3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Lightsaber
Step 2Parts and tools
Parts and tools
You need PARTS.
Go to your local hardware store and buy parts (some parts will not be available at your local hardware store and must be special ordered). If you have a local Surplus Electronics Recycling store near you (Weirdstuff, Electronics Goldmine), go there and rummage around at the old electronics. Gather anything that looks "cool", geeky, futuristic, funky, hi-tech, or would seem useful later on.
Go to The Custom Saber Shop to buy specialty parts:
http://www.thecustomsabershop.com/
OR Ultrasabers
http://www.ultrasabers.com/
Also go to
http://www.onlinemetals.com/
http://tapplastics.com/
http://www.mcmaster.com/
If the parts do not make sense now, don't worry, I will explain each section of the lightsaber in detail in the steps to follow.
The Blade:
1 x 30-36 inch long Polycarbonate (pc) tube, thick wall 1 inch outside diameter (OD). Wall thickness should be 1/8 inch. This is the blade.
1 x end cap for the pc tube (blade tip)
1 x blade film ("corbin" film is great)
1 x reflective material with a diameter smaller than the inner diameter of the PC tube.
The Hilt:
1 x blade/LED holder (aka the emitter)
1 x 1.5 inch chrome sink tube. 12 inch long
1 or 2 x sink tube adapter. 1 to attach the blade holder to sink tube and 2 if you have opted for a machined pommel.
1 x switch or button
1 x pomel or end cap
What ever else parts you want to attach to the hilt body - grooved section, plates, gold trim, jewels, tapered section, leather. BE IMAGINATIVE. MAKE IT DISTINCTIVELY YOUR OWN.
The Electronic Guts:
1 x High power LED (luxeon III, K2, V, Rebel; seoul P4, or any LED with a lumen output above 60). Decide if you want to buy an LED emitting a certain color or a white LED and use color filters. The lightsaber I built for this instructable in theory should be pumping out over 300 lumen... In theory. You will see later how I accomplished this.
1 x compatible optical lense to focus the LED to 10 degrees or less.
1 x method to control the current going into the LED - for the example a BuckPuck was used. A Resistor can be used but that method is less efficient.
Sound: Optional, but without it you just have a stick that lights up. At the very least consider pulling the board out of a Hasbro toy.
Batteries, battery holder, speakers, sound board, lots of screws, vibration motor, crystal chamber, and wires.
Tools.
Solder iron 45 watt or higher and some good quality solder.
Hack saw
Rotary tool (Dremel) with sanding drum, cut-off wheels, grinding and shaping tools.
Drill and drill bits
Jeweler's files
a screw tap set
screw drivers
allen wrenches
hammer
Glue for metal or epoxy
Elmers glue
Graph paper
Pencil
Sharpie
Sand paper, course and fine assortment
24 comments
Oct 8, 2009. 11:52 AMdarthdredge says:
How much does all of this cost?
Mar 13, 2012. 2:01 PMsup3rj3d! says:
It can range from 75 to 200 dollars depending if you have accessories on. It can also depend on the quality and where you buy it. For example, Lowe's sell the sink tube for 10 dollars and the Home Depot sells the tube for 7 dollars.
Mar 13, 2012. 2:18 PMdarthdredge says:
It took three years for someone to reply to my comment...
May 21, 2012. 10:37 AMGenises says:
easily the funniest comment on instructables... :)
Mar 13, 2012. 6:32 PMsup3rj3d! says:
well, 2 days ago
i signed up 3 days ago
Mar 13, 2012. 1:16 PMsup3rj3d! says:
Did you use a 350 mA BuckPuck, i found a 350 mA, 500, and a 700 mA and what store did you buy them too?
Sep 30, 2011. 10:18 PMmemoriable says:
Ultrasabers Has A Whole Section Dedicated To Getting You The Parts You Need For Building Your Custom Lightsabers. Visit It Here.
    -Custom Lightsabers
Nov 9, 2010. 6:54 PMStArwArsN3rd says:
Other than a buckpuck, what can u advice me to buy on a cheaper scale, and if you did buy it cheap where did you go if it's online?
Nov 10, 2010. 8:13 PMStArwArsN3rd says:
Thank you but i think the 3 dollar resistor at Radioshack shall work, I'm cheap, just not that cheap.
Oct 30, 2010. 6:20 AMmikethemaster123 says:
what lens did you use for the tri-star?
Aug 9, 2010. 9:44 AMlord vader says:
(removed by author or community request)
Aug 10, 2010. 8:35 AMLuziviech says:
i looked for most of the stuff on ebay; i found a seller for "plexiglass"-tubes (which is the german word for polycarbonate-tubes, then there are several sellers for hi-power-led and -equip plus the guys from china/hongkong and several low-bidding starwars immitate-lasers that i'd use for the soundboards. I guess things become harder only for the film (dunno where to get that cept from your seller).
Sep 26, 2010. 11:24 AMfrankha says:
Plexiglass is acrylic, also known as Perspex, which is a trade name, polycarbonate is is most commonly known under the trade name of Lexan and chemically is totally different to Plexiglass/Perspex.
Sep 29, 2010. 1:40 PMArx says:
Do you have a link to this thread? I'm going to try it anyways, but it would be interesting to see.
Aug 12, 2010. 5:22 AMlord vader says:
dont worrry anymore i found me a lightsaber to buy it is darth vaders exact replica for R1 951.00
Mar 16, 2010. 8:58 PMdepotdevoid says:
Hi, great instructable!  I've got a couple of questions about sourcing the parts though.
I am a total cheapskate but was planning on making a couple of blades--finding the polycarbonate tubing from mcmaster or grainger was easy, but what is an alternate source to TCSS for the tip and the film?  I'm having trouble finding those, do you have any ideas?
Thanks for your help, and again, great instructable!
Mar 22, 2010. 12:02 AMdepotdevoid says:
Thanks, I've poked around on their site just now and come up with this:
Acrylic Cabochons
They look right, but the page specifies that, "The bottom of the 1/2 cabochons are not flat."  Is that alright, or is there a different product I'm missing?
Also, did you have an alternate source for the light diffusing film, or is TCSS the only option?
Thanks again!
Mar 22, 2010. 8:10 AMdepotdevoid says:
Okay, I'll give it a shot, thanks for your help!
Dec 3, 2009. 6:47 PMnivekcizia says:
 aww sketchup. that's cute
Oct 10, 2009. 12:55 PMDarth-Vader says:
that is cool
Oct 8, 2009. 12:29 PMOrtzinator says:
Some of these parts, like the PC tube would be cheaper from somewhere like McMaster-Carr <a href="http://www.mcmaster.com">www.mcmaster.com</a><br />
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
139
Author:MrTinkerer(ODST)
I like making stuff when I have the time. But It is soooo hard to find TIME...
