your measurements when marking them onto your timbers before you drill too as this is also really important.
Assembling the walls:
I've seen plans that specified rivetting, tying with cord, cotterpins, and bolts.
Bolts are so much easier then rivets, and so much stronger than cord or cotterpins. Just make sure that you either use self-locking nylon nuts , or deliberately damage the end of the bolt thread after putting the nut on (this stops the nuts coming off in-transit and getting lost).
I just hit the thread end of the bolt with a hammer a bit as it's cheaper than nylon nuts
(go to the hardware store and check the price difference for yourself - if you are on a tight
budget you'll do what I did).
If you are building a yurt/ger then you've obviously seen how the walls are put together so I
wont bore you any more. It's just a case of inserting 300 odd bolts thru the right holes, putting
all the nuts on (no need to tighten them - actually tightening them is very bad!), and then
making sure the nuts won't come off easily after you damage the thread a bit.
The only assembly point that is ESSENTIAL is that all the slats angled one way are *inside* the circle, and all the slats angled the other way are outside the circle, otherwise the frame won't fold-together in a scassor-like fashion.
Like I metioned, my holes were sometimes up to 5 mm off in places, but the timber has plenty of 'flex' in it so I just encouraged it a bit with a hammer where necessary, and made it fit. ;-)
(don't hit the timbers to hard or you'll break the slats before you even start).
Near the doors, the slats must get shorter by one hole at a time, I fiddled with the shape of the
timbers where they joined onto the door frame, just because I wanted a neat finish. Everyone does their doors differently as it depends what you want.
Traditionally (in the 1600's and earlier) the monguls would have just had felt 'flap' doors, not solid timber hinged ones, but I've seen quite a few that go the solid door (and it's popular in mongolia nowdays!) as it makes for a very secure structure, and is pretty cool.
Mine is a extremely simple frame made from (suprise suprise) 90x35mm pine framing timber. Two lengths the height of the finished wall (5'6"), and two of the desired door width (2.82' or 846mm). I made the simplest possible door frame, and the door is a canvas drapery that I hang over the space. I did that because I wanted portability, and a big solid door seemed like a real pain to carry around. To do similar, I suggest using a large timber screw called a coach screw, two in each corner of the door, , and drill a hole through them, and screw them together.
Other options might be :
1) a 'door' that is still canvas/cloth covered, but is actually
made of lattice like the walls, this is portable and secure, I'm sure you could make a lock for
it somehow.
2) on one plan I saw recently on the web (it might be in the URLs listed below, I
don't remember) had a "double" door, by that I mean solid "french" doors. Two
half-width doors with one hung from each side. It's more portable, and still solid. I'll
probably do this way eventually.
Step 4: * Timber Components - the roof!
Main roof supports:
Cut up the roof supports from 90mmx35mm (just like everything else).
4x2400mm lengths, each cut down the middle makes the 8 primary supports.
2x2400mm lengths, each cut into 4 makes the 8 secondary supports.
I live in a snow-free zone. If you are going to be snowed on you'll probably want a greater
roof pitch (eg make them 9' or 10' long instead of 8' long) AND stronger beams.
Roof/height Support lengths/pitch/angle:
A 15' diameter tent has a radius from the centre of 7&1/2' (which is shorter than the 8' length
of the recommended roof supports), When the roof is angled, the pitch is slightly longer than
the straight radius, so with a bit of math, depending on the actual pitch and size you choose, you might find that 8' is actually to short to reach the centre, or perhaps a bit long. That's ok because it doesn't have to reach the centre. The centre contains a 'hub' that can be anywhere from 1'(300mm) to 3'(900mm) across.
I could say I figured out the exact roof pitch I wanted, used some more math to get the required length of the supports, then used that to figure the size of the ring I needed if the
supports were 8'(2400mm) long, but I didn't. I decided I wanted a 1&1/2' (450mm) ring, and
that I didn't care what pitch the roof ended up at, so long as it wasn't flat.
I stood in the back yard with a half-assembled yurt and no centre ring, put a ladder in the middle, and propped the top ends of the roof supports on the top of the ladder (a 10' ladder I think), and
guestimated that it would be fine.
I built the ring and I put it together, and it's close enough. I could increase the pitch a little, but heck it works the way it is, so why change it?
You do it however you like. :-)
My First yurt was assembed this way, and it assembles fine, but it's more of an art to put together than a science. The next two yurt/s actually turned out a bit smaller (13-14' foot diameter), so I actually found it was necessary to cut up to a 20cm(6") off the roof timbers, so that they don't hang-out-over the edge of the yurt. That's OK too, and I find these are actually easier to assemble!.
Roof Support Connections:
Joining the roof supports to the centre 'hub' is detailed in the hub section, but joining the bottom of the roof supports to the top of the walls can be done in a number of fashions:
1) the first method I used, and the one I currently still use on my first yurt (but don't recommend) involves tying them down. Drill a 6mm hole thru/across the bottom end of the roof supports about 30-40mm (1&1/2") from the end, and tie a loop of strong woven cord (eg 4-5mm nylon venetian blind cord) that is about 150mm (6") across through that loop. The loop can then just be tied around top of the wall , when the support sits on the wall. I currently do that, and also extended the loop with about 450mm (1&1/2') of cord that can be lashed to the wall further down so the joint is secure (this bit works well enough).
2)What I did on yurt numbers 2 and 3 was to use a steel "pin" on the top of the wall, and have a holedrilled into the rool timbers at an angle matching the pitch of the roof. the steel pin on the frame goes into the hole on the roof timber, and creates a joint. have a look at the pictures, and you'll see what I mean.
Step 5: Metal Components - the roof hub
Roof Hub Options:
The whole purpose of the 'hub' is simply a way of connecting the centre of the roof all together
while also giving a centre 'vent' or 'port' for circulation/ventilation/smoke/watching the stars.
1)Traditionally it would have been a ring of saplings that the roof saplings were lashed to, but that's not something that's easy to dissassemble, and reassemble.
2)Today the most common form (I've seen it in other yurts) is a 3 layer "laminate" ring made of two layers of ply and a middle layer of wedge shaped timbers, the result being that there are squares to push the roof poles into. (the roof poles need to have an angle cut into them to use this form). I have seen this form work well and would recommend it if you have timber skills,but not metal working skills, but I did not use it myself.
3) A timber "ring" formed by building a vertical laminate up from long thin lathes of timber
which are steamed and bent into a ring, and glued and clamped together, with more lathes of timber being added into the inside of the 'ring' until it has a thick-enough profile/width.
This is lighter than 1), doesn't require the roof supports to be weakened by cutting onto an angle,
(only rounded off to fit the large holes that are then drilled into the ring laminate), and is
probably the best form to use if you ignore the construction. It's just really hard to make and
get it to work right.
4) Finally, The form I ACTUALLY used: I own a welder, and have reasonable metal working skills, so I made a 450mm (1&1/2') ring from solid metal 15mm rod (actually an ocatagon, but it looks like a circle if you don't look to closely!), and off of that I welded 8 large (15mm round) 'prongs', and 8 smaller 8mm round 'prongs' (one for each of the 16 roof supports), I arranged these so that they were angled down at the same pitch as the roof is supposed to be (whatever you worked it out to be for yout tent, I just guessed).
To join the roof timbers to this steel "star", I then VERY CAREFULLY drilled a very deep 16mm or a 9mm hole long-ways straight into the end of the roof supports/timbers. (I bought 2 spade bits(16&9mm) and a "spade bit extender" in order to drill a really deep hole.
I drilled about 200mm into the timber end for the large supports, and made the large 'prongs' 220mm long, and 100/120mm for the smaller 'prongs' ).
The idea is that the roof supports slide over the 'prongs', and produce a very strong joint. This
works really well, and I found it easy enough to make.
I made this joint up..I've never seen anyone else use this method on their yurts/plans..I just
guess no one's thought of doing it this way before...or they don't like it because it's not
"traditional" enough for them.
My 'hub' (the first yurt) is really rusted - because it was recycled steel in the first place, but the newer yurts I made were painted with zinc-impregnated (rust inhibiting) paint, which keeps them looking reasonable.
Step 6: Metal components - - bolts, pins, pegs.
The remaining metal components that need to be manufactured in some way or another are:
Metal Pins
- for pinning the doorframe to the wall lattice. these are just bent steel 6mm (1/4") rod. they need to be removable so that the yurt can be dis-assembled, and re-assembled easily. I made the ones in the picture from a piece of mild steel 150mm long, with a 50mm (2") handle/bend at one end.
Newer ones I actually make by purchasing galvalised tent pegs (just like the one shown), and cutting them in half. It's easier, and they don't rust so much.
The 3rd picture shows a close-up of the pin assembled through part of the wall lattice and door frame/s.
Bending them is actually really easy with one end in a bench vice and hitting the other end with a hammer (start lightly, don't rush it, or you'll create cracks).
Roof Eyelets, and Hooks.
- the hooks are actually an option, but something I find makes it easier to assemble the finished roof.
At each of the 16 points around the roof edge where the timber/s point to (ie equidistant), your should put a brass "puch-through" eyelet which is large enough to lace your cord through.
Every second of these should have an "S-hook" fitted (see the second picture for mine) so that you can easily hook tie-down rope through it when you are assembling the yurt. I custom-made mine out of large calvanised nails, bent into a funny U shape, such that the head of the nail will not fit through the brass eyelet in the tent, but the shank will.
Bending them like this, I can permanently fit them to the roof, and not lose them, but can still lace the rope around the open end easily.
Pins for connecting walls to roof
Look closely at the last picture in this set, and you'll see that the vertical part of the "pin" appears to join onto the nut/bolt that goes through the wall lattice X. It's actually all the same bolt, just a long one, with the head cut off.
The bolt is a 1/4"(6mm) diameter, 120mm long bolt with thread on about 1inch of the shank.
By threading a nut on as far as it will go, and bending it almost exactly where the thread stops next to the nut, you get a L-shaped pin which is threaded on the short-section, and has the nut permanently locked into the "corner" (due to the distortion of the thread that occurs while bending the bolt right next ot it).
It's actually quite easy (just bend a bolt)...it's just hard to explain.
These special L-shape bolts are used in-place-of the short bolts at the top edge of the roof, but only on every second joint. (where the timbers sit).
Step 7: Canvas components - the wall!
Buy a piece of canvas that's as long as your tent is round, including the door, plus a bit spare - perhaps 30cm( 1').
The simple version (my first method) :
I didn't have to do anything else to mine apart from hem the two raw ends, and put a few brass eye-lets into the hemmed ends. To keep it up, it just has the top few inches hung over the wall,
and held in place by the weight of the roof supports (bull-dog clips during assembly).
At the door, the canvas end is just taken thru the door, and string/light rope is used to lash
from the eye-lets in the end seam back to the lattice on the inside of the wall, which holds
the canvas tight around the outside of the wall when these are tightened a bit. The wall itself
can then act a little like a "tension band" ..the tensioning ropes are still a must though!.
The longer version (my perferred method now) :
background: my yurt's are constructed such that when all the timber frames are together, and the roof timbers are fitted, the top edge of the wall/lattice has a roof timber fitted on every second X joint. This leaves every second bolted joint free, and accessable for hanging the wall from.
To do this, I sew a reinforcing to the canvas just below the point that would be matched onto the joint in the wall, and sew a wodden "toggle" , via a strong nylon cord into the reinforcing. The wall canvas can then just be hitched-up onto the wall timbers, and hung there from the wooden toggles.
This gives a result that is invisible from the outside of the tent, easy to erect in a repeatable way, and still within the spirit of the construction.
Note about Tensioning ropes:
These tension ropes/cords (I use two bands, each of 3mm woven venetian blind cord) must be
permanently fitted to the timber walls before the camvas walls and roof are put on. I will go into how these cords are tied to the wall at the end of the Instructable. During test assembly though, you can just wrapt them round the whole yurt, and at least the top one must be partially tightened, or the timber lattice walls will fall down. This must be done before any weight is put on them like when you put the the roof timbers us, or the wall canvas is put on.
Step 8: Canvas components - roof
Roof Canvas Construction:
Buy 16 metres of roof canvas at approx 6' wide, and cut/sew it as per the picture below.
Notice how there are two sections 1800(6') wide, these are the full width of the canvas. The two smaller rectangles (top, and bottom) are from the same length of canvas, just split down the middle to half their width.
The "wedge" that is shown missing needs to be cut out and sewn up so that the roof canvas becomes "cone" shaped. to match your roof pitch.
I actually find it easier to just assmemble the whole timber structure in the back yard at this point, and hang the completed flat circle onto the framework/roof. Using a stepladder, and lots of strong pins, I can then pin the roof so that it's clear exaclty how much canvas (the wedge shape) needs to be removed, leaving the roof as a "good fit".
For the simple version:
Do a final Trim, and hem of the outer edge only after you have removed the "wedge" and sewed that bit up, located the roof on the structure again, and finally walked round the outside with a piece of chalk drawing a line where you think the hem should go. I didn't, and no matter how I tried to make it an exact circle, the hems are still a bit uneven. Oh well.
For the more complicated (but preferred) version:
I sew a flat and straight "band" of canvas, about 20cm (6") wide, all the way around the roof edge. This fabric is deliverately NOT curved to match the roof, it is instead straight to match the walls, and it hangs from the bottom of the roof, down the walls, and fully covers-over the wall->roof joint making is really wind/rain/sleet/bug/insect proof.
This also gives a nice professional finish to the outside of the yurt.
I only did this in my 3rd yurt, for which I forgot to take pictures, but believe me, it's really good having a nice air/wind-tight seal there ( my current yurt, the oldes one doesn't have this, and gets a bit drafty). Most of the pictures in this instructable are from my second yurt, which has "dagging" (ie zig-zag square shapes) around the roof edge, this was at the request of the "new owner", and is a bit prettier, but also less traditional, and not as airtight as the 3rd yurt with a solid band.
FINALLY: Don't throw out that "wedge" that you cut out from the yurt.... Cut the biggest equilateral triangle or circle that you can from it, and use that as the "cap" to go over your vent hole.
You'll need at least 24' (8m) of cord/rope to hold that 'cap' in place (three ropes that go from
the tips of the triangle or edge of the circle out to the the walls to be tied off.)
Step 9: Assembly - putting it all together/up
The best way is to just give it a go and try putting it up. Expect the first few times you do it
to take quite a while. You'll need two or 3 people, but no more. I can do it on my own now, but
it's still easier with two.
Follow along through the pictures below for a detailed step-by-step pictographic guide with text hints. Seriously, looking at all the pictures is worth it - there are about 50 of them on this step! That's gotta be worth more than 1000 words. :-)
Hints:
*) You'll need a "tension" cord/band (or even two) to go right round the top (and optionally
the middle) of the wall. It's important that you put this in place before you put the roof
supports on. Some people use a band of canvas that is a few inches wide, I use a 3mm venetian
blind cord round the top and middle of the wall (a thicker slat might not need two tensioners).
I use two tensioners just to reduce the slight "bow" in the walls after everything is in place.
I bought a complete 100m roll of cord and it was cheaper than buying 40m at the by-the-metre
price, so I have plenty for things like tying the roof down.
  • you can fit the tensioner cord permanently to the timber walls, by tying it onto each bolt-head all the way round the wall, which is a great idea, and makes putting it up so much easier too! See the pictures for details.
*) put(or keep) the tensioning cords/ropes in place before even getting the canvas out of the car. I
always forget them, and then have to take the wall canvas off again in order to put them on. You can put them under, or over the wall canvas, I always prefer under, but others use over, it doesn't really matter, and is just cosmetic.
*) If the wind is light, hang the wall canvas over the walls before putting the roof supports on, and hold it in place with bull-dog clips (or stitch little pockets for the canvas to hang from). If the wind is strong, the wall canvas can act like a sail, and blow your tent away, so leave the canvas untill you have the weight of the roof timber/s to hold it down.
*) Put the centre ring up by putting in 3 opposing main supports first, the ring will then
hold itself up, and the person who was holding it up will not get such sore arms. Try not to stand under the centre-ring very much while assembling it, because getting hit in the head with a large heavy object (if it falls down unexpectedly) is unpleasant and dangerous.
*) Start to pull the roof canvas over the roof, and at the same time have one or two people
inside the tent with long poles (borrow a couple of minor roof supports for this if necessary),
get them to use the poles to push the canvas up and over the roof. It's easier than trying to
just drag it over with ropes.
*) Get a tarp, or large black-plastic dropsheet for your floor, you won't regret it. Cut a circle
about 3/4-1' (~200-300mm) larger all round than your tent, and fold the sides up inside your tent to
prevent water getting into the tent. I origninally used 2500mm wide black-plastic "concrete underlay" plastic sheet (as it was cheaper than a 15' square tarp) and joined it together down the middle with
that wide-brown "duct-tape". It sticks to that black plastic like glue, and is waterproof
enough to survive a month underwater if necessary. The longevity of the black plastic isn;t great though ( a dozen uses or more over 5 years) before the ground/rocks tear it up) , so having a tarpaulin floor is good, which is what I now use - I found a local canvas and tarpaulin supplier who made it to-measure for the circular shape for only $AU100 (about $US150) .
*) In anything except nil-wind conditions you definitely will want to take along a few tent pegs, I use 8 or them, placed in the ground directly as the bottom of the walls, and roped to the roof. (ie tie the edge of the roof canvas to the tent pegs) by putting the eye-lets and S-hooks every so soften around the roof hem, and zig-zagging the tie-down rope between these eyelets with the S-hooks and the tent-pegs set at the same spacing around the bottom of the wall. You end up with this nice regular tringular pattern visible around the edges of the yurt.
*) Otherwise (ie in nil-wind conditions) you can hold the roof canvas down with a noughts-and-crosses # pattern of ropes across the roof.
*) take three times as much 'cord' or 'rope' as you think you'll need, use it for:
- tensioning rope/s (about 15m per tensioner - I use two, so 30m)
- zig-zag tie-downs (roughly every meter round peremeter means 35-40m) or # roof ties (roughly 25-30m)
- cap ties (about 8m or more)
- tying wall canvas in place (either side of the door) (about 5 m)
(I bought 100m and use just about all of it somewhere. I even managed to not have to cut it, so it's
still useful for other things for the other 350 days of the year)
Now, the assembly pictures! There are a LOT of these, in the order of assembly, so just have a look!
1-40 of 217Next »
Ira7 says: Sep 12, 2012. 5:54 PM
Thanks for your time and effort with this, Dave. My name is Ira, and I live in South Florida.
I appreciate your efforts in posting this instructional!!!
A few years ago, I built an elaborate Teardrop Travel Trailer, an itty bitty thing that put me in the poorhouse and sleeped two people comfortably--if those two people were cadavers--plus a It was the coolest looking thing you ever saw, but TOTALLY impractical for proper camping. (Plus, you have to tow it.)
It had an elaborate kitchen/galley built into the rear hatch with sink, propane oven and stove, microwave, and a thousand other gizmos--all thing you don't really need to build INTO a trailer.
I nhave a tiny Suzuki Sidekick, soon to have an elaborate roof rack, and the first sensible camping solution I thought of was a Yurt. Somewhere in my house, I have a copy of one the VERY few books on building a Yurt--but I can't find it yet and my wife won't HELP me find it yet. (She ain't the camping type.)
Anyway, I want to build a Yurt, but here are my issues/questions about your designs:
1) I want to build a 12-footer at most. I know the walls will be short, but that's okay, because I'm short too. Only 5' 2". I plan to be using it solo 99% of the time in the Everglades, and if my wife decides to join me one weekend, I can still squeeze her in there. (Although I think I'm going to make her stand outside and watch for gators.)
So I need specs/measurements for a 12-footer.
2) There is no way in hell I can strip that much lumber myself. But I was also thinking, isn't there a plastic or PVC alternative for at least the lattice work? There has to be a source for this dimensional plastic with a certain tactile strength that will work--plus, it would be a ton lighter than wood.
And if there ISN'T a plastic solution, isn't there a 4 by 8 ply sheet solution that will work, cutting strips from that, albeit having to heavily treat all the edges and surfaces?
My optimum solution is to find the strips in the correct length at Home Depot. I believe the 12' yurt, or maybe it's the 10', which is okay too for me, only requires a 4' wall--but how does that relate to the math on the length of the strips needed for the lattice?
In other words, can I just buy 10' lengths of appropriate pine at HD...cut them in half to 5'...heavily treat them...and have that length work for me for a 10' or 12'? (Walls only--forget about the roof for now)
tudgeanator in reply to Ira7Feb 24, 2013. 5:44 AM
I know it's a bit late, but if you still need help with the measurements: http://simplydifferently.org/Yurt_Notes?page=1
This page has a VERY useful calculator for everything!
k5cqb in reply to Ira7Sep 26, 2012. 3:03 PM
Here is a PVC yurt, looks like you'll have to come up with your own measurements but it looks like it works.
k5cqb in reply to k5cqbSep 26, 2012. 3:03 PM
Doh! Here's the link;
http://www.youtube.com/watch?v=0sYpB3Zeiqo&feature=g-all-u
Ira7 in reply to Ira7Sep 12, 2012. 7:22 PM
Forgive all of my typos.
I'm EXHAUSTED tonight.
houseoexcess says: Aug 4, 2012. 11:25 PM
Any thoughts on using cedar? I'm leaning this way for the natural rot and insect resistance... obviously more expensive but I figure it would be built to last, and worth it.
MikeCicc says: Jul 26, 2012. 9:35 AM
Sweet! I spent a month in Mongolia last spring and got to sleep in some of these babies, and we kept saying, "Man, we should build one of these back home!" Way to go.
sallyab says: Jul 7, 2012. 11:58 AM
I can't wait to try this. The only thing I'm not clear about is what the short prongs on the roof circle are for. I wonder too about putting windows in. A sheet of plastic within the canvas wall would be enough no doubt, and could be fancied up to not just give light but open too...Thank you for this manageable and inspirational Instructable!!! :-)))
irm224 says: Feb 17, 2010. 8:18 PM
 Sorry but this sounds really confusing.  I thought it was easier to put yurts together, and I know there are more ways to put one together so what way is easier??
sallyab in reply to irm224Jul 7, 2012. 11:52 AM
You can't have read it thoroughly. It's very well explained and easy to follow. There's nothing in the least confusing in it.
You can't have read it thoroughly. It's very well explained and easy to follow. There's nothing in the least confusing in it..
dzent1 says: Jun 18, 2011. 3:19 PM
I have been rather astounded at the snarkiness and acid tone of some of the comments about David's yurt. It's an awesome feat of building that he didn't have to share; many of us are extremely glad he documented the process so well.
You guys who quibble and sniff about terminology just come off as pathetic. I don't see any of you publishing your "correct" versions anywhere here, especially in this kind of detail - are you just so hungry for some kind of validation that you have to p*ss on the welcome efforts of real makers like David? Just sayin'...
rgrant4 in reply to dzent1Jun 15, 2012. 3:54 PM
I love David's Yurt. I am interested in building one, though I am not sure where to source out the metal hub or some alternative.
sd-shit in reply to dzent1Nov 1, 2011. 3:56 PM
well said dzent1, I love the info here and I'm on to off the grid living, peace, love and unity!
zzoe in reply to dzent1Sep 26, 2011. 9:16 AM
Hear, hear!
mista.v says: Aug 8, 2010. 8:19 PM
If we can't exactly weld or anything, is it best to try to go through all the work of a wood hub or to make one with PVC or other pipe?
davidbuzz (author) in reply to mista.vAug 8, 2010. 11:24 PM
[sarcasm] If I can't fly an aeroplane, is it best to have someone else fly for me, for me to learn to fly, or for me to take the bus? [/sarcasm] Please just think about what you are asking before you type them, alright?
zleebme in reply to davidbuzzNov 26, 2011. 12:08 AM
LMAO :D
triumphman says: Apr 26, 2012. 1:04 PM
some people are too wierd to make negative comments, I don't see any of thier 'ibles either! Strange how they can criticize from behind an internet web! Great job mate!
dare2baware says: Mar 5, 2012. 3:13 PM
WOW!! I could easily live in a yurt. ;-)
pheenix42 in reply to dare2bawareMar 19, 2012. 1:27 AM
Yep, works VERY well for the nomad tribes of Asia! And, they've been doing it for several thousand years, too, so there's something to be said for the design, eh?
sugarsnout says: Mar 5, 2012. 7:47 AM
I really thought this was a cool instuctable. Until recently, I din't even know what a yurt was. My friend sent pics of his and I googled it.
I love this website and find so many great things to make. I am dissappointed at how some people make harsh or stupid comments about an authors attempt to share great ideas. I have lots of great ideas but am hessitant to share here.
Sharing an instructable plan or how-to should be an inspiration to others...if you want a perfect step by step plan of a perfect product then go buy a kit.
I believe that anyone who browses this site should have a spark of creativity or at least interest and should be thankful for an idea or another way of approaching a project. When others offer suggestions..it only makes it easier for another by tapping into their learning style . Critisizing or putting someone down for choice of pics or words is just wrong...(see nice comment policy)
i know how to make a traditional inuit tent in a couple of styles, perhaps I may combine the two and come up with something else.
THANKS FOR THE GREAT IDEAS AND INSTRUCTIONS...FAB PIC OF THE ORIGINAL MONGOLIAN HUT.IT INSPIRES ONE TO ADD COLOUR OR SOMETHING PERSONAL BY THE BUILDER!! GREAT JOB!! i HOPE YOU CONTINUE TO ADD MORE IDEAS:)
sodaking1 says: Jan 17, 2012. 6:38 AM
it all comes down to this haters going to hate. the only thing I can see is people finding fault with something they can't do. the guide look great, who cares what the first pic is or the last pic for that matter. The creator of this, did something that I only wish I could do. Its like the guy said, it's not about what my finished product looks like it's what yours looks like when its finished. Personally I would love to try this and have my own tent that's big enough but durable to move with out distorting the thing
tricker69 says: Nov 28, 2011. 6:23 PM
Awww Geeez, looks like Ive got "another" project coming in my near future, lol. Great instructable. The wife and I have been pricing yurts and been getting sticker shock at the commercial sites. I just want to say thanks for making it look so easy, a caveman can do it. Looks like a great winter project to enjoy in the spring and summer camping season.
the doctor who says: Sep 22, 2011. 8:30 PM
i like it but needs clearer pic
TinkerWorkshop says: Aug 8, 2010. 7:55 AM
FYI, the yurt in the presentation image (the one with an orange door), and the one described in the tutorial are not the same. The yurt with an orange door, the professorially made one, uses completely different technology to be built. The yurt (ger) with an orange door uses two-poles-ring setup, the traditional Mongolian way. Would it not be more useful to have an image of your final product instead of a yurt not made by you?
Valas Hune in reply to TinkerWorkshopAug 1, 2011. 5:26 PM
What is wrong with you guys????
The first thing that is mentioned in the instructable is that the yurt with the orange door isn't his but an original and what the final outcome should be and then he goes into detail about how to do it.
you guys are complaining that you read it and it wasted your time? you clearly missed the first thing he said.
"this is a yurt made by real mongolians! (not by me). You can see mine in the instructable!"
davidbuzz (author) in reply to TinkerWorkshopAug 8, 2010. 7:21 PM
All images in this instructable have mouse-over text that tell you precisely what it is, including the picture you mention. Yes, that's built by mongolians, in mongolia, and it's purely so peoplke can see that their finished product *should* look like when they are finished. It's for inspiration and motivation.
hannahelastic in reply to davidbuzzAug 11, 2010. 6:12 AM
I gotta agree with tinker, using that image as the very first photo is misleading. It's cool you included it for inspiration, but maybe right there isn't the best place for it.
TinkerWorkshop in reply to davidbuzzAug 8, 2010. 8:12 PM
With all do respect... Your tutorial does not describe the way to build the yurt in your title image, building process is quite different. The reason I've looked a the tutorial is because of the first image. I found it quite misleading after looking through the tutorial.
Valas Hune in reply to TinkerWorkshopAug 1, 2011. 5:28 PM
first thing he says in his instructable is:
clearly you didn't read through it.
davidbuzz (author) in reply to TinkerWorkshopAug 8, 2010. 11:26 PM
(removed by author or community request)
TinkerWorkshop in reply to davidbuzzAug 9, 2010. 7:34 PM
Great reply. All your "professionalism" just went out the window. Congratulations.
cyprian916 in reply to TinkerWorkshopAug 8, 2010. 10:27 AM
agreed it would be better and also i see no image comparable to the real yurt's picture I.E. a nice picture of the finished product.
makalove in reply to cyprian916Aug 8, 2010. 11:36 AM
[nods] what they said. using somebody else's finished product for your lead picture is misleading. then to discover that you don't even have a picture of your finished product at all was disappointing. please consider revising your instructable.
davidbuzz (author) in reply to makaloveAug 8, 2010. 8:58 PM
I agree that not having a picture of my version of the 100% assembled "finished product" is unfortunate, but the simple reality is that I don't have a good one to upload at this time. Attached is a small picture, of a "tent city" with my most recent your ( red roof, white walls) on the left.
tim_n in reply to davidbuzzAug 9, 2010. 12:17 AM
Appreciated to see your Yurt, but all in all it's a circular folding tent which to anyone else looks like a Yurt, but obviously you've attracted some Yurt experts. Shame they didn't post an instructable on Yurts first showing their take. Very much appreciated, ignore the negative comments, I'd prefer to see the lattice bits because that's the most complicated bit to make. Good 'ble and remember guys there's a 'be nice' policy!
keebmn82 in reply to davidbuzzAug 8, 2010. 9:55 PM
I take loads of pain killers and even I understood your point. So I dont think its misleading at all. I think some people are overly critical. Great Instructable! Thanks for posting it.
unusedprofile says: Mar 13, 2011. 11:04 PM
Damn man, thats a nice yurt! ive seen smaller ones used for camping but damn, thats awesome. im going to construct one of these for the summer and go camping.
phazerave says: Jan 23, 2011. 10:35 PM
very nice. but I have one question, would it withstand burning man... everyone builds geodesic domes, I want a yurt!
1-40 of 217Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
