loading
Step 14: Shaping the hull. (An added mini-instructable.)
Hello again. After I published the original instructable, I wished I had posted better instructions on how to carve the hull out of the blank block of wood.
So I am adding this “Mini-instructable“. I broke down the entire process into the individual steps that I use to shape the hull. Since this is just a demonstration model I did not worry about getting the dimensions exactly right. (Or this would be a really short and fat little boat. This is also a larger scale than you would use if you were putting it in the bottle.) I just wanted to focus on illustrating the technique.
NOTE! Although I used a belt/disc sander for this illustration, I used to do the entire process with just the sanding drum on a Dremel tool. In fact, if you are carving a smaller hull to use in a standard sized bottle, the Dremel type tool is a better choice.
#1. Draw the basic side profile and top outline of the hull onto the block of wood.
#2 & #3. Sand away the front of the block to form the profile of the bow.
#4 & #5. Sand away a little from the bottom of the stern. You have now completed the profile.
#6 , #7, #8 & #9. Form the top outline of the front of the hull. You are just making flat shapes, keeping the block level with the sanding disc.
#10 & #11. Rock the bottom of the hull on the sanding belt. This is your first curve. You are just trying to round the bottom of the hull, so that it looks like the letter “U” when viewed from the front or back.
#12 & #13. Remove the sharp edges on the front of the hull that were created by the earlier sandings. Just blend everything together.
#14, #15, #16 & #17. Using the sanding drum on a Dremel tool. Shape the area where the rear of the hull narrows down to the area of the rudder.
#18 & #19. Using sandpaper smooth everything out. Notice that I had the sandpaper flat for the soft curves of the bow, and I folded the sandpaper over to create a shape that matched the area of the stern that needed sanded.
#20 Finished!
I hope this helps answer any questions that you may have had about shaping the hull. Just take your time, break the process down into simple steps, and you can make this happen!
<p> I have made a few over many years. My high point was putting a nail through the stopper at right angles inside the bottle. That resulted in a puzzle for many. Sadly my grandson dropped and broke the lot. Sad memory indeed.</p>
What is the best way of attaching sails to the model ship in a bottle
<p>In my experience, a little Elmer's glue on the side of the sail, and just glue it directly to the mast. The <a href="http://www.modelsinbottles.com/2015/12/first-build-inauguration-part-3.html" rel="nofollow">third paragraph after the second picture in this post</a> gives a little better detail.</p>
<p>Love your explanation, wonderful instructable!</p>
<p>When I was about 13 or 14, I made a miniature Spanish galleon in a plastic aspirin bottle. It was nowhere near as elaborate as this, but it drew a few compliments and puzzled looks. I made the hull out of balsa wood and shaped it so that it could be angled through the fairly wide mouth of the bottle, even though it looked like it would never fit. I made the masts out of toothpicks with the booms just short enough to fit and put them in place with tweezers.</p><p>All the various parts of it looked pretty primitive, but as a whole it did give a nice illusion of a miniature ship in a bottle. </p><p>I always wanted to try making using one of those miniature alcohol bottles. I made a schooner hull that fit through the neck, but that was as far as I ever got.</p>
<p>First&hellip; Let me thank everyone for their very kind comments! <br>I cannot believe that it has been almost four years since I made the ship and posted this instructable. It was the last on of these that I have made. Although I have not built one of these for some time, I find that I am constantly on the lookout for suitable bottles, and I have just found one! <br><br>I recently purchased a bottle of &ldquo;Big House&rdquo; Bourbon. This bottle does not have a screw top cap, and the opening is slightly oversized. So I think that it may be a good choice for your first attempt at putting a ship in a bottle. <br><br>When I am finished putting a ship in this bottle, I will post a photo for you. <br>Thanks again for looking at my instructable!</p>
<p>What a great tutorial and follow up. Every <a href="http://www.modelsinbottles.com/p/builds-and-tutorials.html" rel="nofollow">ship in a bottle on this list</a> was inspired originally by your work, since it all started here with your Instructable. You can see the obvious similarities in my first ship to the one you built here.</p><p>Anyway, I just wanted to say thanks for helping me launch a new hobby.</p>
<p>Here is the ship in the Big House Bourbon bottle. </p>
<p>Way cool!</p>
<p>That is awesome! looks really sharp</p>
Thanks again for your compliments! I am using this opportunity to answer 2 of the questions that I have been asked about the rigging. I wanted to use photos to help explain, and I was unable to do so when I replied to his message.<p> Question 5. I have (hopefully ) included a color coded picture (#1) of the rigging. Start from under the hull and work forward. In picture #2 you can see the holes that were drilled for the main rigging lines. The green dots are where the holes for the square topsail rigging will be drilled. These holes should have been drilled at the same time as the rest, but I forgot, and drilled them later. </p><p>Question 6. Picture #3 shows where the sails were glued. The sails are secured with a dab of glue to each other in the front of the boat, to a boom, or the nearby thread in the case of the top sail on the rear mast. This step is to just lock the sails into the proper position.</p><p>Thanks for looking at my instructable, and best of luck should you try to make one! <br> <br></p>
<p>Oh my god it is absolutely crazy how similar our pictures look when we show <a href="http://www.modelsinbottles.com/2015/12/second-ship-in-bottle-sophomore-part-3.html" rel="nofollow">how to do the rigging</a> (about half way down that page). We used the same four colors and everything!</p><p>This is the best Instructable I've ever seen on this site by the way. Thank you so much for doing it.</p>
I there. I was just wondering, if you had a round bottle, how exactly would you get the ship to stay upright? I've heard people use putty, is this the only option? Thanks for the guide, I'm definitely going to use it.
<p>I have a <a href="http://www.modelsinbottles.com/2015/12/first-build-inauguration-part-3.html" rel="nofollow">diagram for putting a ship in a round bottle</a> about half way down this page. I used two strips of wood with wood glue (the exact wood glue can be found on my Tools and Supplies page)</p>
Hello, I always used blue putty when I put a ship in a round bottle. The putty was molded in roughly the shape that I wanted to end with, and then I would cut it into strips narrow enough to fit through the opening of the bottle. Once inside, I used a bent wire to press the seems of the strips together, and create the surface of the water. <br> <br>I did not make a full hull for the ship, only from the waterline upward. And the ship would just be glued to the top of he putty. I would then use a little white paint on a very thin wire to paint the wake behind the ship. <br> <br>Thank you for looking at my instructable, and I hope this helps. <br>
<p>This is such a well done 'ible, I might actually be able to do this. First, I need to find a suitable bottle. I've searched through thousands of old apothecary bottles on ebay but most have very narrow mouths. How large (tall) a bottle is typical and how wide a mouth can be found on bottles like that? I was hoping to find a bottle about 8 or 10&quot; tall with a mouth at least 1&quot; diameter. Any suggestions as to what kind of bottle would be like that? Liquor bottles? Medicine bottles? Thanks!</p>
<p>I've been getting my bottles from hobby and/or craft stores. I've had good luck with Hobby Lobby. I usually use something close to 16 - 24 oz, but you can use anything really. </p>
<p>Thanks for this instructable. Could you append a list (with pictures if possible), of the various tools you used? Are they custom built tools (i.e. the stuff you use to work inside the bottle? Coat hangers perhaps?</p>
<p>Sorry this is five months ago, but I just saw this and goaly hasn't responded to you yet. Here's a <a href="http://www.modelsinbottles.com/p/supplies.html" rel="nofollow">list of tools and materials I use when I build my ships in bottles</a>.</p>
<p>Hi, the detail on your work is commendable, but do you have a comprehensive list of materials needed? I noticed that you mentioned the necessary materials only during the corresponding steps, which makes it hard for a first timer (me) to compile the needed items.</p>
<p>Hi, I realize you asked this question a year ago, but haven't received an answer yet. Here's a <a href="http://www.modelsinbottles.com/p/supplies.html" rel="nofollow">list of tools and materials I use when I build my ships in bottles</a>.</p>
<p>Once more unto the brink. I used your pinned hull method again to make a gift for a friend. This is the Irish immigrant ship Dunbrody. It took me about twenty hours. I chose to do the sails stowed so it would show off the rigging. </p>
<p>Nice, what did you use for the water in the bottle? </p>
Who can build me a boat inside a Corona bottle???? With a little bit of the beer liquid inside of the boat so it can look like the boat is inside floating on the liquid <br>Email me at 1211anakaren@gmail.com
<p>Nice job on this Schooner! </p>
Quick question. Once you get the ship in the bottle and the masts raised do you glue the other edges of the sails? Or, do you just leave the one edge glued? Also, what kind of glue do you use for the sails? Thanks!
If the sails stayed where I wanted them to, I just left the one edge glued. If they tended to curl at an odd angle, I glued them to something nearby, such as a toothpick boom or one of the thread ropes. (See step 12) <br>Also I just used Elmer&rsquo;s all purpose glue for the entire project. <br>
It would really be awesome with blue water (putty) under the ship, instead of a wooden stand. FYI
Nice Work, congratulations! <br> <br> Would your like to know how to get a ship in a 34lts bottle?, I have been working on it... I have already deal with 64 in total.... Now I am catching the big fish. Keep working on your projects it is a really nice thing to do.... I just got me this page randomly. Now I am a member because of you, ahoi for that. <br>I do not use any mashines (anything with electric power/at least on the two last projects), just the old methods... it takes longer but I think it has something special. <br>I got me from Spain a glas baloon. It is a really crazy project if you think about, that I am making also the skeleton for that.... <br> I usually do not spend money to getting bottles... but that one is like more that I can eaven imagine... <br> <br>I hope you are doing great, lets get in contact... <br> <br> <br>Martin
This is a great Instructable! Very impressive! i can't wait to try this out. Thank you for putting it up.
I did another for my son, I continue to be greatful for this excellent instructable.
I assume this is the Black Pearl, right? Very nice &quot;piratey&quot; looking model. I have been considering building either the 'Pearl' or the Flying Dutchman in a bottle. For the 'Dutchman, I think the movie one is easier to copy because of all the footage, but making the legendary one from paintings and word descriptions from the era of exploration is a little bit trickier because they are all different. If I made this one, I would use clear plastic or something to hold the ship above the &quot;water&quot; to make it &quot;fly&quot;.
Thats a geocaching travel bug in the picture right?
yes, I like to go caching whenever I get the chance. I have the same screen name on there.
That is just incredible! Very, VERY well done! <br>
Great work here! If anyone is looking for small drill bits but don't want to pay allot just ask your local dentist. They don't reuse them. They are small and free. Don't work well on metal but very well on wood. Fits most dremel type drills.
Here is mine! <br> <br>http://www.instructables.com/id/Ship-in-a-Bottle-1/
Hey, I have a bottle of a similar size which I want to use for one of these but it has a square base. So to better use up this space I want to make a clipper with rectangular sails. How would I make the sails fit through the bottle neck? Keep in mind they will probably be wider than the opening in the bottle.
Hello, The ship I made was a topsail schooner. There is one rectangular sail on the top of the front mast. This sail is similar to the sails on a Clipper. The thread &lsquo;hinge&rsquo; allows it to rotate parallel to the mast when entering the bottle. <br>
Okay, thanks!
Excellent instructable! <br>I think I noticed Ponal/ Elmer's White Glue used throughout. Did you glue the model to the bottle with White Glue as well? <br>Nice work. <br>G'
Thank you to the compliment. Yes, I did use Elmer&rsquo;s glue to attach the ship to the glass bottle. <br>
On the island of Mauritius there is a small factory which only makes ships in bottles. I went there in 2007 but the factory was closed when we went so I never got to go inside.
This is really quite amazing and one of the best tutorial on how to make these I have seen. <br> <br>I have a few questions, most of which I've conveniently forgotten, but, off the top of my head..... <br> <br>....what do you mean by typing paper? Typing paper is paper which is suitable to be used in typewriters, am I correct in thinking? If so, that may pose a problem. Therefore, are there any other materials one could use for the sails? <br> <br>Sorry that was so lengthy. <br> <br>Thank-you.
Hello, Any generic white paper should work. I used the bulk paper that you buy to put in a printer for your home computer. Out of habit, I still call it typing paper. <br> <br>Thanks for looking! <br>
where did you get the giant tweezers
The tweezers came from a box of odds &amp; ends that I bought at an estate sale. I got them years ago. <br> <br> <br>
Aren't ships in bottles made by putting the pieces in th bottle, rather than making the ship outside the bottle and then putting the ship in ???? <br>
About This Instructable
708,137views
415favorites
License:
More by goaly:Fast and easy shredded chicken sandwiches Fisherman’s walking cane (Or, retirement gift) Bird proof - Squirrel Feeder
Add instructable to:
