Build yourself a portable home - a mongolian yurt
Step 1Overview of the parts and process.!
I'm going to cut right to the chase, and assume you know the following (in principle):
1) What a yurt is, and what it's made from.
2) How all the components should look when together.
If you've ever seen a yurt in the flesh, or photo's, or read a bit about them, that's enough.
As you can see from the photo/s, there are a few major components, so I'm going to write about each of these in turn, with some background info, and how to make them, and after that I'll show you how it all comes together for the assembly!
  • Dimensions and background.
  • Timber Components
- wall
- roof
- door.
  • Metal Components
- roof hub
- bolts, pins, pegs.
  • canvas components
- wall
- roof
- roof cap
  • Assembly!
below are a few sample pictures of some components, just for intereste sake:
« Previous Step   View All StepsNext Step »
3 comments
Aug 8, 2010. 8:19 PMmista.v says:
If we can't exactly weld or anything, is it best to try to go through all the work of a wood hub or to make one with PVC or other pipe?
Nov 26, 2011. 12:08 AMzleebme says:
LMAO :D
Dec 6, 2009. 7:25 PMravenbird says:
Hi,
I'm going to be building a yurt this spring out of 1/2" pvc pipe.  Do you make these center hole pieces for sale?  I figure that the ends of the pipe would fit perfectly on the spikes and make the job incredibly easy.  Also, how wide is the hole?
Thanks,
Raven
Feb 3, 2010. 9:50 AMravenbird says:
Thank you very much for your generosity in giving me the dimensions that I will need to have that center ring created.
I am building 2 x 16' Ger this spring. One as storage and one for a workroom.  The workroom will be fully insulated.  We get a lot of snow here. I have decided on wood instead of pvc.  Collecting stuff and looking forward to it.
Buying stuff on sale, new, and $300 worth of tools included in the pricing (wanted them anyway) the two Ger are less than $1,000 for both of them - less than $500 each.
Again, Thank you very much,
Raven
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
42
Author:davidbuzz
