3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Building Small Robots: Making One Cubic Inch Micro-Sumo Robots and Smaller
Step 4Breaking The Rules
Breaking The Rules
To make really tiny robots, you may have to break many of the rules mentioned above. To make Mr. Cube I broke the following rules:
1- I used a single power supply instead of one for the motors and one for the microcontroller.
2- I mounted the Picaxe microcontroller very close to a motor.
3- I used batteries that are rated for low current draw and ran them at much higher currents than they were designed for. This severely limits the life of the batteries.
4- I crammed all the wires together in a hodgepodge which can create crosstalk and electrical noise problems. I was simply lucky that it did not.
5- I hardwired the circuit onto the robot without breadboarding it first. This can make debugging the circuit very difficult.
You can download the Picaxe programming code for Mr. Cube at: http://www.inklesspress.com/mr-cube.txt
If you are interested in seeing some of the other robots I have built, you can go to: http://www.inklesspress.com/robots.htm
Pic 9 shows Mr. Cube and Mr. Cube two, R-18, a 1/3 cubic inch robot that I have started to build. Details on step 5.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
386
Author:mikey77
I believe that the purpose of life is to learn how to do our best and not give in to the weaker way.
