Step 7Canvas components - the wall!
The simple version (my first method) :
I didn't have to do anything else to mine apart from hem the two raw ends, and put a few brass eye-lets into the hemmed ends. To keep it up, it just has the top few inches hung over the wall,
and held in place by the weight of the roof supports (bull-dog clips during assembly).
At the door, the canvas end is just taken thru the door, and string/light rope is used to lash
from the eye-lets in the end seam back to the lattice on the inside of the wall, which holds
the canvas tight around the outside of the wall when these are tightened a bit. The wall itself
can then act a little like a "tension band" ..the tensioning ropes are still a must though!.
The longer version (my perferred method now) :
background: my yurt's are constructed such that when all the timber frames are together, and the roof timbers are fitted, the top edge of the wall/lattice has a roof timber fitted on every second X joint. This leaves every second bolted joint free, and accessable for hanging the wall from.
To do this, I sew a reinforcing to the canvas just below the point that would be matched onto the joint in the wall, and sew a wodden "toggle" , via a strong nylon cord into the reinforcing. The wall canvas can then just be hitched-up onto the wall timbers, and hung there from the wooden toggles.
This gives a result that is invisible from the outside of the tent, easy to erect in a repeatable way, and still within the spirit of the construction.
Note about Tensioning ropes:
These tension ropes/cords (I use two bands, each of 3mm woven venetian blind cord) must be
permanently fitted to the timber walls before the camvas walls and roof are put on. I will go into how these cords are tied to the wall at the end of the Instructable. During test assembly though, you can just wrapt them round the whole yurt, and at least the top one must be partially tightened, or the timber lattice walls will fall down. This must be done before any weight is put on them like when you put the the roof timbers us, or the wall canvas is put on.
| « Previous Step | View All Steps | Next Step » |
comment
Add Comment
Add Comment
