Please let me know if there are any ways you think I could improve this instructable, and if you have any suggestions for design or constructions modifications.
Shameless Self-Promotion: If you like it, vote for it in the Make it Move contest! Please?
Disclaimer: Multiple instruments are used within the construction of this project that are dangerous if used improperly. Furthermore, if the project is successful and the end result functions correctly, then it will spew hot steam, boiling water, flame, or any number of potentially hazardous substances. Don't hurt yourself, and its not my fault if you do.
Another Disclaimer (New videos=more uses of the engine=more minor injuries=more safety advice): Because of condensation, the method of filling the chamber, overfilling the chamber, the nature of the apparatus, and more, it is possible (read: likely [read: pretty much inevitable]) that you will have some sort of liquid (rather than vapor) discharge from the tubes. In my Engine, the drips from the tubes land right on the hand holding the torch. Although in my experience, this is significantly more likely with the water-filled vs the alcohol-filled Engine, PLEASE take necessary precautions to keep yourself safe. Furthermore, even though the alcohol-filled Engine is less likely to drip, this is by no means a reason to take fewer precautions. The risk from fire not only exists from the rather conspicuous jets of flame from the tubes, but also from the drips which primarily happen at the beginning (before the flame heats the tubes enough to vaporize them before they reach the ends). In short, make sure the area around the Engine is safe, and make sure you protect yourself adequately. One last word of wisdom: don't try to "pre-heat" the tubes with the torch. It's difficult, unnecessary, and if there is any liquid in the tube at all, the tiny amount that you vaporize will eject the rest of the volume of liquid, most likely onto some place where it will cause you pain. Trust me.
More information on Hero's Engine:
http://en.wikipedia.org/wiki/Aeolipile
A video of my Hero's Engine filled with water:
Remove these ads by
Signing UpStep 1Materials and Equipment
Materials:
1 Sheet 22 gauge steel (12in x 24in)
5 ft of copper tubing (1/8 in) I used cooling tubing originally intended for a refrigerator/air conditioner/something else from Home Depot
Solder
String (I used old kite string I had lying around)
Equipment:
Dremel tool with cutting wheel and small grinder
Ball-peen hammer
Vise (both to hold material and as place to work the metal)
Blowtorch (for sweating [brute force soldering] the connections and for operation of the final product)
Aviation Snips (for cutting the steel: very heavy duty, and ideally not ones you mind getting a little dull)
Bag of something impact absorbent and moveable for shaping the metal on (I used charcoal, but anything like sand, gravel, dirt, etc should work. This will become clearer later)
Thanks for the comment, please let me know if you find a solution!
On a tangentially related note, I would prefer a slower, reflexively heated apparatus as opposed to one that I had to A, get near with a torch while its spewing fire, and B, constantly regulate the temperature to avoid it extinguishing itself.
One other option for a reflexive heating system would be a small hole in the bottom of the engine, with a very large, sturdy wick. The pure alcohol/alcohol vapor would keep the fluid inside the chamber from igniting (lack of oxygen) , and the outer part would reflexively heat the chamber. However, that configuration has multiple design challenges and risks.
As always, comments/feedback/constructive criticism much appreciated. Thank you for your comment!
Thanks for the idea!
(Also, as entertaining as charging the entire assembly with O2 would be, I don't have any blast shields, or and gimballed nozzles =/ )
And no prob. Glad to be of service.
Thank you for your comment! Any other ideas you have are much appreciated!
Thanks for the comment!
i havent seen one of these in a long time (few years or so),
its a slightly different take on the one i saw.
here is a link to one like the one i saw
http://www.youtube.com/watch?v=QBh8cHZvE9U
lol for the safety, hope the water didnt get you
5/5
and the Metho is a realy neat trick
Thanks for the comment and the compliment!
The RPM is variable on the fluid being used and the heat level. I felt like I had more RPM with the alcohol, but that was probably because it was exciting and on fire. I would say that the alcohol-filled engine gets to about 60 (or a little under) RPM before it blows itself out. In my relatively few tests (I was more interested in the flaming version) of the water-filled engine, I definitely got it above 60 RPM, and probably could have gotten it faster, but I still hadn't figured out a good way to keep heating on the vessel without burning my hand (if you look at the water-filled video on the introduction page, each time the torch flinches/moves away is me getting hit with very hot water).
Thanks for the ideas!
First of all, barring sturdy attachment to a really nice ball-bearing rotational stand, the assembly would have to be suspended, ideally exactly through the centers (for rotational symmetry and its attendant stability), making the water bottle, and more importantly the hose and check valve assembly, load bearing.
Furthermore, you would have to be able to somehow regulate the flow rate of the water, so that you didn't flood the chamber initially (one thing to note would be that if you had enough water flow, the water out of the tubes would provide the same thrust, but I doubt that's what you're looking for), and so that you got enough water flow through it to matter.
However, I do think that the black chamber and reflector would work great with just the liquid in the chamber.
If you get some water bottle feed apparatus working, I would love to see pics/descriptions.
Have a good (Safe) weekend everybody ;-)
Gordy
and experience
BACK PRESSURE INTO THE WATER SUPPLY TANK,
which is what the check valve is intended to stop, not regulating water coming out into the expansion tank. so you'd orient the check valve that way,
sorry if that was unclear.
You don't want hot gas feeding back into the supply and pressurizing it.
Of course, I'm talking about the ridiculous notion of making it powerful instead of what the OP may intend. Pay no attention at your pleasure.
1. Make a string harness for the base of the water bottle that will tighten when placed around it and the bottle suspended upside.
2. Attach the 'motor' to the bottle. The rotation will now be generated at the base of the bottle rather than the engine.
3. Small hole in top of motor for water line attached to a valve which is attached to the bottle.
The opening or closing of the valve controls water flow and the the whole motor will spin on the string attached to the water bottle harness.
1. The Engine would have to be used with a solar arrangement (which does not yet exist outside of theory), as it does not seem very torch-proof
2. The flow of the water into the chamber would, ideally, be just enough to keep the pool in the chamber roughly the same size. As the engine heats up, more and more vapor is expelled, which means a variable flow would be necessary to keep the pool the same size (less at the start, more as the chamber heats up). However, I do think that this would greatly extend the time it can turn itself, even without a way to vary flow during operation.
Thanks for your feedback!
The vaporisation in that assembly takes place in the lower chamber rather than the upper chamber, but the principle is roughly the same.
To further streamline your design, it would be great if the feed line was actually a relatively large diameter tube topped with a sealed bearing: this way it could be both the base/stand of the chamber and the feed line. The only problem with this would be if the negative pressure from the attempted recondensation of the steam would be enough to pull a sufficient amount of water/vapor from the reservoir.
Great idea, thanks for the comment!
Let's keep brainstorming though, I like where this is going.
If you had some sort of feed system that allowed the chamber to rotate on an axle rather than a string, I see no reason why you couldn't put bevel gears on the axle to transmit the motion to a horizontal axle, but practical application, as far as I can tell, is limited to a steampunk rube goldberg machine, or something equally novel.
Thanks again!
Also, sheet copper would look great in this application.
GREAT WORK!
Also, about the sheet copper, I agree that it would look great, but I worried about whether or not I would be able to hammer it into an appropriate shape (a big enough chamber) without tearing or other holes.
Thanks for your ideas!
