3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Building a "Billie Jean" Sidewalk
Building a \"Billie Jean\" Sidewalk
Although it's not a scary addition to our Halloween decor, I built a lighted sidewalk (the famous effect from Michael Jackson's "Billie Jean" video) to entertain party guests and treat-or-treaters on their way to our door.
Only the wiring was a little tedious, the rest of the construction was pretty simple, and we've gotten lots of great comments and impromptu dancing.
Step 1Goals
Goals
First I came up with these goals:
  • Keep any additional platform low to ground. I don't want people to feel like they're stepping up onto something.
  • Span the whole 12-15 length of our sidewalk. It wouldn't look too cool if only a few feet were done.
  • Outdoor-friendly and fairly immune to moisture (we typically get rain in October).
  • And most of all it would have to work with fairly light people, but not crumble under foot of heavier ones. I had to figure people might start dancing on this, so it'd have to take a fair bit of abuse.
51 comments
1-40 of 51next »
Dec 28, 2009. 5:47 PMxadevox says:
where can i get acrylic panels and how much are they?
Dec 30, 2009. 8:55 PMxadevox says:
dang... so if i wanted to make say 20 panels thatd be like $360! dang! haha
Aug 18, 2011. 5:47 AMgtsky303 says:
actually $720 (20 panels x 4 sq ft each x $9 per sq ft), I wonder why acrylic cost so much. From what I found the frosted/colored translucent panels cost more.
Oct 16, 2010. 3:57 PMPMadds says:
What is this different-colored material in the middle of the square?
Sep 6, 2010. 1:30 AMCyborgGold says:
I may be doing something similar to this in the future now... but instead of using multiple LEDs and acrylic... I may use cement with fiber optic cables running through it (found in another instructable I read a while back) and have the loose ends running to the LED. Maybe even find a way to make it water tight so I can have a year round lit pathway.... if I ever find the money for the project I will definitely have to put it on here....
Nov 12, 2009. 8:49 AMeoutlaw says:
"I had to figure people might start dancing on this, so it'd have to take a fair bit of abuse."  Haha!  Have they?
Nov 12, 2009. 1:39 PMbounty1012 says:
Yea cause you know people are gonna "Beat it."
Apr 22, 2010. 1:46 PMFl0ris says:
haha, You better don't play that song when they walk over it :)
Apr 24, 2010. 7:48 PMbounty1012 says:
Haha, especially when the kiddies come near....
Nov 14, 2009. 6:27 AMjerjod says:
 You've got to do that!
Mar 11, 2010. 11:33 PMqueesy says:
I wish I knew what was going on here Im a fairly "newbie" type of user here. I was really interested in this but I feel there on detailed instructions missing for people like me to actually build this =(
Apr 22, 2010. 2:02 PMFl0ris says:
First you need some wooden frames, a translucent (lux=light, only permitting light) material, e.g. arylic, (you walk over this) and some weather stripping to seperate the transluc. material and the wooden frames. You put some wiring attached with foil duc tape on both sides (so you put this on the translucent material and the wooden frames on the left and the right). If the duc tape foils touch each other the circuit is closed. More info about schematic circuit in step 3.
If you have more questions please reply
Feb 25, 2010. 5:30 PMimpulse94 says:
This helps me with a couple of problems I've been having with my sensors.  I'll have to try those options!
www.instructables.com/id/3D-DDR-Frame-for-PS2/
Feb 25, 2010. 6:55 AMroccopeterbilt says:
I love your homemade pressure switch idea.  Just a thought on making assembly easier, if you put the foil duct-tape on as just a portion of a leg of the circut, but cut out a break a second piece of foild on the acrylic could bridge the gap and act as your switch.
Just my idea.
Dec 28, 2009. 5:21 PMxadevox says:
where can you get weather stripping?
Nov 27, 2009. 7:25 PMxtremd says:
 Congrats on your win! Great Instructable!
Nov 18, 2009. 3:07 PMStkMtd says:
I suppose this is pedantic, but you really ought to have some resistors on those LEDs. Awesome project otherwise. Any reason you used 2 switches here?
Nov 18, 2009. 5:51 AMampeyro says:
i've been trying something like this for a long time, but didn't find an effective pressure swich, will you be angry if i use this as "inspiration"?
Nov 15, 2009. 9:49 PMsensoryhouse says:
 Video Please!
Nov 14, 2009. 2:54 AMCamisado says:
Epic win in it's effing best. 5 stars, voted, subscribed.
Nov 13, 2009. 4:36 PMphoenixqueen says:
This is awesome!  I'd want to make one for a catwalk or something.
Nov 13, 2009. 11:37 AMsoshimo says:
I noticed you didn't have current limiting resisters on your leds.  The forward voltage bias is fixed on leds (depending on the led, color, and manufacturer anywhere between .7vdc to 1.7vdc) but you should still take measures to limit forward current to 20ma (or whatever peak current is for your device).  Typically 220ohm to 470ohm resisters are used.  Also, remember since you are in parallel you will have supply a resister on each current branch or you risk frying the one without a resistor.  You will also notice longer battery life if you limit your current draw on your LED.  I've seen the ultra brights light up plenty on 10ma and they blind at 20ma so it's up to your utilization.
Other than that, great idea and outstanding implementation.  I like your attention to detail.
Nov 12, 2009. 8:11 PMcanida says:
This is awesome!
Agreed with the others, video would be great - do you have any friends who can moonwalk?
Nov 12, 2009. 6:33 PMcancast says:
Would love to see a video of people using it!
Nov 12, 2009. 5:50 AMNinzerbean says:
 I think this is really scary, anything to do with him is perfect for Halloween.
Nov 12, 2009. 1:58 PMHardCoreHacker says:
You just hurt my feelings lol.
But really, whats your deal with MJ?
Nov 12, 2009. 6:21 PMNinzerbean says:
 Instructables has a "be nice" policy that I must adhere to. I am a big fan of Instructables.
Nov 12, 2009. 2:18 PMmskogly says:
Love it! And I second the addition of video to this tutorial. And yes, Billie Jean baseline is a must!
Nov 12, 2009. 8:46 AMeoutlaw says:
This is so friggin' brilliant!
Nov 12, 2009. 7:56 AMrecumbentrecycler says:
It would be cool to see someone cover a hallway floor with these things.  Very nice.
Nov 12, 2009. 4:22 AMKlappstuhl says:
Awesome.
I'll so build one in my apartment, all the way to the toilet! XD
Nov 12, 2009. 6:13 AMmoesboy says:
that would be awesome
1-40 of 51next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
53
Author:flaming_pele!
Web developer by day. Gamer by night. DIYer, all the time! My projects tend to combine technology and craftsmanship to produce something that's fun to use and cool to look at.
