iImage Information
For many years I have been interested in Gypsy Wagons or "vardos" and western sheepherder wagons. As it isn't practical for me to have an authentic, horse-drawn lifestyle I decided to make a version towable at highway speeds. After reading just about every book I could find on wagons, caravans, old-school RV construction and trailers, a model began to take shape in my head. For me, it needed to be short and maneuverable, sleep two to three people, and still have the air of old world craftsmanship. This meant not looking like a modern RV. My secondary goal was that it should cost as little as possible without sacrificing sturdiness or basic comfort. Finally, I decided on wood as the primary building material as that is what I am familiar with and is definitely a very cozy and comfortable medium for a living space.
Most of the actual work was performed with a table saw, band saw, drill, and a slew of hand tools as I found time around my day job. Although I don't really consider it "done", it is complete enough to use and is currently on the road.
Step 1The Mock-up
iImage Information
After about fifty sketches and lots of graph paper renderings, I decided I needed to visualize this in three dimensions. Here is my cardboard mock-up of the final design. An earlier version is visible behind it but this one had a lot of appeal for me. My requirements were 7' width for sleeping cross-ways, 8-10' long, and enough height to stand up in. A collapsible bed and table allow for a shorter overall wagon. The first drawing above probably gives the most accurate dimensions for the final product. You can see some changes in design even as I approached the final product.
I like the way yours is laid out very much. We have to consider hot temps more than cold, so we have to figure the bed situation to not cook someone in a box on the floor with no ac.
We have embraced your ideas for building no complicated systems into it. Thanks for that. Sure simplified the build. We also have a metal frame welded up with an aluminum skin from the get go so it will stay light weight. The wooden parts are being painstakingly pieced together by us now.
Thanks for your blog and instructions. It sure helps when we don't have to reinvent things.
Awesome project! I wanted to build one for years and use it while traveling and if possible live in it while I was a Park Ranger in Kansas... I also wanted to take my parents 16' Lakota tipi and live in it for the 5 months I was there but both fell through mainly cause I was there was from January to May! My family wouldn't want to see me freeze on the Kansas Plains!
Thanks again for sparking that intrest in me again!
just wondering ;>
To make it look a little more "authentic", maybe paint the wheels with
"wooden" spokes?
The "sporty" looking wheels it currently has just look a tad...
anachronistic?
Very, very, Cool.
I was also pleased that you did a reasonably long trip for the test as well.
Great stuff.
HAPPY TRAILS
Keep up the good work.
In some states, it's also the law to have an emergency exit in a trailer designed to sleep in. Again, I would strongly urge anyone considering a trailer build, involving a wood stove especially, to add at least a transom type window big enough to crawl out of to the front of the trailer to give you an emergency exit. It's better to have it and not need it than to need it and not have it.
I would still install at least one alternate escape route, but wood stoves are as safe as gas burning heaters. I would connect an emergency electric heater for when the coals burn out. I live in the mountains, so I built an electric furnace to automatically turn on if the main heater drops below 50 degrees.
My neighbor installed a wood-burning stove in an old camper. It works good for him. I offered to make a sheet metal covering with weather guard. If I can get his permission, plus make a weather guard, I would post it.
I like your build. Nice job.
I don't trust the stove to run unattended. Heat in a small space is a dangerous thing and I think it would be great to have a second egress. I keep fire extinguishers nearby and even in the cold I have avoided sleeping with a roaring fire. Honestly, in such a small space, I actually am at least as concerned with CO buildup or smoke inhalation in a fire. My ideal is using more blankets and no night fire. I have only broken this rule once during an extremely cold night this winter. Generally a morning fire takes only a few minutes to heat up the entire wagon nicely with a handful of wood.
Otherwise, for me, I use the wagon more like regular camping and less like a modern RV which is treated like a house. I have spent enough of my life sleeping in the open on the ground in all weather that I don't really expect or need the air temperature to be in the 70s all night long.
I hope you put up some images of your design/build when you get to that phase. I look forward to seeing your wagon.
Steve
I noted your comment somewhere in Forums about how to "Flag" someones off topic remarks. Please don't be distracted by "off topic" comments they are not worthy of your time. Simply ignore and they will die away. Great job.
Thanks for the kind words. It is still a work in progress but has made a cozy part-time home and travel companion for a while now.
Other than that, nice looking project.
