3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Building a Capacitive Liquid Sensor
     A capacitive liquid sponsor relies on the fact the the capacitance or charge between 2 metal plates will change (in this case increase) depending on what material is between them.
     This allows us to create a level sensor that is safe for use with any liquid, this one will be used in a buggy with gasoline (petrol).
One plate is hooked to ground. The other connects to pin 23. There is a 820K ohm resistor from pin 22 to 23. The sensor works by charging the capacitor (the water bottle) and measuring how long it takes to drain through the resistor.
Step 1Parts
Parts
1. A solder-less bread board is strictly not needed but make it a lot easier, especially if you plan to add other stuff later.
2. Arduino, I'm using an Arduino mega but a standard one should have just enough pins.
3. LCD character display.
4. Some odds and ends including some wire and a 1MΩ resistor.
5. A computer, you know, that thing your using to read my instructable with.
6. Patience.
26 comments
Dec 7, 2009. 8:08 PMpelrun says:
Sweet 'ible, but can you elaborate more on exactly how the bottle is wired up? It's rather brief and ambiguous at the moment...
Feb 8, 2012. 6:35 PMbill.schuller says:
How'd it go now that Thursday night was a year and a half ago?
Mar 31, 2011. 4:40 AM29guitarman says:
hey yeah, how did you connect the wires aswell? can you explain further on how you set the bottle out?
Cheers
Nov 29, 2010. 5:55 PMlw119 says:
This is pretty clever. I think I am going to try something similar.
I have pet cockatiels that love to backwash in their water dish. It doesn't take long for the water to get kinda nasty. I wonder if something like this could be used to alert me when their water needs a change out.
Have you ever noticed a significant reaction to the electrolyte getting contaminated? Any tips you can offer would be much appreciated.
Thanks for the inspiration.
Nov 29, 2010. 6:55 PMlw119 says:
I have a float that maintains the water level so I don't think that would be an issue.
I considered the infrared idea but they like to bathe in the water too, so that might trip it. Plus, they like to break things, so I was hoping some submerged concentric metals tubes would be beak proof.
I guess it's a trivial problem but a fun challenge.
Thanks for the reply.
Oct 14, 2010. 3:18 AMHunter601 says:
Hmm.. I'm trying to figure out if this would be the right way to measure the qty of Heating oil left in a 1000 Liter plastic tank, which is about 160 cm high and the other dimensions about 80 cm each.
I haven't noticed (or have overlooked) any max practical size for your setup but I assume it might not work out for my requirements, right?
Could anyone point me in the right direction? Maybe sink a pressure sensor to the bottom of the tank and read out the static pressure, using an Arduino?
Oct 14, 2010. 7:23 AMHunter601 says:
Ok, concentric tubes makes good sense. Thanks for the tip.
May 25, 2010. 11:11 AMTheBestJohn says:
 2 questions and a comment.
1: so the two aluminum sheets sit outside the container? one on either side of it?
2: would there not be a risk of the capacitor discharging and creating a spark?
Comment: NO METAL CONTAINERS!? I guess a keg level sensor is out of the picture lol.
May 7, 2010. 12:56 AMlinkthewise says:
 Hey I one question did you cut the aTinFoil in two pieces and you put them in the sides of the conteiner?.
Apr 9, 2010. 4:49 PMzoltzerino says:
 Good Instructable, nice XKCD reference...it's so true ;-)
Feb 2, 2010. 8:09 AMMomentumV says:
how well did this work with petrol instead of water?
Jan 28, 2010. 11:44 PMmakkan says:
Just what I have been looking for to measure the coffee level in the office coffee machine.
Dec 9, 2009. 3:16 AMbullzebub says:
how are you going to handle the odd shapes of a gas tank?
it would be nice to have someting that shows a realistic approximation on whats left in the tank.... not like most car systems
Dec 8, 2009. 12:20 PMlemonie says:
The permittivity of water is about 80x that of air, the permittivity of gasoline is about 2x. Are you confident this will be sensitive enough on a gas-tank?
L
Dec 8, 2009. 1:38 PMlemonie says:
No, it's much more similar to air, water is more polarised / ionic. But do let us know how it works out.
L
Dec 7, 2009. 7:51 PMjam BD says:
nicely done =D
Dec 7, 2009. 7:34 PMErik Lindemann says:
Favoriting this. I love the logic that went into this homebrew liquid level sensor.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:VadimS
