Building Robotic Arm With Makeblock Parts
Published
Introduction: Building Robotic Arm With Makeblock Parts
About: Makeblock was founded in 2012 as the world's first open-source robot and programing platform. With more than 400 mechanical components, electronic modules, and software tools, we are determined to bring mean...
Here is the demo shows building a Robotic Arm with Makeblock parts.
More tutorials please visit :http://www.makeblock.com/
Step 1: Bill of Materials and Tools
Bill of mechanical parts:
    Beam0808-136x 3
    Beam0808-184 x 11
    Beam0824-016V2.1 x 2
    Beam0824-032 V2.1 x 3
    Beam0824-096 V2.1 x 3
    Beam0824-112 V2.1 x 1
    Beam0824-160 V2.1 x 3
    Timing Pulley 90T x 4
    Timing Pulley Slice 90Tx 5
    Timing Pulley 32T x 4
    Plate 3X6 x 5
    Plate 7x9x 1
    6x8 Triangle Plate x 2
    Plate A x 7
    Bracket 3x3 x 0
    Bracket 3x6x 2
    Plate O1x 1
    37mm Motor BracketV2.1 x 3
    Shaft Claming Hub 8mm x 1
    8mm Bearing Bracket A x 2
    Disc D72 x 1
    Flexible Coupling 4x4mmx 1
    D Shaft 4-50x 3
    Threaded Shaft 4x39mm x 6
    Shaft D8x96mm x 1
    Shaft D8x128mm x 1
    Circle Shaft 4x80 x 2
    Shaft Collar 4mm x 15
    Shaft Collar 8mm x 8
    Plastic Ring 4x8x1 x 3
    Plastic Ring 4x7x2 x 20
    Plastic Ring 8x11x2 x 5
    Bearing 8×16×5 x 2
    Flange Bearing 4x8x3mm x 3
    Plastic Rivet 40120 x 8
    DC Motor 37mm V2.0 50rad/min x 1
    DC Motor 37mm V2.0 20rad/min x 2
    Makeblock Robot Gripper x 1
    Screw Countersunk M3x6 x 12
    89MXL x 1
    112MXL x 1
    128MXL x 2
    Nut M4 x 52
    Screw headless M3×5 x 35
    M4X8 x 29
    M4X14 x 44
    M4X16 x 16
    M4X22 x 13
    Bill of Electronic parts:
      Me-Baseboard x1
      RJ25 Adapter x1
      Wall Adapter Power Supply - 12VDC x1
      Me Joystick
      Me Four Finger
      Me Dual Motor Driver
      6P6C RJ25 cable-50cm x2
      USB A-Male to B-Male Cable x1
      Tools:
      1. HEX Screwdriver 2.5mm x1
      2. Cross Screwdriver 3mm x1
      3. Wrench 7mm x1
      4. HEX Allen Key 1.5mm x2
      Step 2: Build the Base Assembly
      Step 3: Build the Arm Assembly
      Step 4: Assemble the Drive Base Assembly and Combine Them Together
      Get this package:
      www.makeblock.com/
        • Microcontroller Contest
        • Casting Contest
          Casting Contest
        • Make it Move Contest
