3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Building a "Billie Jean" Sidewalk
Step 4Cheap and reliable pressure switches
The real trick was thinking of a switching mechanism. I considered micro switches, limit switches, and finally decided to keep it simple (and cheap!) and make a home-brewed pressure switch. My idea was to tape a wire to the upper (acrylic) and lower (frame) pieces of each step with some foil duct tape and separate them with a bit of weather stripping (3/8" thick). The panel sits on top of the weather stripping and as it's depressed, the two pieces of foil make contact and the lights go on. Once the weight is off the step, the weather stripping springs back, and opens the switch.
I decided to place two switches per each step on the edges you walk across. Closing either or both switches would complete the circuit. The good thing about this is that as you're walking along, even if you just catch the edge of the next step, it will light. Having to step in the center of each step would be much less effective.
Adjusting the sensitivity of the switches is easily done by changing the length of weather stripping and how close it is to the foil switch.
6 comments
Oct 16, 2010. 3:57 PMPMadds says:
What is this different-colored material in the middle of the square?
Mar 11, 2010. 11:33 PMqueesy says:
I wish I knew what was going on here Im a fairly "newbie" type of user here. I was really interested in this but I feel there on detailed instructions missing for people like me to actually build this =(
Apr 22, 2010. 2:02 PMFl0ris says:
First you need some wooden frames, a translucent (lux=light, only permitting light) material, e.g. arylic, (you walk over this) and some weather stripping to seperate the transluc. material and the wooden frames. You put some wiring attached with foil duc tape on both sides (so you put this on the translucent material and the wooden frames on the left and the right). If the duc tape foils touch each other the circuit is closed. More info about schematic circuit in step 3.
If you have more questions please reply
Dec 28, 2009. 5:21 PMxadevox says:
where can you get weather stripping?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
53
Author:flaming_pele!
Web developer by day. Gamer by night. DIYer, all the time! My projects tend to combine technology and craftsmanship to produce something that's fun to use and cool to look at.
