3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Building a Chicken Tractor, the LONG and DIFFICULT Way! (UPDATED!)
Step 5Drilling the holes in the Base
You need to drill 3/4" holes into the top of the pipe, so you can push the ends of the conduit hoops into them and secure with a screw.
Since you are using a drill that has a removable chuck, make sure to put the chuck somewhere other than on the drill.
Go to the barn to find the chuck.
Discover that the biggest bit that will fit in the drill is 3/8".
Go to the barn for a 3/4" bit.
Come back 20 minutes later, without one. You have 9 toolboxes, but can't find one drill bit in any of them.
Drill one hole in the elbow of the base, then mill it bigger with the 3/8" bit by wiggling it around.
Drill second hole same way on next elbow.
Find it immediately in the first box you looked in before.
Measure and mark every 2 1/2 feet for the other 4 hoops (3 along the pipe, one in the elbows on the other end.)
Drill 8 holes with 3/4" bit in less time than it took to drill the first one with the 3/8" bit.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:FireBAT
Well, I am a Fire B.A.T. - A Breathing Air Technician for firefighting equipment. I repair and test Survivair Breathing Apparatus and air compressors. My wife and I recently moved to her parents' far...
more »
