If I were to win the contest and win the grand prize, I would be closer to quitting my current job and concentrating on a business to design and make items for resale. That may include bass guitars. My background in computers, software, and manufacturing are all pieces to the foundation for my desire to expand my CNC and design skills.
Remove these ads by
Signing UpStep 1: General Planning / Tools / Suppliers / Sketches
TOOLS: These are the primary tools that I used: table saw, planer, hammers, digital caliper, many files, lots of clamps, router, cordless drill, various drill bits, small digital scales, dremel (with at least the cheap plastic base), spray paint equipment, headset magnifying glasses, dremel buffing wheel, and a CNC router with router bits helps. I had most of the tools but did have to buy a fret file and fret nippers for the planned fret work.
Other supplies include razor blades, carpet tape, painters tape, lots of sandpaper from 220 to 1000 grit, face masks/respirator, rubber gloves, wood glue, super glue, clear epoxy, feeler gauge, fret oil, polishing compound, binding tape, razor blades, ½” tap and tap handle (due to my table mounting process, and a board to mount the guitar onto for the routing). You’ll need the finishing material, but more on that later. Add in some 3D software for drawing the guitar. You should stock up on a lot of patience, too.
I ordered hardware and parts for the guitar throughout the process and will mention them at the point they came into the build process.
SUPPLIERS: These are the primary suppliers I used.
http://www.warmoth.com/
http://www.stewmac.com/
http://www.bestbassgear.com/
http://www.lmii.com/
http://www.grizzly.com/
http://www.thebassplace.com/
PLANNING THE GUITAR AND SKETCHING THE BUILD: My plan was to build a neck-through bass versus a bolt-on neck style. I also wanted to do the 3D routing over the full length at one time and then be able to flip it over to machine the back side.
The first step was to take my current guitar and sketch it out with any dimensional changes I planned. The following is just one of the sketches to show the detail I captured. I did separate sketches for the back side and the fingerboard to capture the dimensions accurately.
Visit Our Store »
Go Pro Today »
Makes me miss my my 4 string Peavey Tiger Maple Bass I sold a few months ago.
thanks
columbiad
I don't know that much about bass's, but what did you do about the truss rod in the end it's no longer visible at the back side of the neck. how did you cover it?
I am going to build a bass myself to but i've not yet started the physical work, I'm still in the planning phase. My biggest problem is absolutely that I have not nearly a tenth of your equipment (no cnc and other heavy machinery), this means I'll have to do almost everything by hand.
GRZ Pieter DC
http://www.stewmac.com/freeinfo/Truss_rods/i-0975.html
They are not really hard secured in the slot. The ends just fit snug so that any tension on the adjustment rod bows the rod.
Good luck.
On the wood, the body dark side wood is walnut; as well as the small 1/8" strips that run from top to bottom through the neck. The very center piece is hard maple, and the two pieces on the outside of the walnut strips are birdseye maple.
Reminds me of an Alembic with the laminated woods. And you can never have enough clamps.
