3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Optimus Prime Costume
Step 8My two left feet
My two left feet
To create the feet I took an old pair of shoes and and old industrial floor mat. (Like the ones store cashiers or chefs use) and stacked them on top of each other.
- Decide on how big you want the feet and create the box+trapazoid design you want.
- Cut out 8 to 12 pieces out of the foam and hot glue together on a pancake stack.
- Save just enough foam for the top layer where you will trace out a silouette of the bottom of your sneaker.
- You will cut out that silouette and put the shoe in. This will keep your shoe from sliding back and forth inside.
- Hot glue a velcro strap around all the foam pieces so that it meets just above the shoe. This will hold the shoe down into the silouette and give you more stability.
- Now build the shell around the foot and for added strength, insert some screws into the foam through the cardboard.
- When you paint make sure the shoes aren't inside the boxes!
6 comments
Feb 7, 2010. 3:06 PMdeathnot3d says:
what is the measurement for the top of the trapezoid (where the lights go)?
Oct 29, 2009. 11:03 AMkb8wsj1015 says:
what material is the foam padding? is it the foam board just being stacked on each other?
Jul 15, 2009. 9:04 AMFreddy108 says:
Hi, how deep did you go with the 'cut for natural foot flex'? Is it just through the first layer of foam, or is it through the cardboard outer too? Looks like you have cut over 3 thirds in from the bottom from the diagram.
Jun 16, 2009. 11:02 PMxXBudaXx says:
Also how did you achieve that shape, did you use more then one box and connect them?
Jun 16, 2009. 8:50 PMxXBudaXx says:
I have questions about the feet to this project. It says you used a strap that wraps around the shoe, what did you use?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
67
Author:dannyeurena
