Step 6Attaching the hoops
Break bit.
Remove chuck to expose 1/4" drive socket for screwdriver bit. Put squaredrive bit in holder.
Discover bit is too short.
Pull bit out with pliers and put in longer holder.
Push end of hoop into hole, and run galvanised screw into the side hole using the drill.
Break the head off the screw, leaving the stump jammed into the conduit and preventing you from pulling the hoop back out of the hole.
Fix it.
Repeat at other end of hoop.
Push end of second hoop into hole, and run galvanised screw into the side hole using the drill.
Break second bit.
Push end of third hoop into hole, and run galvanised screw into the side hole using the drill.
Repeat until all 5 hoops are secured.
Didn't you bend SIX hoops?
Drill holes through ends of unbent section of conduit, and , using wire, attach the straight piece to the tops of all the hoops, to keep them from wobbling.
Remember how you made the base sections 10 feet long to match the top conduit, which is also 10 feet? You also added elbows to that length, making the base about 10 feet, 5 inches long, and the end hoops more than 10 feet apart.
Cheat. Angle the ends in so the top pipe will fit.
Go to the barn to get a roll of electrical tape, to add some security to the wired connections on the hoops.
Discover that you knocked the glue over, and since you didn't screw the lid on tight, half the can is now a sticky puddle in the grass.
Frame is DONE!
Drink second expired Apple Juice Box.
Add Comment
